Question about Whirlpool Duet GHW9150P Front Load Washer
No lights or power comes on, door lock.repair man said control box so bought new one still no power,got 120 volt going in to box, (ghw9250ml0 = front load)
  • 640 Answers
I think you brought the wrong board ,,i looked this up a night ago,,you need the power control board,,,im going to get the part number,,and you match it to the box or invoice,,,
Posted on Dec 31, 2008
Why won't my Whirlpool Senseon Dryer start? The control panel will not respond. No buttoms will light up or beep. The dryer has power and the door latch works properly and the light comes on inside
Always disconnect power before attempting any service. Most electric dryers require 240 volts to operate properly.
You may have only 120 volts to supply the dryer which will give you your symptoms. Click dryer circuit breaker off then back on to reset 240 volt system.Still no heat/run
This link will aid you in tear down / diagnostics/parts
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
Nov 21, 2017 | Whirlpool Dryers
2003 gulf stream prairie schooner 5th wheel computer box/electrical problem
ac runs off 120 volts refrigerator 120 volts heater element 12 volt heater element and control board outside lights 12 volt ceiling fan 12 volts wires that go to box 2 blue furnace 12 volt wires from thermostat 12 volt
May 10, 2017 | RVs
PAU error code comes on when iI test it it shows e41 door lock
Hello, welcome to FixYa
Based on the info you provided, specifically the E41 error, It sounds like the unit is detecting an unlocked door, loose wire, or the control itself is bad. (E41= Shorted or open. Defective door lock assembly.Around 1500Ohms. Defective control board.)
The PAU simply indicates the control thinks it has been paused...that may be just a side affect of the door lock assembly.
Here's how to check...
**Unplug the unit from the wall first...safety first**
Remove the door lock assembly and measure the resistance of the PTC. Should get a reading of around 1500ohms.
Attached here is a great tutorial for accessing the assembly for testing and replacing.
http://www.repairclinic.com/PartDetail/Door-Switch-Assembly/131763202/1531974
Let me know if you need further assistance going forward or if anything is not clear.
Thank's again for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Jun 16, 2011 | Frigidaire Affinity ATF7000ES Front Load...
I have a 1991 chevy astro van when my van sits without starting up more than 12 hours the battery is dead. I bought a new battery and the same problem remains. I took the van to a repair shop and they...
The way to find the short is as follows. Using a 12 volt test light start with the hot wire(s) going to where you think the problem is located.( like the windows or door locks as you stated) Continue this process with all of the circuits until the bulb in the test light "lights up" when you insert the probe into the circuit wire. Bear in mind this type of problem can be very time consuming which is why vehicle electrical repair shops charge so much.
Nov 22, 2010 | Chevrolet Astro Cars & Trucks
All the lights, display, etc. work on the oven but no heat
First and foremost check the breaker box. Ovens use 240 volts which is a double breaker in the box. Just to be safe I would click both breakers off and then back on together. If this doesnt work turn off the power and have someone help you pull the oven out and check your plug or connection. You may be dealing with a broken wire in the junction box due to the power outage. If you have a volt meter turn the power on SAFETLY and test if your getting 240 volts. If the connections are good (including the one from the juction box to the stove itself) and you are getting proper votage, unfortunatley you are going to have to get a new control. What happens is with only 120 volts going to the oven everything runs but your elements (they utilize the 240 volts to heat). You can tell time or use the timer but without your full 240 your turkey aint gonna cook. There is 120 volts coming coming from each of those breakers you checked in the garage. Bottom line is the chances of both elements going out at the same time are slim to none and I feel you are probably dealing with a broken wire.
Jan 23, 2010 | Whirlpool RBS305PD Electric Single Oven
GE microwave will not come on. No light no control panel.
The door light is usually controlled by a relay on the control board, not just the door switch.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jul 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Door lock - controller
Control board sends power to door lock and unlock door. Control Board is most likely the problem. Have you tried unplugging machine for 5 minutes and then plugging back in?
Sep 23, 2017 | Whirlpool LHW0050PQ Front Load Washer
2000 Ford Ranger
TEST B: BATTERY VOLTAGE OUT OF RANGE - DTC B1676
1. Check if vehicle has been jump started within past 2 weeks. If vehicle has been jump started, ABS is
okay. If vehicle has not been jump started, go to next step.
2. Using DVOM, measure voltage between positive and negative battery terminals. If voltage is 9-19 volts,
go to next step. If voltage is not 9-19 volts, diagnose charging system. See appropriate GENERATORS
article in STARTING & CHARGING SYSTEMS.
3. Turn ignition off. Disconnect 25-pin ABS control module. Install EEC-IV 60-pin Breakout Box (014-
00322). Turn ignition on. Measure voltage between breakout box terminal No. 20 and ground. If voltage
is more than 10 volts, go to next step. If voltage is less than 10 volts, repair Light Blue/Pink wire between
ABS control module and instrument panel fuse panel.
4. Turn ignition off. Measure voltage between breakout box terminal No. 25 and ground. If voltage is
greater than 10 volts, go to next step. If voltage is less than 10 volts, repair Red wire between ABS
control module and power distribution box/engine compartment fuse box.
5. Measure voltage between breakout box terminal No. 9 and ground. If voltage is greater than 10 volts, go
to next step. If voltage is less than 10 volts, repair Yellow/Light Green wire between ABS control module
6. Measure resistance between breakout box terminal No. 8 and ground. Also, measure resistance between
breakout box terminal No. 24 and ground. If both resistance measurements are less than 5 ohms, replace
ABS control module and repeat self-test. If either resistance measurement is greater than 5 ohms, repair
suspect Black wire between ABS control module and ground distribution.
NOTE: DTC B1676 will set if vehicle has been jump started.
2000 Ford Ranger
2000-01 BRAKES Anti-Lock - 4WAL - Explorer, Ranger & Mountaineer
Jun 11, 2008 | 2000 Ford Ranger SuperCab
Old whirlpool washing machine won't run.
Need the Model # from the unit open the lid if it is a top load look at rear where lid closes to on the rim
Oct 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
62 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
