You need to call your service provider and get them to resend you your settings. When you receive them via message just click save and it will automatically set up
U must need to connect with internet.when 2 phone have active mms setting,and internet setting than u can send mms/photo.for internet setting talk with ur sims service provider.
you need to configure the mms settings from your internet menu... but you need the right configuration from your network provider to the settings..
to give you an idea, here's how you may do it..
from your phone, press menu
select internet
select browser profiles to lead you to internet profile settings..
from your settings, press create.
then create the mms profile your network preferred.
once created, press save and exit the settings for internet profiles..
to make the mms profiles be the default settings for your mms, do thes steps...
select settings
select phone applications
select messages
select multimedia
from multimedia menu, select profiles
assign the mms profiles you created for your multimedia.
press save and exit the setup...
now to check if it's working, try sending a multimedia message to your own number to check if your phone can send and receive mms. once you successfully send it and received it, it means that your phone mms is already set and working...
take care..
Usually, mms has settings like gprs. Therefore these settings needs to be set on your phone by your Internet service provider, on request.
In my country, mms and gprs phone setting are usually sent automatically by internet service providers immediately you insert your sim card into a phone that has mms & gprs. And these internet service providers are also the network providers.
For instance, if your network provider is Zain, MMS & GPRS settings must be from Zain because that's the network you are using. These settings are as follows: IP Adress (eg. 172.018.254.005), homepage (e.g wap.uk.zain.com), port (1902) and so on....
So check if the above are intact on your phone as this is the only thing that can make your mms work.
Go to message, under message, look out for mms settings and you will see what I am talking about.
Joshua_ept - If you mean that the connection info hasn't been set on the phone, you need to contact your service provider, they will be able to send you a text that will fill in the settings for you.
Houndslow61 - Eh? Do you mean you CAN'T recieve MMS?
Also puzzled.
The settings are all different, Internet, Wap etc... for MMS you need to call your service provider and ask them to send you the MMS settings, they are sent via a txt msg, when you receive them click Save or Install.
MMS doesn't work between all networks.
