Question about Palm Tungsten T5 Handheld
How do I stop my palm from restarting in an endless loop?
I have just hotsynced my palm and now my palm seems to be going in an endless loop just restarting itself over and over. I've tried the reset button on the back, but nothing has changed.
    President:
  • 1,223 Answers
Pls try these steps first
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=1156,E=0000000000310371479,K=2039,Sxi=10,case=obj(33016)
if it doesnt help pls try to hard reset the device like this
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?New,kb=PalmSupportKB,t=ooccase,case=obj(887)#hard
otherwise update rom from here
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?New,kb=PalmSupportKB,t=ooccase,case=obj(15356)
pls rate me fixya if i have fixed ur problem
Posted on Mar 03, 2009
Hello, it seems my palm Tungsten E2 is not compatible with Windows 7 (hotsync). Anything I can do or is there another PDA that will work? Thanks, I do need the PDA.
you need to uninstall the version of palm desktop that you alredy have and install the 4.14 palm desktop, with the hotsync manager that 4.14 includes you should have no more problems
Feb 01, 2010 | Palm Tungsten E2 Handheld
It won't hotsync, it start to than stops when I get to the what should I do I have a tx
Here are a few things to try:
Check that the HotSync icon in showing in the system tray (bottom right hand side of the screen, next to the time).
Check that USB connections are enabled in HotSync - In HotSync V7.0.2, Right click the hotsync icon in the system tray, Click "Settings...". Click "Connections" on the menu on the left hand side and ensure that the USB option is checked.
Try rebooting your PC and also resetting the device (use a paper clip to reset the device).
You could also try reinstalling Palm Desktop, maybe even remove Palm Desktop, reboot, then reinstall Palm Desktop.
Jul 31, 2009 | Palm Computers & Internet
Why does my palm centro keeps hotsync non-stop
My phone did this today....i look up answers and saw yours..i later called my phone from my home phone and it seems to be working fine as of now, don't have that popping up every minute...once open you will be able to delete the hot sync application. I didn't delete mine yet, I was going to wait it out and see if it starts again. Hope I helped.
Dec 20, 2008 | Palm Treo 500 Centro
Palm Tx problem after hotsync
I had the same issue, the palm is stuck in a loop,
I got mine out of this by pressing the power button while the palm was on the screen where the bar goes across the bottom, it asked me if I wanted to erase all data, I said yes, and it reboot normally, I went thru the setup, and all is o.k.
I did have to try this several times, but it eventually worked. Hope this helps, although it looks like this is an older question. I hope you have resolved it.
Oct 12, 2008 | Palm TX Handheld
Crash after Hotsync
There were some problems with the hotsync working with Vista. I don't know if they fixed them yet. Best bet is to look on Palm.com and see if the current hotsync program supports Vista.
If it isn't listed, it may not support it.
Treo 680
Go to Palm.com and make sure that all of your treo connectivity software is updated. They were a little slow getting it updated for Vista use.
Oct 06, 2008 | Palm Treo 680 Smartphone
Can't install palmone quick install on vista
Vista and quick install work just fine for me.. Here is the process.. Using latest 4.1 from palm.com
you may loose palm desktop data and the users you have created
shut down hotsync, quick install, and palm desktop
go to start.. Programs... Palm desktop
highlight hotsync manager and left click... Go to properties...
Go to compatibility tab and tick run in windows XP mode
select disable visual themes and at bottom select run as administrator
OK that and go to quick install and palm desktop and do the exact same
restart hotsync manager (you will need to allow the program now)
start palm desktop (you will likely need a new user created) (you will also have to allow)
start quick install and poof it will work like new on your vista PC
I struggled with that one for at least 45 min myself but I can now go to quick install and find my application and upload to my palm and sync with ease!
Hope that helps
Aug 17, 2008 | Computers & Internet
Palm 650 stuck in loop
you have to hard reset it. Remove any software that you just install.
May 21, 2008 | Palm Treo 650 Handheld
Pls help me for power on fail
If your Treo loops or freezes during a soft reset, a system reset may help. Performing a system reset allows you to get out of an endless loop in order to uninstall a third-party application causing the looping: 1. Press the Battery Door Release button and slide the battery door downward to remove it from your Treo. 2. While pressing and holding Up , use the tip of the stylus to gently press the reset button on the back of your Treo. 3. When the Palm Powered logo appears, release Up . 4. Delete the third-party application that you suspect is causing the problem. 5. Perform a soft reset. The wireless features of your phone are not available until you complete this step. Good luck!
Nov 23, 2005 | Palm Treo 650 Handheld
Vx to Outlook 2002 failed - no connection Established
hi, on ur palm tap on home , u would see hotsync icon tap on that , on the hotsync page , u would see ur name on top or just welcome , make sure u see direct serial on the same page , tap on the top left corner where it says hotsync in words , in the drop down , tap on lan sync prefs , make sure local hotsync is darker in shade. on the pc make sure u see the hotsync manager at the bottom right corner , if not , click on start , click on all programs , choose palm desktop , inside that u would see hotsync manager , left double click on that , if it doesnt appear at the bottom right corner , try 4times , then if it still persists , restart the pc and try again. Once u see the hotsync manager at the bottom right corner , right click on that , left click on setup , left click on local , choose a different com port , reduce the speed to 9600 , click on ok restart ur pc and try hotsyncin , if it doesnt work try the previous step again and do not forget to restart ur pc , and then perform a hs , it will work .... Regards
Sep 11, 2005 | Palm Vx Handheld
Open Questions:
Palm Tungsten T5 Handheld Logo
329 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
