Question about Epson Stylus CX6400 All-In-One InkJet Printer
Where is usb port for usb cable in espon cx6400
Nmmmmmmmmmmmmmmmmmmmmmmmmm
    Genius:
  • 1,447 Answers
Hi
Open/lift the scanner glass. if you are facing the printer. look inside it on the left hand side there is a port for usb cable on that are.
Hope this help
Posted on Jan 01, 2009
  • glenns81832 Dec 01, 2010
    Look closely about four inches from the left end of the grey cover for an embossed symbol for the USB port. Lift the small cover segment to find the actual port.
I cannot print anything from my computer i got no disc drive for my espon stylus sx105
If the drivers are available for your printer and you have a generic OS driver installed, uninstall it then disconnect the data cable. The generic driver will install with Windows "plug and play".
Navigate to http://www.epson.co.uk/Home-and-Home-Office/Printers-All-in-Ones/Home-printing/Epson-Stylus-SX105/Drivers-Support;jsessionid=EDF17857D68DB083F3B38755B90282DC.acc5-new to download the drivers for supported OS versions. This download will not include any third-party software that is on the CD included with the printer. Install as Administrator for Vista and Win7 - make sure to use the correct version (64-bit if that is your OS). If your OS is compatible with the software on disc, external optical disc drives (DVD writers) can be obtained for $50 or less.
Make sure that the USB cable is fully connected when the software prompts you to connect it. Make sure the paper is in the tray and can be picked up by rollers. Insert all of the ink cartridges properly and make sure that the alignment process has finished. Are any error messages showing on the printer?
With USB printers, try a new cable and a different port. Try a direct connection if you have a print server or USB hub connected. For Windows, check the USB drivers and make sure the ports are not disabled for security or power savings. (The first is in the Device Manager; the second is part of the advanced settings from the Screen Saver.)
I hope this helps.
Nov 23, 2010 | Office Equipment & Supplies
There is no place to plug in the usb cable on this thing
Hello nancy_rob396, The USB Cable should insert into a square shaped plugin on the back left or right side. Feel free to reply if you have any further questions or please rate this solution if you found it helpful. Thank you! Edward
Aug 22, 2010 | Epson Stylus CX6400 All-In-One InkJet...
Directions how to install
USB is pretty bullet proof. Printer USB cable ... only one end will go into the printer, the other end can go into any available USB port.
Normally, the cable does not come with a new printer. Get one at the big box store or at a computer store or look at Kmart
I hope this helps you
Oct 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
I CAN NOT FIND MY USB PORT ON MY PRINTER I HAVE LOOKED
The USB end of the printer cable goes into the computer, the other end which is basically a square goes into the printer.
Jun 28, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Can not find usb port on the unit
Hello
You have to lift from the left and right handles on the sides of the printer, it will open it, and you will see the usb plug
Jun 27, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Just purchased a cx6400 can not find usb port on the unit
The rear, left hand side(as you look from the front) at the top, if it's like mine(dx 5400) it will be in a cut out, right on the corner( turn the cable 90 degrees to insert)
I purchased a Epson sty lus cx6400 second hand
Open the lid and look on the left hand side of the printer unit approx 4 inch's behind the on/off button, There is a usb connection.
May 09, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Epson CX6400. No display. no power. does the printer have an inline fuse?
1.) Unplug all cable connections ( power cable and usb cable ).
2.) Check if there's any obstructions inside the printer.
3.) While the printer is off and unplugged., press and hold the on button for 10 sec.., release after 10 sec. and connect power cable.
4.) Turn on the power.
Apr 06, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Reinstall epson stylus c66 drivers on vista
Scorpion9er,
Epson Notes That Your drivers are:
In-Box
= Drivers are included with Windows Vista. Just connect your Epson product to your computer and follow the on-screen instructions that Windows Vista displays to guide you through driver installation.
My spin on it:
Try unplugging the USB cable and plugging it back in with the printer on. Vista should rediscover the printer if its been removed, and is no longer in your device manager. If this seems to do nothing of use, try switching the USB cable to a different port on the computer.
Hope this helped,
Jem
Jan 04, 2009 | Epson Stylus C66 Inkjet Printer
Needing usb adaptor for espon r340 printer to inable us to go wireless
Here is the usb cable:
USB Type A Male / Type B Male Cable, 2.0 Version, 6 ft
or here
3ft USB 2.0 Printer/Device Cable A Male to B Male
If you additionally need to get morte USB plugs you can use an USB hub:
Micro Innovations Hub
Do not forget to rete the solution appropriately.
Many thanks.
Aug 29, 2008 | Epson Office Equipment & Supplies
Epson Stylus CX6400 All-In-One InkJet Printer Logo
355 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
