Question about Dryers
The wires on my heating element might be switched any clue on the wiring diagram Changed heating element, it was broke . After about two months a wire going from a sensor to heating element burnt and it quit heating. Did I put the wires on wrong ?
  • Anonymous Mar 18, 2014
    can you please give me the colouring wiring code for the heating element
  • Dryers Master
  • 8,220 Answers
The 2 wires that go to the element are largest. Does not matter which one goes where. The other 2 wires are smaller and imposible to get on the wrong terminal.
Posted on Dec 31, 2008
I have a Lakeside #937 plate warmer why doesn't it heat?
Have a look at the wiring diagram to see if there is a thermal or safety cut-out. If this has tripped or turned off, the unit wont work. Also make sure the unit has a neutral. Appliances can have an active but if the neutral has broken or disconnected, it wont work. Use a multimeter or get a sparkie to check it for you.
Apr 08, 2015 | Dryers
Whirlpool Dryer is not heating
suspect element. refer to wiring diagram. unplug dryer. unscrew or unplug wires from element. use multimeter set to "continuity," and touch leads to ends of element where you removed wires. If no meter reading or "beep," element is probably bad. If you have continuity, suspect loose wires or switches. That's all I know!
Apr 14, 2013 | Dryers
Long story
more likely that you didn't wire the plug correctly
take it in to a repair shop for check
May 08, 2017 | Frigidaire Dryers
Oven will not turn on. but stove top works fine. model#jgbs07pea2ww
A common problem is the heating element goes bad. I have had this happen and you can see a spot on the heating element which looks different from the rest of the element (a clue).
Many ovens have two heating elements. Upper and lower. Now I am no Julia Child, but I think bake turns on just the lower heating element? And broil turns on just the top heating element????
So I suppose you might have it on bake and it is not working. Might try broil and see if that works. If yes, then you are getting power through all the controls to the upper heating element, so good chance just the lower heating element is bad.
If you don't get heat to either the upper or lower heating element, then I would suspect the wiring or a control.
So far as the heating element, you should be able to remove it and using an ohm meter, get some sort of reading if it is good (I have no idea what though). Or open circuit if bad.
Also the insulation on older ranges can "melt" back exposing live wires! This is of course very dangerous and the wiring should only be replaced with high heat range wiring which I assume you could get at an appliance store?
Or the contacts on a control/switch could be bad. I would test this with a continuity tester or ohm meter.
Many appliances have a wiring diagram down low somewhere. Or might find it online.
Nov 18, 2009 | GE Profile JTP56 Electric Double Oven
My dryer will not heat. I had this problem about 6 months ago. I have a res6745rq0 model.The thermostat was replaced and the fuse 6 months ago
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor 2 heavy red wires (check wiring diagram for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Aug 16, 2009 | Dryers
Changed high temp thermostats, maybe hooked wires back up wrong?
you should have a wiring schematic diagram somewhere on the machine otherwise the limit switches are normally wired in series w/element
Aug 15, 2009 | GE DVLR223 Dryers
The dryer won't heat. We just changed the heating element but it still won't heat up. What else could be the problem
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check timer , thermostats and safety switch on motor (check wiring diagram for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Aug 06, 2009 | Dryers
My kenmore electric dryer is not heating I checked the heating coil and it seems ok could it be one of the thermostats?
Kenmore style dryer - no heat problems:
Electric dryers - See the "how to take apart" section first if needed. Always check the power supply first...if one house fuse blows or 1/2 of the breaker trips, it is possible for the dryer to run with no heat. If you have a volt meter, you should read 240 volts between the red and black wires, 120 volts between the white and black and 120 volts between white and red, check for this at the main power connection. If you have 240 volts to the dryer, remove rear access panel, turn dryer on and test for 240 volts to the *heating element wire connections (#4). If you have 240 volts there and no heat = bad element, the element must be broken physically to be bad. If you have no power at the heating element, remove power, remove wires to the heating element and isolate them so that they can't touch anything. Reinstall power and check each wire for power from the wire to the dryer cabinet, one wire will probably show 120 volts and the other will show zero. Make note of the color or # of the wire that has no power, remove power to the dryer and check the wiring diagram that comes with the dryer to find out where that color or # wire goes to. EG: - wires might be yellow and red, if the yellow wire (example only) was the one that had no power, look at the wiring diagram to find out where that goes to and check only those parts, no need to check the other colored wire parts as they are working. Things to check are, *thermostats, timer contacts, selector switch, motor switch heat contacts ( 1&2 on the motor switch ) and *thermal fuse. If the wires to the heating element are the same color, just remove power after test and slowly follow that wire that has no power with your hand to see what parts it goes to. If live volt testing scares you, try the ohm checkinstead.
*#1-Thermal fuse that controls heat. If the dryer overheats, this fuse will blow. One shot fuse. Does not reset.
#2-Canister for the heater element.
#3-Hi limit thermostat. This thermostat is a safety thermostat in case the dryer severely overheats. When this safety thermostat is defective, it should raise a red flag for air flow problems.
#4-This is the terminals of the heater element that is inside the canister.
#5-Thermal fuse that controls motor run.
#6-Control thermostat. This is the thermostat that controls the cycling of the heater in high heat mode.
#7-Heater for low heat. When you select low heat, 110V is sent to this heater that the control thermostat sits in. The heater helps cycle the control thermostat faster, therefore you get less heat than the high heat mode.Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Jul 11, 2009 | Kenmore 62602 Electric Dryer
Powers on wont heat lg dle2532w
better to unplug the unit for an hour.
Mar 23, 2009 | LG DLE2532W Electric Dryer
Dryers Logo
567 people viewed this question
Top Dryers Experts
