Question about JVC AV-32F476 32 in. Television
Can't play dvd player on JVC tv; I don't have a JVC remote.
I have an older 32 inch JVC tv (not a flat panel). I can't figure out how to connect it to a Phillips dvd player. When I plug the connectors in, it will not play. I do not have the JVC remote, so I can't figure out how to switch from tv mode to dvd or external device mode. Can you help me?
I hooked up a Pioneer DVD player to my TV and when I play a DVD the volume cannot be controlled by the TV. It just plays at one level and on the louder side. When I'm watching regular TV and the DVD player is on and playing a disc I start to hear the DVD soundtrack at the same time as the whatever I'm watching on TV. I should not be able to hear anything until I switch over to Video 1. Any suggestions?
Posted on Sep 04, 2009
    Problem Solver:
  • 7 Answers
You can change the input for your TV by way of the menu button on the front panel on the TV, instead of using the remote control. Per the owners manual, please read below:
You can also access the input menu screen by using the MENU button on the front of the TV
instead of the remote control. It appears between INITIAL SETUP and PICTURE ADJUST
screen. Choose the INPUT by pressing MENU button on the front panel and select TV or VIDEO
INPUT by using the CHANNEL +/- buttons ( <- -> OPERATE )
Choose the input that the DVD player is connected to.
Posted on Dec 31, 2008
I need a power cord...where can I get one?
Something like this. Make sure you order the right plug and make sure yours has a figure 8 connector to the back of your television.
UpBright NEW AC Power Cord Cable Plug For RCA 22 26 32 40 42 inch Series...
Jan 01, 2016 | Iview International 22 inch LED TV with...
White space above and below picture
Thirteen Retailers Recall 32" Coby Flat Screen Televisions ...
www.cpsc.gov/.../Thirteen-Re...
U.S. Consumer Product Safety CommissionDec 12, 2013 - This recall involves black Coby 32-inch flat screen televisions with model number ... AmTRAN Video Recalls to Repair 42-Inch JVC Flat Panel ...Missing: space
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the ... Just match up the sticker, and also add a space and n8lk, then search on amazon. .... LCD & LED TV Repair - No Image & BlankBlack Screen Flashlight Test ...
Coby DVD-209 Ultra Compact DVD Player Troubleshooting ...
https://www.ifixit.com/.../Coby_DVD-209_Ultra_Compact_DVD_P...
iFixitNot Compatible With Coby DVD Player; Disc Types Compatible; Problem Message Displayed On Screen. "WRONG ... Follow the repair guide to replace the fuse inside the device. ... The same goes for the white and yellow plugs and ports.Missing: space
Top 139 Complaints and Reviews about Coby Electronics
www.consumeraffairs.com > Electronics > Televisions
Dec 21, 2015 | Coby TFDVD2284 22 LCD TV
Jvc 32dm22 tv pc mode not supported
not compatible format or the resolution of the tv not enough to recognized the pc.
Oct 27, 2012 | JVC LT32DM22 32 inch LCD TV with builtin...
How do i hook my dvd player to my jvc 32 inch flat screen tv
U might be putting them in the wrong places or the wrong channel try and go through the channels but make sure they are hooked up right cause it will mess the TV up I did it on time and had to go get me another one cause I messed the sound up Hope this helps ya
Feb 20, 2012 | Televison & Video
How can I connect my dvd player to a Philips 32PFL5605H/05 32-inch Widescreen Full HD LED TV ? It is of the type which has one red, one yellow, and one white connector but i do not see any sockets that...
The included cable with the red, yellow and white RCA connectors is a composite A/V cable. To connect this cable to the TV, you need a SCART-cinch adapter. Then use one of the SCART connections on the TV. Note: the SCART connection does not handle HD signal.
You will get a much better picture if you buy a different cable. Depending on your DVD player, get either an HDMI cable or a pair of cables - a component video and audio cable. (Both component and the audio cable will have RCA plugs at each end. The component video has 3 plugs - red, blue and green. The audio will have 2 plugs - white and red.) Both of these will carry HD signals. Most DVD players will have at least component video and composite video jacks; some have the HDMI output. Most DVD/VCR combinations will need the composite video for the VCR and the component video is optional for the DVD signal.
I hope this helps.
Dec 24, 2010 | Philips Televison & Video
I connected dvd player to dynex 32 inch tv. what
You should be connected to the AV input 1 slot. Change the input on the TV to Input 1
Jan 17, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Dvd picture is darker than tv picture
Most sets have electronic service adjustments. Contact manufacture for nearest service center.
Mar 06, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Need to find out if older model phillips tv is dvd compatilbe?
If you dont have rca jacks on tv then you will need to get a converter bob with rca jacks in and anti out to tv or youcould try using your vcr with the rca jacks on it and put rca cable from dvd out to rca vido in and audio in then hook up your anti cable out to anti in on tv.should work cam corders do.
Mar 05, 2009 | Philips Televison & Video
Connecting COX DVR and Phillips DVD to Vizio HD TV
we connected the cable box to the coax connector while our philips dvd went into the HDMI1 connector, and we got both working fine and dandy
Jan 10, 2009 | Vizio L32 32 in. LCD HDTV
Tv-dvd connections
first what model samsung? second if the tv has yellow red white then you need to change the tv to the input you are using. for best picture I would use an s-video cable it will give you superior video images since I don't know what brand dvd player I only say this if you have an output on the dvd player
most important is to make sure the tv is on what input you have plugged in. and dont forget to power up both units.
Apr 27, 2008 | Televison & Video
JVC AV-32F476 32 in. Television Logo
1,142 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
