Question about RCA DRC8335
Unit unresponsive - see detail below
DRc8335 says hello, wont eject tape, wont shut turn on or off with button on unit. I held down the button on the unit - no change. I unplugged the unit - no change. I put fresh batteries in the remote. No change.
Thanks to the help on this forum, I was able to fix my DRC8335 power supply. C226 was the problem, went to Radio Shack and found the 470uf 35V replacement. It came up and worked like a charm after soldering it in. (See the picture of the cap on the board). It was just slightly swollen when viewed from the top but when i removed it, the bottom was really distorted. Thanks to micro065 and Mike PowellUnit unresponsive - see detail below - ebbca66.jpg
Posted on Feb 22, 2009
  • dvickery926 Feb 22, 2009
    Thanks to Mike Adams not Powell, sorry. Mike Adams is a FixYa Expert.
Hi, I had this exact same problem and got i bit lucky. All I did was took the cover off and removed the power supply board. Then I looked carefully at all of the components and found three bad capasitors. They were swelled. I replaced them and tested it to fully function. The caps I replaced were one 470uf 16v and the other two were 220uf 16v. I hope this will help you repair yours as well.
Posted on Jan 14, 2009
My Sony TC WR 535 wont open doors, one cassette in deck B,lights blinked in display panel then unit shut down, not been able to turn it on since
Remove the cover after unplugging AC. Look for a plastic stop that keeps the eject button from going in farther. Move the plastic stop peice downward and the buttom will then move in all the way and tape will eject. On mine the plastic piece is white and rotates down.
Feb 18, 2012 | Sony TC-WR565RM Single Cassette Deck
A cassette has jammed inside my vcr machine. It will not move forward or backward Can yoy please help
Since the tape won't come out then it means you will have to manually remove the stuck tape. This involves you disassembling the unit in order to help/assist the player get the stuck tape out.
Turn of the unit and remove from the wall, get a Philip screw driver, use it to remove all the screws from the unit and take it apart.
Open the cover and you will see the stuck tape and what's hooking or preventing it from coming out/ejecting.
Now plug the unit, and turn it on. Press the eject button, as the tape tries to come out, support it with your hand so that it can come out.
Or if it happen that the cassette tape has coiled inside the unit, carefully free the coiled tape and the press the eject button.
Lastly, the moment you disassemble the player, you would see what's preventing it from coming out, then you can free whatsoever that is making it stuck press the eject button and the tape should come out.
Make sure the unit is turned off each time you want to remove what's making the cassette stuck.
I hope understand the above explanations.
Good luck.
Mar 04, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
RCA DRC8312 DVD/VCR player is stuck on Hello
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20 minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Nov 13, 2008 | RCA DRC8335
Sampo DVE-611 apparently powers up from front panel switch (w/red light) LCD display, etc. No other buttons work, incl. eject. Remote completely unresponsive. Unit shuts down about 10 sec. later. Anyone...
After several power ups, the front panel buttons eventually "woke up". Replaced remote, and everything's working fine. Not sure why the front panel was temporarily unresponsive.
Jul 16, 2008 | Sampo Televison & Video
VHS Tape stuck and won't eject
you going to have to open it up and remove the tape manually, either the belt drive is broken or gears are.
you going to have to get your hands dirty. :)
Jun 25, 2008 | RCA DRC8335
Eject
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To manually remove the tape from the Canon ES900 video camera do the following after reading all below.
1. Remove the two small screws from the tape door face. I show the entire carriage removed.
2. Look for the small metal peg on the left side, about 1” down from the top of the tape carriage.
3. Using something small push down on the peg to release the tape door.
4. Important Note: Most likely the tape will still be wrapped around the video head and held there by two capstans, (one on each side of the head)
5. Carefully pull out the tape not damage it any more than necessary. Keep in mind this might cause the player to “eat” the tape at this area so smooth the tape here with your fingers (nothing metal) and wind the tape to begin playing past this area if possible.
It seems this is a common problem with this unit; Canon should have put a better motor here in this critical area.
Good luck, hope this helps everyone,
Apr 21, 2007 | Canon ES900 Camcorder
RCA DRC8335 Logo
560 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
