Question about Home
How to repair porcelain/cast iron sink scratches
This is an under the counter sink installation and I do not want to remove the granite counter top to remove and repair the sink. Please advise best process to eliminate srcatches, dull spots. Most repair services in my area advertise a polymer spray-on process? Is there anything better?
If this does not work, is it possible to cut out the cast iron sink and replace with a new surface mount sink. If so how do I cut out the sink??
Look forward to your reply.
Lou
    Novelist:
  • 148 Answers
You can repair the sink with an epoxy based porcelin kit
Epoxy will not show brush streaks it will levelitself out do not get any kits from HD or Lowes they do not harden
Go to Sherwin Williams and ask for an epoxy paint for porcelin
As for removing the under counter sink
I would try cutting through the caulk adhesive
between the bottom of the granite and cast iron
sink with a hack saw blade
I have used a diamond blade on a grinder and
cut through but it was not a granite counter top
Be extremely areful to suport the underside of the sink with 2x4 blocks to prevent stressing the granite as you cut through
Good luck
Posted on Dec 31, 2008
    President:
  • 3,433 Answers
Use comet cleanser to remove pot and pan marks. Unless they are deep scratches or gouging.
Posted on Jul 12, 2009
I would call your local Kott Koating dealer and have them re-glaze the sink with their Porcelain based K-40 glaze. It was specifically developed for this application and will make it look like a new sink. Plus, its not paint (epoxy or urethane) so it will last way way longer and be much more durable.
Posted on Nov 25, 2009
Will under mounted sink take the weight of garburator?
The sink should be physically mounted with clips if it is not cast iron, otherwise a cradle made of wood is usually the route I go.
Feel free to contact me with any questions. Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
May 15, 2010 | Jacuzzi Kitchen Iron Black Finish...
No the weight of the disposal will not separate the sink from the granite. When they set the sink they put wood on the edge under the sink to hold the weight of the sink. You will not have a problem.
Mar 27, 2010 | Jacuzzi Kitchen Iron Black Finish...
How do I eliminate scratches and scuffs marble ?
i have been installing these kind of counter tops for years,there's a ton of stuff you can buy to seal,and protect your counter, one trick is to apply mop and glow to a dry counter let it dry and apply more coats.the good thing about mop & glow is you can remove easy, it works great.good luck
Jul 08, 2009 | Swanstone DIT-S042 Gray Granite Veritek...
Porcelain grate scratched or stained?
If you keep using the range without the aluminum pans it will eventually go away, but aluminum will leave marks on the surface of the grate.
Aug 20, 2017 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
PORCELAIN SINK UNDER GRANITE
Hi just unscrew from under sink use construction grade clear silicon screw it back in do not use for 24 hours and it will be ok
Apr 06, 2009 | Oxo Porcelain Pedestal Bathroom Sink,...
Cast Iron Sink with porcelain coating. The Porcelain coating crac
Kohler does have a porcelin touch up or you can get it at Home Depot or Lowe's. Not the best solution but it might help. Comes in a little bottle like White out
Kurt
Mar 15, 2009 | Kohler K-5814-4U Clarity White/Color...
How to remove a cast iron kitchen sink installed
Turn the water supplies off unscrew the hoses,get a flashlight and look under the sink you should see clamps around the top holding it in, unscrew these and pull the sink out.
Len
Feb 22, 2009 | Eljer 212-1088-00 White Dumount Double...
Home Logo
6,062 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
