Sylvania vcr won't play or eject tape
Finally took cover off vcr and played around until tape came out. looking at machine while cover is off, seems it plays even when a tape is not in it. When a tape is inserted, "tape in" light flashes but won't play or eject the tape. i know, get rid of the machine and stick with dvds. but, is it a cheap fix to get the vcr running again? we have a lot of children's videos that are hard to find on dvd...
SOURCE: Flashing '2' or '1' or '4' when I try and play a tape
The idler on your machine needs to be changed and also the drum head of your machine needs to be clean.tape head cleaners can be bought from any electronic shop.the idler must be changed by qualified techn
Posted on Jan 27, 2007
  • 883 Answers
SOURCE: Tape ejects just after insertion
the end-of-tape optical sensor is at fault. either it is very dirty, has failed or something else is detecting end of tape. many VCR's now will auto-eject the tape upon end of tape detect
Posted on May 20, 2007
SOURCE: Tape wont play then ejects
Hi Slovakia
Thanks for the reply ...but where do I download the service manual from?
Posted on Dec 16, 2007
  • 883 Answers
SOURCE: Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Posted on Feb 05, 2008
  • 139 Answers
SOURCE: VCR tape won't eject
The flap on the door stays open until the tape is ejected. There are two possible ways to remove the tape. First, with the power off, try to locate the drive pulley or gear on the side of the tape housing. It may be possible to turn it with your finger and cause the tape to eject. The eject mechanism will move VERY slowly when you use this technique.
The second way to do it should normally be done by an experienced technician, because it involves taking it even farther apart...and it may be difficult to reassemble. There are typically four screws that hold the tape mechanism in place...two near the top front and two near the back. It should be possible to remove those screws and pull the entire mechanism out of the VCR. Then you can more easily rotate the eject pulley (or gear) and remove the tape. If this sounds a little scary, I would definitely recommend placing the top back on and acting like nothing happened!
Posted on Mar 17, 2008
How can I get my tape to eject?Sharp VC-A560. Played my taped, rewound, but tape would not eject. Tried to play again and it would not play.What can I do?
Unplug from wall outlet - find the wheel that ejects the tape when you slowly turn it. It's usually on the right side when the cover is open. Avoid touching any metal parts.
Mar 01, 2015 | Sharp VC-A560U VHS VCR
VCR won't eject tape
unplug VCR take the top off about 4 screws or more I would say you willmbe able to see that tape is wound round inside you should be able to remove it .
Mar 16, 2013 | Heating & Cooling
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
My sylvania tv/vcr keeps ejecting when it has nothing in it. It will go through stop eject play over and over. What can I do to fix it?
Not likely to be worth repairing but if you can get it apart look at the mechanism when you plug it in.
These units (all brands/models) have two light sensors (one on either side of tray) and if blocked with something will instantly try to eject the tape--they usually stand up and have a clear LED and could be bad or even broken loose from the board---when a tape goes in it blocks both and machine switches to load--pulling tape in and down---if one is bad or one covered you could have this problem.
Look also if you open it for some item that does not belong inside like a coin etc.
Apr 08, 2012 | Sylvania Televison & Video
Problems playing a VCR tape
check/replace your vcr's belts, clean the reel sensors and check or look for bloated and deffective capacitors on power supply section,
Oct 13, 2009 | Sylvania SSD803 DVD Player/VCR
I hAVE 24 in DVD triple combo ^&@$DG TV. I put
You're describing what could be a loose or worn loading belt problem, most of the vcr mechanisms used in these combos use one to load the tape and thread it for it to play or record, that is why you have to keep puhing the tape untill the machine accepts the tape and you have to keep pressing play untill it starts the play function.
Sep 19, 2009 | Sylvania Televison & Video
VCR tape was hung in Sylvania SRDV495. Got the
You need the aligniament the eject gears to tape gears.Please remove the cover platen and the rear cover(bottom) and align the gears manually.Obturated the sensors hole and insert the cassette.Verify the eject and the tape belts.If you have knowlwdge VCRs the problems solved in 1 hour.
Aug 21, 2009 | Sylvania Televison & Video
Tape stuck.
check the tip in my profile
May 19, 2009 | RCA VR651HF VHS VCR
VHS got jammed, clicks, turns self off
Open it up and next to the right spindal where the tape goes there should be a small, black B-S button, press it in with a pencil or pin, and it should reset the VCR's computer.
Feb 04, 2009 | Sylvania DV220SL8 DVD Player/VCR
VC recorder keeps on driving
I beleave your sensor that tells the player weather a tape is in there or not needs replaced ~ It sounds like it doesent know the tape is not there aand will not shut down! (replace tape sensor)
Please rate my answer and help keep this site free!
Dec 31, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
