Wide screen 21 inch KDS monitor
I can't seem to get the right resolution in the windows settings I have tried many changes but the images are still too short or sometimes with a different resolution tey are too skinny ?
  • shadyuk Jan 02, 2009
    Changed the resolution several times none helped , Thanks for trying!
  • 142 Answers
It shouldnt be a problem with the monitor, but with the computer. Unless adjusting the resolution solves the problem, im not sure what to do. Sorry, hopefully that helps.
Posted on Jan 02, 2009
To widen border on Toshiba lap top
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.If you cannot change the screen resolution then most likely the incorrect video driver has been installed.
Mar 30, 2012 | Computers & Internet
The images on the monitor are stretched lateraly
Depending upon the screen resolution that has been set in Display, the image will be distorted on these wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down the Shift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolution slider, increase or decrease the screen resolution then bring the circle image to the front and check the image, if the circle is still distorted then change the screen resolution and check the circle again until you are satisfied with the image of the circle. When you are satisfied then click apply.
Feb 24, 2011 | LG W2053TQPF 20 inch Monitor
My computer dekstop theme is small and this synchronize
Are you saying that your resolution on your screen is small?
Try Right Clicking on the desktop and choosing properties. Then click on the settings tab on the right and this will show you the resolution of your monitor.
http://www.desksite.com/faq/DPI-Settings/images/XP-display_properties.jpg
That is what it should look like. The screen resolution shown here is for wide screen monitors.
Try changing the resolution by sliding the bar across to the left that will make everything look bigger.
Try a few and see which you think is best.
Thanks
Oct 07, 2010 | Microsoft Windows XP Professional SP2
Pop up of monitor adjust screen
Hi, you probably have to set the correct resolution that fits on your monitor. The correct resolution is: 1920x1200 You can set it by right-clicking on your desktop and choosing "Screen Resolution" in Windows Vista and Windows 7. If you use Windows XP, right-click on your desktop and choose "Properties" Then open the rightmost tab to choose the resolution
Jul 19, 2010 | CTL 261UW 26Inch Wide Screen LCD Monitor...
I have a wide screen Dell 21'' flatscreen lcd monitor....all my screens are stretched and photos do not look right.
change the resolution from the desktop properties(right click on desktop ..choose properties than settings ...in there you will find resolution ...setting ..change them one by one untill you get to one that fits...probably will be the last one in the right ..the largest if it is a wide screen on 21 inch ..
Jun 27, 2010 | Dell P1110 21" CRT Monitor
Acer wide screen monitor 20'' font and images all
Right click on the desktop in a clear area and scroll down to either resolution or properties. From this you can experiment with resolution settings to see which setting best fits your display. After each setting change the computer will ask you if you want to accept the changes, it will give you 15 seconds for each change.
Jun 26, 2010 | Acer AL2016W 20" LCD Monitor
I cant fit the whole image on the screen. The options to adjust only allow me to adjust the width...it wont let me show both the top of my windows open AND the start button.
Your resolution may be set to high on the computer. Or you have a standard screen resolution set and since the monitor is a wide screen, it is cutting it off.
Try a different resolution 1440x900 is what the va1930wm uses.
If using a laptop with a standard type screen on it, you may have to set the laptop to just light the monitor to allow this setting to take.
Since this monitor is a wide screen, it may have options in the menu to stretch or zoom on an image if the resolution is not set to a wide screen format.
Dec 03, 2009 | ViewSonic VA1930WM LCD Monitor
Screen image unstable
Sounds like your screen is set too big for your PC... it may just be a settings issue in your display properties. Right click on your desktop and go to properties, check in there and change resolution and things.
Doesn't seem like bad hardware.. just seems like a software setting is set improperly.
sorry i can;t be more help.
Sep 15, 2009 | Formac ProNitron 21/800 21 inch CRT...
I have a dell with windows vista. the monitor is 20 or 21 inches wide screen. I recently had a friend try to install windows xp but at the last attempt he tried to reformat my computer & install it xp...
You can adjust the screen resolution to increase the size of the image to fill the screen.
Go to the Control Panel - Display - Settings and adjust the screen resolution to 1280 X 1200 pixels. If this still doesn't fill the screen then increase it further say 1600 X 1200 pixels even higher if necessary.
Aug 19, 2009 | Dell Computers & Internet
Wide screen images lookshort and fat
Native resolution for a 17" widescreen TFT is ;
1280 x 800
Try that.
(The 1440 x 900 is for a 19" widescreen)
Dec 31, 2008 | KDS K717s 17" LCD Monitor
Computers & Internet Logo
374 people viewed this question
David Payne
David Payne
