Question about Amana AER5515QA Electric Kitchen Range
Oven will not heat past 220 degrees
My electric Amana range (AER5515QA) will clean and broil, but will not bake. When we set the bake to 400 degrees it will heat to 220 and stop there. Any ideas? The range is 2 years old. Thanks, Jon Z
  • Anonymous Aug 25, 2008
    Oven will not heat past 220 degrees though the control is set to 400 degrees.
Check your bake element, I had the exact same problem and found the bake element had burned in half. The broil element comes on during preheat and kicks off at around 220 degrees.
Posted on Dec 01, 2008
SOURCE:
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Bake element burned out on my Jenn-Air SVE47100 Slide-In Electric Kitchen .I replaced it but oven does not heat ,when i turn oven on and check each terminal of bake element (and broil element)from ground i...
HI,
You should have 120 to the element when not in bake mode, while in bake mode you should have 220 - 240 volt. Sounds like you lost a relay to send the additional power to the element, or you have a High Limit thermostat which could be open. This is a safety device to protect the unit from over heating, this only goes if temperatures increase higher the safety levels, normally set about 200 degrees or so along the air flow channels. I would trace from the elements to the clock and find the missing source of current.
I hope this helps
Be safe with electricity......
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 26, 2011 | Jenn-Air SVE47100 Slide-In Electric...
When set to bake oven does not preheat and tempature does not increase. when set to broil oven heats
Since your oven has a separate element for bake and broil I would bet the bake element is burnt out or burnt electrical connection to the element. Make sure you disconnect all power to the range before checking.
Mar 21, 2010 | Amana AER5844VAD / AER5844VAB / AER5844VAW...
Hi, We have an Amana AER5845QAF electric range and over the last year it has been behaving strangely. At random times it will beep and the bake light will be flashing so we have to push CANCEL to stop the...
Hi Tom. Salesmen love the phrase 'self-clean'. As a Tech I came to know this function as 'self-destruct'. The entire oven locks down so that owners cannot release air inside the oven that reaches 700-800 degrees during this 3hr. cycle. The control board routes max current through its circuits for most of this time, and over repeated cycles, causes eventual failure in almost all boards. Symptoms and errors vary- consistent with multiple failures of either resistors at power junctions, or internal processor errors that accompany heat related damage. FIRST- disconnect power and check resistance for elements- broil/bake/conv. If all have resistance and are not OPEN, control is probably bad. Control part # AP4422522 Whirlpool available for $157.52 or so thru local or on line parts. Installation is not difficult......power Off..... Advice- drip pans, aluminum foil, if boil over is possible---protect from contact with bottom of oven. Avoid using 'self-clean' by preventing or minimizing spills. Hope this helps- Thanks- ED
Feb 25, 2010 | Kitchen Ranges
I am attempting to pre-heat oven to 400 degrees but oven heat will not raise above 100 degrees
Hi, Upon reading your post I immediately thought of a bad ignitor for the oven, but I am not sure whether you have a gas oven or a conventional electric range. So...If it is gas, I'd suggest replacing the ignitor for the hot surface ignition. If it's electric the bake element may be at fault although most range's use the broil in the preheat, so it should still climb up to 400, it would just take a really long time. Maybe you can clarify if it's electric or gas and I can try to move you forward from there. Macmarkus :)
Dec 09, 2009 | GE Ovens
Oven not baking
1. Check that the bake/broil elements are ok. Do they glow red when cycled on?
2. Control board may have failed. We see this as a common failure. We repair control boards at www.fixyourboard.com
Oct 08, 2009 | Amana AER5515QA Electric Kitchen Range
Amana Range, AER5515QAW
could be a bad bake element, bad temperature sensor, or control board problem
what does the oven readout display for temperature? if the readout agrees with the actual oven temperature ... it is probably the element
if the oven readout displays a much higher temperature it may be the temperature sensor (the probe in the oven cavity) or the control board
the temperature sensor can be tested by measuring its resistance with power off and unplugged from the control board, should be about 1100 ohms at 75F
If the sensor is good, then it is probably the control board ... in which case we can repair it for you at www.fixyourboard.com
Jul 20, 2009 | Amana AER5515QA Electric Kitchen Range
Maytag oven overbakes or burns bottom of cookies, biscuits
Try this first, if the temperature is off contact me.
Put an oven thermometer at the center of the oven and set the oven to 350 degrees F.
Check the temperature indicated on the thermometer after 20 minutes. If it's not within 5 degrees of 350, you'll need to adjust the oven's temperature control.
Apr 25, 2009 | Amana AER5515QA Electric Kitchen Range
HEATS OVEN VERY SLOWLY
Check that both elements are working, and that there is 240 VAC being supplied to the oven (one of the two breakers has not tripped, or one of the two fuses has not blown.).
Jan 24, 2009 | Amana AER5515QA Electric Kitchen Range
Oven bake does not work properly
check the selector swich and thermostat.
Dec 07, 2008 | Amana AER5515QA Electric Kitchen Range
Amana AER5515QA Electric Kitchen Range Logo
561 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Paul Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
