BenQ FP731  17" LCD Monitor
Problem for BenQ FP731 (Silver) 17" LCD Monitor
BENQ FP731s Monitor Problem white blank screen
By vwbugrazz on May 06, 2007
hello, power light works, monitor comes on, but only with a full white blank screen, whn I disconnect from the PC, the white screen stays on permanantly, when I connect it back up to th PC the white screen go black as the computer boots up, but then remails white. The controls on the front of the monitor don't do anything at all. Please help, thanks.
Comments:
May 07, 2007
- is it time to toss the monitor, or is it worth taking in for repair?
Same Problem
Nov 22, 2007
-   when i turn my benq fp731 monitor my lcd whole screen changes color ffom white then red then green then blue over and over again.-   yapsim
Best Solution
posted on Dec 27, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
BenQ brand new high-voltage wire circle
BenQ LCD Controls circle / BenQ LCD accessories more high success rate, and easy maintenance, fault lower again!
Name : LCD Controls circle
Model : specifications : 1J.26048.011
BenQ LCD accessories four small mouth lights of the high-pressure reverse pressure plate used for high temperature must Taiwan curbs are enameled wire system. With a small noise, power, brightness control in high-efficiency low-loss. Rapid cooling loop can be designed according to customer-specific products.
2 features the use of high-precision inverter line Rao, insulation and can be a long time. 3 to 1. Electricity use light line measurement of high-frequency currents. 2. Backlight voltage output of a sinusoidal waveform. 3. The backlight brightness and the same as the original high-pressure plate. 4. 1-2 4.1 filament output AC exchange through the export of Maintenance and Spec - CN5 link to the. 5 and storage temperature and Temperature temperature ranges : -5 -- 50 ℃ work humidity range : 10% -- 95% RH the backlight should be within the scope of the above, the following conditions can store 40,000 hours. Operating temperature : -10 -- 80 ℃ work Humidity : 20% -- 95 % RH
BenQ LCD maintenance information
1 : BenQ LCD can switch planes normal (no signal light yellow, green signal), Looking carefully at the screen whether there are changes, they generally do not carefully read the screen can not see a change, oh, look at carefully Matata. Change or switch to a normal plane, the main board intact, such a high-pressure situation on board is no work, no lights lit backlight.
2 : disassemble machines, starting with high-pressure plate (box 220V piece of the plate), a screwdriver button open, not lazy. Power board and put the Main Board are removed, this is a good Off Power Plate,
3 : Measurement C5707, FQU11P06 (Some of the machines are used FU9024), whether the damage (breakdown) If the damage (breakdown), he seemed to see the appearance .22/160V capacitance whether deformation, If deformation replace, if not capacitance deformation on regardless.
4 : damage to the replacement of the device, if the fear of electricity burned again, you can Controls circle together too, In order to save costs if you should not start for high-voltage wire circle -- testing, If the damage C5707 meeting on the need to replace the high-voltage wire coils (most of the damage to the C5707 is Controls 72.9% Circle aroused),
5 : measurement of high voltage power supply board whether short circuit, without short-circuiting I would be grateful if insurance (PF801) new ones (General C5707 damage, insurance will certainly damage), If you do not have insurance you connect with fine copper wire, this 3-A insurance. Please stop the PF801 power-measurement, measurement inaccurate.
Understand how maintenance of electronic maintenance steps friends
2 : disassemble machines, starting with high-pressure plate (box 220V piece of the plate), a screwdriver button open, not lazy. Power board and put the Main Board are removed, this is a good power to remove board.
3 : replacement C5707 4 (Q809, Q808, loops, Q815) four high-voltage wire coils (T001, T002, T003, T004). 2 FQU11P06 or FU9024 (Qingdao, Q805). PF801 Insurance (insurance for the three A).
Solution #2
posted on May 06, 2007
Somewhat Helpful)
samkong
Rank: Wiz
Rating: 82%, 194 votes
You have a serious problem. ie. only the back light is working in your monitor. You might need to replace the TFT associate components.
Was this helpful?
Yes
No
Solution #3
posted on Apr 01, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Dewang LCD accessories This replaces the board is FP71G (motherboard connects above liquid crystal screen is a row of line, row of wide 30PIN, the white FFC line) The customer purchases this power panel not to have to look the machine model, needs to disassemble the machine to look the motherboard connects above the liquid crystal screen is several row of lines. A row: FP71G machine. Two rows: FP71G+. A line: M170EP01 This board until now had above a year from the sale. The board quality obtains the full affirmation and the customer approval. Until now has not had repairs a second time the board. Maintenance way: This board for brand-new replaces the time which the board, this company produces goods can test, tests OK on the packing to deliver goods, if the customer receives the board to appear cannot use or for one month has the damage, this company free maintenance. The maintenance period transport expense voluntarily undertake by the buyer. Commodity name: The bright base liquid-crystal display replaces the high clamp + power panel specification: Four lamps small mouths + power panel Supports bright base FP71G, FP71G+ FP71GX and so on, thoroughly processes the good bright base liquid-crystal display black screen breakdown, this board maintains for a month, brand-new board, FP71G FP71G+ FP71GX FP737S (screen model: M170EP01) Ming Jihen multi- liquid-crystal display power panel type, purchase time best please pat a picture we to look, in order to avoid makes a mistake the goods Note: This board is the bright base liquid-crystal display replaces the board, the non- original factory board, the bolt hole site is dissimilar, when the time comes asks customer to fix inside the machine, does not need the wiring, this company already completed the connection motherboard plug, the attention: Nearby the original installation power panel power source plug has a fixed Zhuang-zi to be able to short-circuit, please presses him evenly, other places cannot short-circuit. Installed may, brightness and the original factory board was nearly equally bright.
