Question about ViewSonic N3251w 32 in. LCD HDTV
My mointor turned purple
I want to turn my monitor on about 20 mins ago to play my xbox360 and my screen turn purple help
  • Anonymous Apr 15, 2009
    nothing happens... still purple... any solution?
Now this may or may not work for you.
I think I had the same problem today, I just turned on my PC and the letters and startup screens were purple all of the sudden when the day before they were just fine. Well this is what I did to fix it.
Your Monitor should have some buttons below the screen. You want to press the button that says
"Menu". Once on the Menu screen use the up & down buttons on the monitor to scroll through the menus. What you are looking for is a "Reset" option once you find that choose to reset the Monitor and all the colors should go back to normal.
I am sorry if it is hard to understand, I did my best to explain it. I just hope this helps
Good Luck
Wolf26pack
Posted on Mar 08, 2009
Screen Turn's on.You seen Acer load up Splash Screen for less then a min, Stay on until Windows Xp Load up screen then goes into sleep mode. Encontered same problem when I connected Xbox360 with HDMI to...
  • Hello chaleebradsh, the "Monitor" as well the Computer have "Power Saving Modes," [Sleep, ScreenSavers, and Hibernation]; so what you want to do is "Change the way the Computer / Monitor Sleeps!" From the Desktop Screen, click on the "Start Button," next in the [Start Search Window], type: power. In the next [window] that opens, you should see, from your point of view; a "list" in the (left column) "Change when the computer sleep, the wording may be different, but it will be clear enough. Now all you have to do is change the way the Computer and Monitor "Sleep, or Turn-off." If the Monitor have its own "settings;" just find them by the [button on the monitor], and do the same thing as above; but I'm sure the computer will take care of both. "I hope this information is of help; thanks for using FixYa, paul7of9"
Jan 31, 2011 | Acer AL1717 17" LCD Monitor
Whenever I turn it on, it has a red light on the bottom right of the console. The screen says E-74 Error. I was reading how to fix it, some suggested its the A/V Cable. I tried to blow any dust off, and...
simple fix my friend mine broke today was going to play a game and message came up. simply take about 2 towels wrap your xbox up with no games or hard drive in but keep the power supply and av cable in. let it sit for about 20 mins until the bottom red light goes away and 2 red lights appear on the left side. then unwrap it and wait 10 mins turn on it should work hope this helps!
Nov 26, 2009 | Microsoft Xbox 360 Console
Dell 22' monitor Black screen Green light stays on.
well i have a dell 22'' monitor and it did exactly the same thing , turns out its a fault with the invertor drive transistors ( these power the fluro screen light ) , i'm in the uk , but i would take it straight back to walmart along with proof of purchase and tell them it dont work and ask for a repair /replacement under warranty
Nov 17, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
Red light is flashing when i turn the console on
that is the same thing that happened to mine call customer care center and send it in....
Oct 27, 2009 | Microsoft Xbox 360 Console
My samsung monitor syncmaster 743nx is not turning on..plss help me...tnx
How to troubleshoot a Samsung SyncMaster 743NX LCD Monitor? My Samsung SyncMaster 743NX monitor turns on slowly. I mean,last week when I started up my pc,it took 5-10 mins before my monitor displayed anything. I know the pc is already turned on because I've already heard the Windows Vista start up tune play. The problem is now getting worse as it now takes 20-30 mins before my monitor displays anything. Please help.
Mar 11, 2009 | Computers & Internet
Dell flat panel monitor -power button blinks green to amber - no
One reason that this is happening could be that it is on Power saving mode. This happens when the LCD monitor detecs an incorrect timing then thats the time that the LCD goes blank and the power botton starts to blink.
what you need to do is to turn the computer off. Unplug cables attach to the LCD make sure it is also off, once done press the power botton for a couple of 30secs to a minute and then release. After doing so re-connect all the cables and make sure that both ends is tight and secure once everything is ok turn the computer on same with the monitor to check if it solves the problem.
Jan 10, 2009 | Dell Dimension 2400 PC Desktop
Help
There are solder issues, so something to try is just leave the xbox on for an hour, turn off let cool for 5 min. If that doesn't work, it's a difficult solution to recommend but the towel trick' does work, let it over heat the 360 for about 20 min, then let it cool for 20 more min, and it now works fine, I have a inner cooler now to keep from overheating again. Also don't take apart the xbox, if this doesn't work then just send it back to microsoft
Mar 25, 2008 | Microsoft Xbox 360 Console
Dell 1704 FPTt monitor goes black after about 20 min
Go to Start, Control Panel, Power Options and change your monitor setting to never turn off. If you do leave your monitor on all the time then you should set up a screen saver.
Dec 22, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Respectable Sir,
DOES TOSHIBA LOGO OR SCREENSAVER SHOW AS COMPUTER IS TURNED ON.
BETTER YET DO YOU HAVE ACESS TO ANOTHER MONiTOR FROM A DESK TOP IF SO CONNECT MOINTOR TO THE LAPTOPS EXTERNAL MONITOR CONNECTOR (BLUE IN COLOR) MOUNTED ON SIDE OF LAPTOP OR BACK IF VIDEO IS VISIBLE ON THIS new MONITOR YOU HAVE AN INTERNAL VIDEO DISPLAY connector PROBLEM or bad display
Nov 13, 2007 | Toshiba Qosmio G25-AV513 Notebook
ViewSonic N3251w 32 in. LCD HDTV Logo
570 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
