Question about Refrigerators
Roper Refrigerator, top freezer leaking water into refrigerator
HI
On my roper, in the fridge there is water leaking in from the ceiling (base of the top freezer). Seems to happen only at night. I currently have bowls on the top shelf to catch the water. I do not have an ice maker. How do I find the freezer plug to see if that is clogged?
My Kenmore leaks water from the ceiling inside the fridge. Any idea what causes this?
  • crsperos Mar 08, 2009
    Indeed, I have the same problem. I now find water under the two crisper drawers as well as on the top shelf of my refrigerator. I tried turning the whole thing off over night to see if it would thaw itself. After two days the leaks began again.
  • 135 Answers
This is usually caused by a plugged freezer drain. The back wall (or floor) of the freezer may come out to access the drain. Clear out anything visible and run a stiff wire thru it. Test with a cup of water. Hope this helps!
Posted on Jan 01, 2009
Look aty the back of the freezer and at the bottom there will be ice. The Freezer drain is clogged. Usually Iced up becaust the defrost heater coil is weak or shutting off too soon. Clear out the freezer and heat up all around the bottom of the back plate. Take off the back and disconnect the wires for the ice maker if you have one. Disconnect and shut off the ice maker line. Actually shut it off first.
Using the hair drier heat up the drain and make sure it is clear for several inches down. Take a copper wire about 12 inches and make a small loop to go over the heater wire and then the rest goes straight down the drain. Now when the heater coi is on a small amount of heat will go down the wire and keep ice from the drain.
Now just reassemble the ice maker and back putting all wires whaer they go.
Posted on Oct 13, 2011
  • hcphillips
    hcphillips Mar 14, 2013
    Thanks Don ! instructions were just the ticket ! I liked the idea of putting the piece of copper down the drain pipe .
  • hcphillips
    Thanks Don ! info worked like a charm.
Where do I find the drain I have water leaking into my refridgerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
Roper Refrigerator. No ice maker. Freezer on top. Water pooling in refrigerator. keep refrigerator in garage.
heatman101
Jun 20, 2011 | Roper Refrigerators
Roper top freezer works but not the bottom
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 16, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Refrigerator cold ice on ceiling no air to refrigerator and its warm the fan not turning
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 19, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Freezer leaking into fridge
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jan 21, 2010 | Roper RT14DKX Top Freezer Refrigerator
Water in refrigerator
Defrost drain under evaporator in freezer. Inside back wall of freezer has to be removed to access drain
Oct 05, 2017 | Roper RT21AKXKQ Top Freezer Refrigerator
Hi I reckon you gave either an ice block in the defrost drain system or a blockage caused by loose food bits. You can clear the ice block if you keep the fridge off for 24 hours leaving both doors open. If you have a small table fan to circulate warm room air you could speed up the process.
The second type of block with food bits may need you to open the internal rear panel of the fridge and push through a stiff wire to clear the blockage.
Jul 15, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Refrigerators Logo
1,946 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