Asks front which the customer purchases to send the information to my mailbox: Indicates your board and the machine model, is best can pat a your bad board the picture. Thanks! Mailbox address: Dongwandewang@yahoo.cn Address: The Chinese Guangdong Province Dongguan city pond mansion town lotus lake district is bright and the computer market A2092 room telephone: 86-0769-82077079 8772017413728205959 contact people: Ancient gentleman
Вспомогательное оборудование Dewang lcd это заменяет ть доску будет FP71G (motherboard соединяется над жидкостным crystal экраном будет рядком линии, рядком широкие 30PIN, белой линией FFC) покупкы клиента эта панель силы, котор нужно посмотреть модель машины, потребности демонтировать машину для того чтобы посмотреть motherboard соединяется над жидкостным crystal экраном несколько рядок линий. Рядок: Машина FP71G. 2 рядка: FP71G+. Линия: M170EP01 Адрес: Китайское заречье озера лотоса городка хором пруда города Dongguan провинции Guangdong будет ярко и комнаты рынка компьютера A2092 телефон: 86-0769-82077079 8772017413728205959 свяжутся люди: Стародедовский джентльмен
Solution #4
Not Rated)
dewang
Rank: Apprentice
Rating: 85%, 1 votes
Comments:
Dec 27, 2007
- 1:明基液晶顯示器能否正常開關機(指示燈沒信號為黃色、有信號為綠色)、仔細看屏上是否有變化,一般不仔細看是看不到顯示屏有變化的哦,看仔細啦。有變化或能夠正常開關機,表示主板完好,這樣的情況就屬於高壓板沒工作,沒點亮背光燈。
2:拆開機器,首先檢查高壓板(插220V的那塊板),螺絲鈕開,別偷懶,把電源板和主板都拆下,這樣比較好取下電源板、
3:測量C5707、FQU11P06(有的機器是用FU9024的)、是否損壞(擊穿)、如果損壞(擊穿),將他拆下來,在看.22/160V電容外觀是否有變形,如果有變形請更換,如果電容沒變形就不管他。
4:將損壞的器件更換新的,如果怕上電再燒,你可以講高壓線圈一起換掉,如果為了節約成本你就先不要換高壓線圈上電測試,如果在次損壞C5707就需要更換高壓線圈(大多數損壞C5707最歸禍首就是高壓線圈引起),
5:測量高壓板供電部分是否短路,如果無短路,請將保險(PF801)換上新的(一般損壞C5707,保險肯定損壞),如果你手上沒有此保險你就用細銅線連接起來,此保險為3A。
PF801請用電阻擋位測量,否則測量不准確。
不懂怎麼維修電子的朋友維修步驟
2:拆開機器,首先檢查高壓板(插220V的那塊板),螺絲鈕開,別偷懶,把電源板和主板都拆下,這樣比較好取下電源板。
3:更換C5707四隻(Q809、Q808、Q816、Q815) 4個高壓線圈(T001、T002、T003、T004), 2個FQU11P06或是FU9024 (Q812、Q805)。 PF801保險(此保險為3A)。
4:好啦,你現在可以開電看你的結果啦。
Apr 01, 2008
- Dewang LCD accessories This replaces the board is FP71G (motherboard connects above liquid crystal screen is a row of line, row of wide 30PIN, the white FFC line) The customer purchases this power panel not to have to look the machine model, needs to disassemble the machine to look the motherboard connects above the liquid crystal screen is several row of lines. A row: FP71G machine. Two rows: FP71G+. A line: M170EP01 This board until now had above a year from the sale. The board quality obtains the full affirmation and the customer approval. Until now has not had repairs a second time the board. Maintenance way: This board for brand-new replaces the time which the board, this company produces goods can test, tests OK on the packing to deliver goods, if the customer receives the board to appear cannot use or for one month has the damage, this company free maintenance. The maintenance period transport expense voluntarily undertake by the buyer. Commodity name: The bright base liquid-crystal display replaces the high clamp + power panel specification: Four lamps small mouths + power panel Supports bright base FP71G, FP71G+ FP71GX and so on, thoroughly processes the good bright base liquid-crystal display black screen breakdown, this board maintains for a month, brand-new board, FP71G FP71G+ FP71GX FP737S (screen model: M170EP01) Ming Jihen multi- liquid-crystal display power panel type, purchase time best please pat a picture we to look, in order to avoid makes a mistake the goods Note: This board is the bright base liquid-crystal display replaces the board, the non- original factory board, the bolt hole site is dissimilar, when the time comes asks customer to fix inside the machine, does not need the wiring, this company already completed the connection motherboard plug, the attention: Nearby the original installation power panel power source plug has a fixed Zhuang-zi to be able to short-circuit, please presses him evenly, other places cannot short-circuit. Installed may, brightness and the original factory board was nearly equally bright.
Was this helpful?
Yes
No
Solution #5
posted on Nov 28, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
You need to call BenQ technical support to get a RMA. They can be reached at 866-600- BenQ (2367).
Popular Solutions for BenQ FP731 17" LCD Monitor
Questions and Unsolved Problems for BenQ FP731 17" LCD Monitor
Do you recommend BenQ FP731 (Silver) 17" LCD Monitor?
Answer
Answer
my screen has gone black, it started by turning on and off then it would show the desktop then go... (More)
Answer
what can i do if the on/off button has been stuck and I am unable to switch on the monitor?
Answer
My pictures are too "long" that is, faces are elongated. y monitor is new and I can't... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
