Question about HP PSC 1610 All-In-One InkJet Printer
Unusual noise My copier is making a louder noise than usual while printing. Like maybe a motor or wheel or something?
  • steve clark
    steve clark Jun 01, 2009
    not my noise type, thanks anyway!
Scanner unit initialises on power on condition. scanner unit moves to right extreem end and makes banging noise. This problem is due to scanner unable to find the home position. open the flat bed glass unit . one end of there will be black colure with white stip. apply black marker ink on black colour and fix the blass back to griginal position. scanner will work.
Posted on Sep 13, 2007
Dryer will not start
Many possibilities. If you hearing a noise when it's trying to start, the motor may be the problem, or something lodged in the blower wheel preventing the motor from turning.
Oct 02, 2017 | Washing Machines
What the part no for main motor assy. The whole assy that needs to be replaced due to unusual grinding noise during paper run.
You cannot typically buy the entire assembly as one piece. You need to purchase the main motor and then all the related gears. There are companies out there that sell a kit with all the gears, look for one for the 5200 laserjet as they are the same.
Aug 31, 2016 | HP LaserJet M5025 MFP Printer
Identify cause of right rear wheel stuttering in turns (either direction) at low speed. No unusual noise.
Is your car a rear wheel drive? If so, the limited slip differential grease is low...if front wheel drive could be right rear strut/shock assembly is totally worn out...wheel bearing maybe, but usually makes a grinding noise...does applying the brakes affect this stuttering? Should be a free inspection at most quality repair shops...good that you notice this before it gets worse...
Sep 24, 2015 | Cars & Trucks
My 2013 elantra is making a thumping noise when I drive it. the faster I go the louder it gets. but when I turn the wheel to go around curves, the noise stops. any ideas
something is rubbing underneath by tires or maybe a bad axle or ball joint or wheel bearing,could even be a stuck caliper,you will have to look at your tires on backside to check your ball joints,
Sep 26, 2014 | 2013 Hyundai Elantra GLS
Vibration coming from front axle when coming to a stop it gets worse, brakes are good , maybe cv joint?
if you feel the pulsation in brake pedal when stopping. its a warped brake rotor thats causing it. for bad cv joint symtoms--- Unusual noises when making turns. As you are driving on the road and you make a turn at the corner, if you start hearing unusual sounds coming from under the car then this is one of the symptoms of a bad CV joint. These noises will sound like something is clicking beneath the car every time you turn the steering wheel. Evidence of a damaged boot. Steering wheel feels heavier. The steering wheel will start to feel tighter and heavier and you can hardly make simple turns to the left or right. In severe cases you might even feel heavy vibrations like you are driving down a rocky road.
May 02, 2012 | 2004 Jeep Grand Cherokee
Hi, Thee dryer makes a loud noise during cycle. It starts low, but it seems after each rotation it get louder. Has anyone ever experienced this and are there any solutions. Thanks for any assistance.
Describe the noise. If its a rattling banging noise you could have a broken exhaust fan which is usually attached to the motor, a broken cylinder roller (if your dryer has them) or worn felts. Maybe a noisy pulley. If its more a high pitched squeek it could be your motor or the parts just mentioned. A metal scraping noise could be something like a bra wire caught by the cylinder but I don't see how that can get louder as the rotates. Make sure the belt isn't cracked all over. Worst case scenario is that your motor is on its way out...
Good luck
Aug 29, 2010 | Dryers
My car makes a bad growling noise. Everyone said that it was a front wheel bearing because that tire was worn down really bad on the outside. I replaced the passenger front wheel bearing, and it is still...
WHEEL BEARING USUALLY STARTS MAKING A ROARING TYPE NOISE WHICH USUALLY GETS LOUDER THE FASTER YOU DRIVE, SOMETIMES THEY WILL BE LOOSE , TO CHECK JACK UP THAT WHEEL AND GRAB TOP AND BOTTOM OF TIRE AND SHAKE, IF THERE IS MOVEMENT, TRY TO GET SOMEONE TO ROCK TIRE FOR YPU AND WATCH WHERE AXLE GOES INTO CENTER OF BEARING AND SEE IF AXLE IS MOVING WITH TIRE MOVEMENT AND SPINDLE REMAINS STATIONARY, THEN IT IS BAD BEARING, OR SOMETIMES THERE WILL BE NO MOVEMENT, THEN BLOCK REAR WHEELS AND RUN CAR WITH THAT WHEEL IN AIR AND SEE IF YOU HEAR NOISE, GOOD LUCK.
Mar 20, 2010 | 2001 Chevrolet Cavalier
The car makes a howling noise while driving it
well did the noise start after the tires were rotated?could be choppy tires,,,if not ,i strongly think it sounds like a bad wheel bearing,,,,if you drive and while its making the noise turn left and right quick and see if the noise gets louder and which way turning makes it louder,,if you turn leftand it gets louder its usually the right wheels bearing as you are putting load on it, if it makes the noise louder while turning right its the left wheel bearing,,,got it
Oct 08, 2009 | 2000 Pontiac Grand Prix
Unusual fan noise
sounds like you need a new fan motor or blade
Jun 03, 2008 | Amana ARB8057CSL Bottom Freezer...
HP PSC 1610 All-In-One InkJet Printer Logo
152 people viewed this question
Clive
Clive
