Question about Lands Phones
I have bout an idect twin q1i cordless telephone and i wish to no the registration number. or how do i register the phone?
Go to menu registration
select base
enter pin 0000
press ok
Posted on Mar 04, 2009
  • bane08987 Mar 04, 2009
    right
    go to menu registration
    select base
    enter pin 0000
    press ok
    now press the intercom button on the handset until the phone beeps
    it should take about 20 seconds
    it will now be registered to the base
    you must press the intercom button as quick as you can after pressing ok
    if it doesn't work first time keep trying
How to register the extra cordless handset of vtech 15250
Add and register a handset
Each newly purchased handset must be registered to the telephone base before use. When first purchased, each expansion handset shows NOT REGISTERED.
You may need to charge the phone first.
To register a handset:
    ·Place the unregistered handset in the telephone base or charger. Press Find for 4 seconds. If the headset screen doesn't light up after the 4 seconds. You will need to charge it some more.
    ·After making sure it is charged set the telephone on the main base again press and hold the Find button for 4 seconds ( until the red light IN USE comes on) Then release the find button. The headset will show PLEASE WAIT; this takes about 10 seconds to complete the registration. The hand set will show HEADSET REGISTERED and the headset number assigned, you will hear a beep when the registration is finished
    ·When the registration is complete, the newly registered handset is assigned the next available handset registration number. For instance, if you already have HANDSET 1 and HANDSET 2, the next registered handset is HANDSET 3.
    ·Makes sure no other headsets are in use at the time or the registration may fail.
    ·You cannot register a handset if any other system handset is in use. Only one handset can be registered at a time.
Aug 18, 2017 | Vtech Lands Phones
When I make a call my number is withheld why
CLI or calling line identifier is usually controlled by your carrier not by the telephone device. suggest to call your carrier /telephone line supplier and ask them to enable CLI
Feb 14, 2015 | Binatone Idect C5i Twin Digital Cordless...
Delete message idect answer phone
CONFIRM MEANS THAT IT CONFIRMS THE delete has happened.lol.
Oct 31, 2017 | Lands Phones
Kindly can u advice why my idect q1i is not rejistring at the base,also the pin no is not accepted how can i rest the pin no thank u
When registering dont forget to press and hold the paging button on the base station for around 10 seconds to put the base into registration mode. The PIN will be 0000 unless it has been changed, to reset without PIN: Hold Paging button, disconnect power (whilst holding Paging), reconnect power still holding paging button. Any further queries call the Helpline on 0845 345 9677.
Apr 03, 2011 | Lands Phones
On the screen of the phone says not registered and wont allow me to make phone calls or recieve
Please try the following procedure to register the handset:
  1. Place the unregistered handset in the telephone base. If PRESS FIND HS 4 SEC ON BASE does not appear on the handset screen after a few seconds, remove the handset and place it in the telephone base again.
  2. On the telephone base, press and hold FIND HANDSET for about four seconds (until the red IN USE light on the telephone base turns on) and then release the button. The handset shows PLEASE WAIT... and it takes up to 60 seconds to complete the registration. The handset shows HANDSET X REGISTERED (X represents the handset number assigned) and you hear a beep when the registration completes.
When the registration is complete, the newly registered handset is assigned the next available handset registration number. For instance, if you already have HANDSET 1 and HANDSET 2, the next registered handset will be HANDSET 3
Mar 05, 2011 | Vtech DECT 6.0 Digital Cordless Phone
Online user manual for a idect Q1i twin
There is a scan of the idect q1i manual here.
Feb 19, 2010 | Lands Phones
My cordless phone says "to register see owners manual for help" How do I get the phone working, it is a uniden DECT 6.0 Model DECT 1588-2
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Dec 21, 2009 | Uniden DECT 6.0 Cordless Telephone...
I use the cordless phone binatone twin model 3300 e 2107th on one of the headset now only writes HBI singala it does not have a while before it was written, the signal h2 b2.Sada constantly blink (MIGA)...
Problem is solved On the telephone headset to make the first reset, selecting keys 1 0 and confirm the green headset. After that, the BASE press for registration until the hear a beep. Within 30 seconds the phone headset press PROGRAM 1 6 and enter the number 20,000 and confirm the green headset, or OK. Telephone handset is registered as the second in a row and at the same writes h2 n2. Problem solved PROBLEM JE RIJEšEN Na telefonskoj slušalici prvo izvršiti resetovanje, odabirom tipki 1 0 i potvrditi zelenom slušalicom. Nakon toga na BAZI pritisnuti tipku za registraciju dok se ne čuje BIP. U roku od 30 sekundi na telefonskoj slušalici pritisnuti PROGRAM 1 6 i ukucati broj 20000 i potvrditi zelenom slušalicom, odnosno OK. Telefonsk slušalica registrovana kao druga u nizu i na istoj piše h2 n2. Problem riješen
Oct 28, 2009 | Motorola Mobility E51 MD7161-2 Twin...
IDECT V2i twin phone user manual
http://www.binatonetelecom.com/resources/0000/0146/idect_v2i_ifu_master_080409.pdf
Oct 21, 2008 | Lands Phones
Lands Phones Logo
267 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
