Question about Ovens
Finding the serial numbers or model numbers
Plate with numbers have been removed is there somewhere esle to look for the numbers VVV Jenn Air
  • 41 Answers
If the plate is gone your out of luck
Posted on Jan 01, 2009
How does one rmove the oven door of a jenn air oven. I can not find instructions in the owners manual or installation guides/instructions. Do I need to remove the hinges or is there a release mechanism?
Look at the hinge, their is like a slider bar to move or you remove the little cover plate, with the Philips screw..then lift the door up and out while pulling...
I WARN YOU, if you really don't need to remove the door don't, it is very hard to put back on unless you have had practice....
Dec 19, 2010 | Jenn-Air Electric Double Oven
Top electric oven will show an F3 error after being turned on and will beep. Botton oven works fine. Jenn Air electric oven model JJW927AAW. Serial number 11993640WO
HI thanks for your question.. code F3 says to replace the oven sensor, located in the oven. top left corner. Replace the oven sensor. Thanks
Dec 17, 2010 | Jenn-Air Ovens
I need the Manual for jenn air w198-c
Hi, Sorry, but that's not a Jenn Air model number. Jenn Air ovens have 9-digit model numbers, e.g. JJW2530WS. Please reply to this message with the correct full model number and I will provide a download link to your manual if one is available. Regards, BElectric.
Nov 15, 2010 | Ovens
My oven Door fell off. it is a Jenn-Air JJW9530C
This is a known issue. The model number is JJW9530C. I have been browsing the internet trying to find stronger hinges but with no luck. It seems there are a lot of unhappy Jenn air owners. You are correct in your assumption that the door is to heavy for the hinges. I will post the websites for your review
http://www.ovensworld.com/jenn-air-jjw9530c-expressions-collection-electric-single-oven.html
Maybe if I could see the hinge I could fabricate a stronger stainless steel one for you
Apr 27, 2009 | Jenn-Air JJW9530C Stainless Steel Electric...
Jenn-Air double oven door seal W241
it is very simple if you look at the back of the oven there is part number and serial number yet there is the model number and you can search it on the internet i i changed mind simple but i change the window of the oven it had 4 screws and i took it out and in put in withen 20 mins . without the manual how ever if you still think cant do it look a the model of it and see what does it need to be removed you are smart good thinking changing by your self then sending to repaire and yet not alot of people will do what you do..
Apr 21, 2009 | Jenn-Air JJW8230D Electric Double Oven
How do you get a Jenn air oven out of the wall???
The JennAir website should have the installation manual for download. Go there, type on your model number, and it should come up.
Sometimes these ovens just get "stuck" in place, and take some easy levering to break free, or to help you find other fasteners.
Jan 15, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
My Jenn Air 30 in oven
For Jenn-Air ranges, this is a fault code for a defective Electronic Range Control (ERC) and/or membrane (keypad). It is usually a bad membrane that causes this problem. If the membrane has a small ribbon cable connecting it to the ERC, you can sometimes disconnect it, clean the connections, and reinstall to correct the problem. The problem may also be as simple as a button on the keyboard stuck somewhere. Worst case scenario: you will have to replace the entire ERC and membrane altogether. For pricing information, you can find replacement parts at searspartsdirect.com or repairclinic.com. Just type in your model number in the search menu and there will be a parts index for you. The membrane and ERC are usually sold separately. I hope this helps you.
Mar 02, 2008 | Jenn-Air 30 in. Pro-Style Electric Single...
Jenn-Air built in oven Model W188-C, Serial # 210764UC approx 1987
Big oops, Millwood. Shut power to the unit immediately and wait a day or more for it to dry out. If it works then, fine. If not, you've got a learning experience installing a new pad.
Dec 07, 2007 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
106 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
