SOURCE: insignia DVD player NOT WORKING
Hey jgconstable,
Before seeking repair assistance, there are a couple of options that you may wish to try out at home.
First, you may want to try cleaning any affected discs if you are only encountering this problem with a select few titles. Any kind of contaminant (dirt or lint) can often cause optical devices to not recognize a media title that is inserted. I would suggest checking each disc that is affected for any signs of scratches, and try cleaning them with a soft, lint-free (typically microfiber) cloth. Remember to use gentle, outward strokes from the center of the disc towards the outer edge.
Second, you may want to try cleaning the lens of the player itself. Many retailers (including your local Best Buy™ store) often sell commercial cleaning kits that are designed to be inserted directly into the player, in place of a normal CD or DVD.
If cleaning doesn't resolve the problem, you may wish to attempt resetting the player. Many DVD players will have either a physical reset button located someplace on the exterior casing, or be capable of a "soft reset." A soft reset is typically done by pressing and holding the power button for five to ten seconds, but please keep in mind that your owner's manual would have the most detailed information on how to reset the player to the original factory settings.
Should the player continue you malfunction, remember that you can always bring your DVD player into your local Best Buy™ store for service and repairs.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
SOURCE: insignia portable player NS-8PDVDA not working
Here's how I've solved same symptoms with our NS -PDVD8a:
1. Cleaned laser optics with isopropyl alcohol/swap --make sure you let the optics dry/IPA evaporate from the optics before running
2. Using compressed air can--cleaned laser track
3. Gently move laser along track several times - it seems laser is having most trouble at start of disc -- not sure it needs lubrication, but running it along track several times seems to have righted it
Had to do this a couple of times, but it's working now -- expect I will need to do this again -- no idea how long fix will work.
SOURCE: previously recorded disks and new disks all-dirty disk rejection
you may need to go thru the cleaning process a couple of times since it has never been cleaned ,but I'm glad there is a for sure improvement
that was my thinking about the laser lens cleaning disc , I have helped alot of people with thier player as well because they to did not know of the disc either. they do not advertise it enough for people to always hear about it or include the cleaning process and recommendations(maybe because they want you to buy a new one is about right!)
sometimes they get so dirty the laser lens has to be cleaned manually ( with a q - tip and the disc solution )
if you have anymore questions don't hesitate to ask
electech1
SOURCE: ripspeed in car dvd player
I had a similar problem with mine I have just had a technical fault with mine and the only solution i could find was through halfords. If its under warranty they send it off to their supplier AEL to solve. If its no longer under warranty like mine, they send it off at an initial £60 cost which could escalate if the problem is larger.
SOURCE: Can this be fixed?
i have an audiovox dvd player model D1718 . i put the disc in and it says it is loading but then comes up no disc . how can i fix this problem?
