Question about Motorola Mobility MPx220 Pocket PC
Weak signal on Motorola MPX220
Having problems with my MPX220. Can't get a good signal at all. Standing with my MPX200 in one hand and my MPX220 in the other, the 200 shows Full Signal and the 220 shows one bar if any. Both with T-Mobile. Any solution? Thanks in advance...
0 characters
1 Points
I dont have a network on my motorola mpx220!Is there any way I can either fix this problem some how?
Hi Meldisa,
Remove your cell phones battery and Simcard and reload them again.
Hope this helps.Thanks!
Dec 14, 2011 | Motorola Mobility MPx220 Pocket PC
Mymotorola mpx220 says no service everytime and it had like a 2 hamlf moon sign next to service antena and i tried 10000 times to master reset after pressing yes it says processing and after 2 sec it shuts...
MPx220 - Master Reset How do I do a Master Reset? To do a Master Reset:
  1. Power the phone off.
  2. Press and hold the BLUE action key.
  3. While holding down the action key turn the power back on.
  4. You will then get a prompt asking for confirmation of a Master Reset.
Note: This will NOT delete the file manager but all memory contents and phone settings will be erased. Please recomend that any data be backed up before performing a Master Reset on the MPx220.
May 12, 2011 | Motorola Mobility MPx220 Pocket PC
I have made a folder to store some messages in my phone and now i have forgotten the password to unlock it. What should I do?
Hi!Did you change the default password of your phone?If not,try to enter or type the default password (0000) or (000000) to unlock your folder.If ever the default password is not working,you may try this other secret codes for motorola.
c350 english languge
1 1 5 2 6
(T190, T191, T205) master code
- 19980722
- 20010903
P2K test menu:
*#06#, menu, menu, 048263*
Test comands:
32*116*1*0*0 - read phone code
32*118*1*0*0 - read security code
18*0 - factory reset, phone code off
18*1 - master reset
54*18*1 - full phone reset
10*0*6 - select 900/1800
32*279*1*0*8 - model
32*383*1*0*0 - flex version
Hard reset MPX200, MPX220 - blue button + power on
Feb 25, 2011 | Motorola Mobility ROKR E6 Smartphone
Where the moptorola MPx200 driver free side
Try and see you drivers there.You did not indicate what Operating system you want your driver to work on,but you will find some solutions there.
Nov 25, 2010 | Motorola Mobility MPx200
Does not start
change the rom or hard reset,to do hard reset first press the big blue button and hold it press and then press the power swich,the message master reset will apear and choose yes.By doing this you will loose everything on your phone
Apr 05, 2008 | Motorola Mobility MPx220 Pocket PC
Soft ware
Go to and dowmload Active sync 4.2 or 4.5 as per ur requirement and follow the instruction.Thats it....
Mar 29, 2008 | Motorola Mobility MPx220 Pocket PC
Flight mode
press "power on" and "home" keys (same time), then in menu: fligh mode off... and ready
Mar 05, 2008 | Motorola Mobility MPx220 Pocket PC
Cellphone problem with activesync
There are few solution you can try: 1) uninstall ActiveSync 3.7 and reinstall it and start over agin for the sync process. 2) Try to install the newer version of Activesync 4.2, it may help to cure some bugs with MPX220. 3) But first, you need to install the Motorola Mobile Cd comes with the phone and upgrade the software to th emost recent version and reinstall this software. Now tehn try to reconnect the phone again and start the new setup. If you try all these options, the phone is stil l not be connected normally, then your phone may has some bugs in synchronization. If your phone is llocked to Cingular, try to unlock it first before do synchronization since this phone has this issue reported form many users. you are not alone. Good Luck
Sep 19, 2005 | Motorola Mobility MPx220 Pocket PC
Motorola Mobility MPx220 Pocket PC Logo
50 people viewed this question
Top Motorola Mobility PDAs Experts
David Payne
David Payne
Abby Carter
Are you a Motorola Mobility PDA Expert? Answer questions, earn points and help others
