Question about Kitchen Ranges
Right front burner won't burn. Oven will not ignite.
1. You can hear the igniter ticking when turning on the valve but the burner will not ignite. Doesn't appear to be getting gas.
2. The oven started out burning at a higher temprature than the setting. (i.e. 200 burns at 350). Oven currently will not ignite.
  • ced_t28_ethe Jan 01, 2009
    My oven would not reach the appropiate temperature. A tech recommended an igniter replacement. However, the igniter glows but will not light the oven.
  • 135 Answers
Try lighting it with a bbq lighter. If no gas, then replace the valve. If it lights, replace the igniter. Hope this helps!
Posted on Jan 01, 2009
JDS9860AAP Front e-burner does not light.
follow this instructions. God bless you
    • 1
      Unplug your unit and turn off the gas supply at the saddle valve near the unit.
    • 2
      Lift up the hood of the oven. If you have sealed burners, the lid will not lift up. Locate the ignitors near the burners of the unit. Clean any gunk away from the ignitor using a toothbrush. Test the unit.
    • Sponsored Links
    • 3
      Pull the burner dials off the front of the unit if the ignitors won't work.
    • 4
      Remove the screws at the ends of the front cover, where the gas supply knobs are located, using a screwdriver, and remove the cover from the oven.
    • 5
      Slide the wires off the burner valve switches and pull them off the burner valve by sliding the switch forward. The switch will have wires attached to it. Loosen the screws holding down the wires of the burner valve. Pull out the wires carefully. Place the wires in a new switch. Slide the new switch onto the burner valve. Replace the knob, and turn on the gas supply and power. Ignite the burner.
    • 6
      Follow the switch wires into the oven if the new switch doesn't work. Locate the module box, which is usually 2 inches by 3 inches. Slide the wires out of the module terminal by pulling on the wire connectors. Remove the screws from the old module and pull the module out. Insert the wires into the new module, using the same wire orientation as before. Reassemble the oven. Turn on the electricity and gas, and turn on the burner.
Read more: http://www.ehow.com/how_7925141_repair-electronic-ignition-gas-stove.html#ixzz2ZPuc5nad
Jul 18, 2013 | Kitchen Ranges
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
My Electrolux Eog6330xn oven cuts out after about an hour and the ignighter then constantly sparks. the oven then has to be turned off to cool down before it will relight. Any advice.
Hello there Gary and welcome to FIXYA
Usually when an oven won't bake properly or stops baking , it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself. The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame. I would disconnect the power to the oven then unplug the wiring assy and remove the part then clean all of the terminals really good then reassemble it then try the oven again if it still does not work properly i would go ahead and replace that part ok
Please keep me posted on how this is going i can give you more help but this is the most common problem ok?
Best regards Mike
Nov 07, 2011 | Electrolux EOG6330 Gas Single Oven
The oven will not light when turned on.
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective gas valve coils
Dec 22, 2009 | Imperial IR-6-C Elite Gas Kitchen Range
Ignitor lights up and I can smell and hear the gas, but the oven will not light
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
Nov 13, 2009 | GE Ovens
My indersitt cooker wont stay lit once i have lit the oven with a lighter what do i need to do plz
-- defective thermostat(located inside the top section of the unit)
-- defective selector switch(mounted on the front control, or part of the touch pad assembly)
-- defective gas safety valve(mounted on the valve assembly)
-- defective gas valve coils(mounted on the valve assembly)
Nov 05, 2009 | Kitchen Ranges
My kenmore gas oven won't heat. I turn to dial to temp i want can smell gas building up in oven and can see a glow in bottom of oven but will not ignite. Sometimes if I turn on a cooking eye I can then...
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
Oct 22, 2009 | Whirlpool SB160PEE Gas Single Oven
Oven will not light
Oct 16, 2009 | Magic Chef 31000 Gas Kitchen Range
Oven wont light
-- defective gas valve coils(This will be the next possible issue if the igniter is functional)
Sep 26, 2009 | Frigidaire Ovens
The gas oven will not light. gas burners light but oven does not
O-defective thermostat
O-defective selector switch
O-defective gas safety valve
O-defective gas valve coils
Sep 20, 2009 | Ovens
Kitchen Ranges Logo
153 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
