Question about V, Inc. Vizio P50HD Plasma Television
No picture my picture went out ,the green light goes on but i get no picture
  • rmewifey Feb 24, 2009
    same problem. Called vizio technician and he said it sounded like a back light still waiting to get it fixed
  • Anonymous May 05, 2009
    Heard 3 loud 'pops' while watching my Vizio, then screen went dark power shut off. Turned it back on, got sound no picture. What happened?
    New Friend:
  • 56 Answers
Y Sustain board is bad. Replace the board will fix it. If you have bought the TV from Costco, then give them a call. Because the TV may still under warranty. I have repair a lot of P50 model lately and all of them still under warranty.
Posted on May 12, 2009
The screen went blank and green light started flashing. Turned off the TV and let it cool. Turned it back on, getting sound but no picture. Red light is on, after about 15 seconds the green light blinks...
Since you say that there is sound but no picture, the first thing I would check would be the status of the lamp. I believe that the lamp has been shattered or the filament is blown. Please verify this and let me know
Feb 25, 2011 | Toshiba 52HM95 52" HDTV Projection...
Bestec atx 250 12z Power Supply - Community power went off today - machine was on when power went off, but now will not turn back on. Now Green light is flashing on back of power supply. Light...
Outages are frequenly accompanied by power surges. It sounds like your power supply got cooked and does not produce enough power to start your computer anymore.
They are inexpensive and are easily replaced. Take a couple of digital pictures of it in your case and then remove it.
Measure the dimensions and go find an ATX power supply that will fit. I recommend that you go up to at least 350 watts. Use your pictures to help you install the new power supply.
If this helps please vote for my solution.
Sep 21, 2010 | Computers & Internet
No picture, power light flashes green. I was watching tv when the picture went out and the power light started flashing green. The temp light did not light up.
If you take the back cover off (and part of the front) you should be able to the cage that holds the lamp. Above that there is a small thermal fuse that occasionally goes out and causes this problem. Quick solution is to repalce with a normal 5amp fuse. Just clip it out and solder the new one in. I would use a pico fuse. Or invest in a replacement thermal fuse from a part store. Part number K5C117BC0003. Goodluck.
Jul 05, 2010 | Panasonic PT-45LC12 45" Rear Projection...
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
When I turn the power on the the green light flashes, the set attempts to turn on,goes off,green light goes on attempts to turn on and goes off. This is a 36 inch picture in picture, about the first year...
You most likely have a horizontal and/or a high voltage issue. These sets are famous for this problem. If the picture was still good before it went out, it is probably worth getting checked out. Thanks
Oct 28, 2009 | Proscan PS36700 36" TV
SONY TV PICTURE TURN GREEN WITHOUT RETRACE
Picture goes to high green with retrace lines that shows picture tube is defective and requires replacement.
Usually in above symptom, TV goes to standby mode and standby light blinks when green raster problem occurred.
New TV is better option because picture tube of KV-34XBR960 would not be available any more.
Thanks.
Aug 14, 2009 | Sony Televison & Video
My tv turns on but no picture or sound
power pack capacitors have failed they will need to be replaced with new ones and that should repair the tv, soldering skill is required to do this or replacement of the entire power pack.
hope this helps
Apr 07, 2009 | Samsung Televison & Video
Picture gone
Is the set completly dead...does the green light flash then go off. or when you plug it up does it come on for a moment?
Jan 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
TV turns on then off no picture
I was watching my tv and it just automatically turn off, everytime since then i turn it on it goes off in seconds without picture or sound comes.
Mar 20, 2006 | RCA D52W19 52" Rear Projection Television
V, Inc. Vizio P50HD Plasma Television Logo
753 people viewed this question
Top V, Inc. Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
rostit
Are you a V, Inc. Televison and Video Expert? Answer questions, earn points and help others
