Nakamichi CD player ejects discs
I have a Nakamichi " CD player 2" and it simply ejects a newly loaded disc after 5-10 seconds. There is a sound as if it is trying to read the disc but that's all.
Any Ideas?
Thanks,
Bill.
  • Anonymous Mar 28, 2014
    nad 5170 6+1 multi disc cd player
    Problem Solver:
  • 9 Answers
I think either your disk player, or your CD is dirty.
You should probalyly try getting a Q-tip slightly dampened in rubbing alcohol .
and clean the inside of your player.
Or you should try a different disk
Posted on Jan 01, 2009
CDP cx355 cd doesn't spin
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 13, 2015 | Audio Players & Recorders
Nakamichi cd cassette player 1 not spinning discs
There's a Music Bank 7-disc player in use in my bedroom these days. Nice unit, but they used to come in for service once in a while- from what I could tell, these units don't 'park' the CD drawers on a soft power off- they simply shut down. When powered up again, they sometimes let the disc last in play slide off the tray & jam the machine. I've had no issues, as long as I always hit stop, wait for it to park, and then shut off. The analog output's sound has been very good (has a coax out as well).
Jul 28, 2012 | Nakamichi Audio Players & Recorders
Pioneer cdj 400 unit turns on, takes cd, cd spins and then just ejects it.
There are two reasons for this fault. The first one is with its disc loading mechanism. If the mechanism do not place the disc properly on to the reading chasis, this fault can be. It will spin for some time and will ejected automatically
The second one is with its optical pickup unit. If optical pickup unit do not read the disc; due to some fault to it [dust or dirt over the optical lens]. But in this case, there will be only "No Disc" display will be there. No automatic ejection will take place.
With your player, the first sated might be the case. The disc loading mechanism might need replacement.
May 29, 2012 | Pioneer Audio Players & Recorders
Cd will not eject from cd 3.gives disc error message and will not read the cd.. disc errors on cd2 and cd4,but will eject the cd.will not play cds. have unplug both units for an hour. no change...
My first guess would be that the loading belt is slipping. This will prevent the cd from loading completely and thus won't read. The belt costs around $2-$3. Care must be taken when opening up this unit.
Let me know if you need any additional info.
Dan
Sep 30, 2010 | Bose Wave music system Multi-CD Changer...
The cd gets ejected without being read.
As long as it does that on more than 1 disc, it can be a couple of things. The lid has to be taken off so you can see and listen to what is happening. #1 If it takes it all the way in and spins the disc, it most likely cannot read the disc usually because the laser lens needs to be cleaned or the laser is defective. You will hear the lens going up and down, making a clicking noise over and over and then it ejects it. #2 If it cannot load it all the way in and does not even spin the disc, it is usually a rubber loading belt is slipping and needs to be cleaned or replaced. You will hear the motor running and running without taking the disc all the way in. It will never spin the disc, then eject it. Other things can cause it also but those 2 are the first things to look at. :)
May 19, 2010 | Audio Players & Recorders
Disc error in multi disc player and won't eject disc
Some of their models had a small gear that almost falls off a motor used for loading/unloading! The gear may have a small crack in it and also not avalible as a part from "Bosey"! May be found in a car cd changer from Ford.
Apr 12, 2010 | Bose 32022 CD Player
Disc tray does not come out. makes a grrrr sound
Either your mechanism gear which ejects the tray or the belting has worn out. Open up to check both issues. Theres nothing else is wrong with ur player.
Jan 16, 2010 | Nakamichi Audio Players & Recorders
Cdj 1000 mk 2 cd won't go in front load tray
sounds like a cd slot mech problem,if you havent had it repaired you can send it to us.
thanks.
http://www.audiovisualservices.info/
Oct 05, 2008 | Pioneer CDJ-1000MKII CD Player
Discs will not play.
Could be some dirt on laser lenses. Try to clean it.
Sep 25, 2007 | NAD C541 CD Player
Soundspace 8 - Disc eject / play problem
Hi Kev Frey, Have you checked the mechanism for a broken or loose belting or possibly a broken gear teething. With Regards, Edmund
Aug 13, 2007 | Nakamichi SoundSpace 8 CD Player
199 people viewed this question
 Grubhead
Grubhead
