Question about Makita 12V Cordless Impact Driver - 6980FDWDE
Can't get the keyless chuck off cordless Makita 6095D drill.
The drill stopped working, dead. The batteries hold a charge fine. I tried getting the case apart to look for something loose or disconnected, and couldn't get the chuck off. Rather than a screw head inside the chuck, there is some other kind of head I can't budge with an allen wrench. What to do?
  • 2,176 Answers
If this is a newer tool it is probably a Torx drive screw usually a T20. The screw is LH thread and after removing it you will need to put some screws back in tool to remove the chuck. First shift the gear selector to the low setting and the clutch to the drill only. Next get a bent handle allen wrench about the capacity of the chuck install the short end of wrench in chuck and tighten. Put the chuck on a block or wood or a workbench to support is and turn the wrench to about a 30 degree angle in the counterclockwise position. The chuck has standard threads so you want to hit the wrench with a hammer to loosen it. This might take a few tries but it will work. Good luck
Posted on Dec 31, 2008
How do I remove the drill bit from a Makita6223D?
If your drill has the original keyless chuck on it, there are two plastic rings on the chuck. The outer ring should tighten and loosen by hand enough to hold the bit(s). The inner ring is to hold on to if the chuck gets overtightened. Chucks do wear and get corroded over time and can get locked in position. If you can't get it loose by hand, channel lock pliers can help. If the chuck is that bad you may need to replace it.
Mar 03, 2013 | Makita 9.6v Cordless Impact Driver 6903VD
Keyless chuck drill just spins
Some times the selector on top get gummed up with dust, it just needs cleaning. You were right to put it into 1st gear to remove the chuck with a big allen key, you get more resistance in the gears.
May 30, 2012 | Makita Drills
How can i replace the keyless chuck on my makita
I answered that question already on another post, but if you need to know how to remove the chuck I have detailed instructions in the TIP SECTION on how to do this. Let me know if you need more help
Dec 31, 2011 | Dewalt Makita Bhp452 18v Lxt Lithiumion...
How do you remove the chuck on a 18volt makita drill driver
there is a flat head screw in the center of the keyless drill chuck counter clocwise to remove.
Nov 28, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
We were using a makita cordless power drill. Somehow the clutch got stuck and it won't spin or open where you put the drill bit in. The motor seems to be spinning, think the problem is just in the...
keyless chuck. grab the ring immediately behind the chuck and the tampered chuck piece with a padded channel lock plier. turn the chuck part clockwise to release.
Oct 26, 2009 | Makita Drills
Remove keyless chuck on a 12 volt makita drill
There should be a Screw in side the end of the chuck were u put the drill bit in u will have to undo it back wards its got a left hand thread
Oct 23, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
How do I change the bit on makita 6095d The drill bit is on right now and I simply want to change it to the phillips screwdriver bit. Thanks
have you opened up the chuck to remove the drill ? If not then you need to by holding the chuck tightly with your hand and then run the drill in reverse. hope this helps you
Oct 05, 2009 | Makita Drills
I bought a new highter current ni cad for my makita; however, the
As long as the charger voltage and the battery voltage match (7 volts) there should be no problem. A fast charger just runs more current thru the battery (per unit time) than a not-so-fast charger. If you notice the battery getting really hot when it's charging (like too hot to touch), stop using it.
Apr 28, 2009 | Makita 6019DWE 3/8 Cordless Drill Keyless...
Keyless chuck
You will find a screw inside the chuck that needs to come out first of all but beware that it will be a reverse thread. This is to stop it loosening whilst in use. then you will need to unscrew the chuck but it isn't easy as you have to hold the shaft that the chuck is attatched to. You can sometimes take the chuck off by holding it and pulling the trigger while in reverse. (but they can be stuck fast).
Aug 10, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 12V Cordless Impact Driver - 6980FDWDE Logo
3,258 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
