Question about Intel Desktop Board D815EGEW (BOXD815EGEWU) Motherboard
External connection problem
I am making up another PC..and I have just installed all the hardware including a D815EGEW motherboard. The only problem I have is the external connections (e.g. Reset switch..power switch...HDD drive ..etc)) I connected them as per instruction manual but it will not work. There are two extra sockets coming from the front...named VCCD minus....VCCD plus....and I cannot find where they connect. Any ideas?
    Novelist:
    Scholar:
  • 104 Answers
I know you said your following the manual, but the connectors you're talking about sounds like the ones fro USB! Make sure you are using the one outlined in this image!!! regards, babb
Posted on May 06, 2007
Monitor stays off
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions
even something as small as an electrical fan and its lead can cause you problems
computers need all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps you
Mar 28, 2012 | MSI 848P Neo-V Motherboard
Front panel setting Intel D815 Motherboard
Goto the Intel download site (Click here) search for "D815EGEW" and download the PDF manual. Connection diagram is mentioned in detail in that manual.
Jun 22, 2011 | Intel Desktop Board D815EGEW...
D815egew sound driver code 10
Hook up wiring for Intel motherboard D815EGEW
Dec 24, 2010 | Intel Desktop Board D815EGEW...
Display problem
More info needed like OS and monitor / PC model.
Dec 08, 2010 | Intel Desktop Board D815EGEW...
PIN CONFIGURATION FOR CONNECTING FRONT PANEL CABLE
Use the following link to download the documentation.
http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/17795/eng/motherboards_desktop_d815egew.zip&lang=eng&Dwnldid=17795&ProductID=783
open the zip file and open the PDF folder and open the file ew_english.pdf or refer to the picture below
siddiquema_1.jpg You should be able to connect it.
Dec 05, 2010 | Intel Desktop Board D815EGEW...
Screen lights pure white. When connected to external monitor screen shows Windows startup for about ten seconds, then goes blank.
Possible failure of the display drivers/ the hardware in the section of the motherboard. Since the fault is confirmed with the external display the motherboard needs a probe and you might need help to get a consensus.
I don't think a re installation can do any good as you are not able to get the OS on screen display.
Nov 26, 2010 | Acer Aspire One Netbook 8.9" Notebook
Pc acer aspire T650. My card reader fail so i took it out from my pc. Since then I have problem to make my pc read my external HD and the 2 usb in front don't work and since a very long time. Where can I...
hi,
Infact front USb ports are connected with the card reader it self.If you are havingthe separate connectors then you will have to connect those to motherboard to make those USBs to work.
You can get any 9 in one card reader from nearest hardware vendor and deploy it.
thanks
Jul 27, 2009 | Acer Computers & Internet
Motherboard
Intel's Driver Download Center Select your product in the product categories listed on the left. Downloads are grouped by product. Are you looking for an Intel® Modem Chipset Driver? ...
Jan 23, 2009 | Intel Desktop Board D815EGEW...
External SATA hard drive will not wakeup after "System Standby"
All in one !!!
http://www.mediaatlantic.com/section.php/1730/0
This device will switch off all devices connected to it (including your hard drive) at the same time as your pc is switched off.
There are other models available.
Danechip.
Mar 27, 2008 | Intel Motherboard
Modem
To access the ports you mean via the control panel.  If it is an internal modem then XP would automatically install it as a hardware providing it is connected to the motherboard.  I detected you saying that you rebuilt the PC.  Have you slotted an internal modem into one of the periferal slots or did it use an external modem.  Did you know you dont need a modem to logon to the net unless your dialing up? But if you use broadband most use an external modem that connects fast ethernet connection.  But I suppose you know this after all you rebuilt the machine.
Oct 10, 2007 | Toshiba Satellite A10-S167 Notebook
Intel Desktop Board D815EGEW (BOXD815EGEWU) Motherboard Logo
50 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
