Question about Dell DJ MP3 Player
My 30 gb DJ turns itself off after about 25 minutes despite a charged battery.
Once the DJ turns itself off all I have to do is push the on button and it resumes where it left off, but it is still a nuisance. I've reinstalled the upgraded firmware which didn't help at all. Any idea where the problem lies? Harddrive, battery? Any suggestions would be appreciated. John
Make sure you don't have a sleep timer or something like that set on it. mine does that too, but i have it on idle shut off, so thats why
Posted on Jul 31, 2007
Philips Gogear Connect 3 8Gb runs out of battery in less than two hours.
I had the same issue. Device would charge in 30 minutes, but would then die in about 40 minutes of playing music.
Solution in my case was to reset. The first time I tried the reset I did it with the device off and that didn't seem to work, the second time I did it with the device on and it worked great. The device showed 8% battery life remaining. I reset and turned the device back on and it showed 93% battery life remaining!(I did not charge it) Since that time I have been playing music through Bluetooth to some remote speakers and still have 91% battery left.
To reset get a pin or knife and push in the small reset button on the non button side of the device.
Good Luck!
PS - If you don't own a Phillips GoGear Connect 3 DO NOT buy one. This problem aside it is the worst mp3 player I have ever owned. And if you subscribe to Rhapsody THIS IS NOT RHAPSODY ENABLED.
Jul 12, 2012 | Philips Gogear Connect 3 8 Gb Digital Mp3...
Wont charge
I would try to open the battery door on the device and remove the battery for about 1 minute and then replace the battery and door and try to charge the unit and turn it on
Jun 10, 2009 | Dell Pocket DJ MP3 Player
Garmin 178C Boots up then shuts off
I've had a similar situation with a Magellan, it would power off despite being plugged in.
Its usually a battery issue, perhaps its not getting enough power? You could try to unplug it and do a "hard battery reset" depending on the type of battery. Keep turning it on and let it run out, until it wont even turn on anymore, after that plug it into a charger while off and allow it to charge completely. Turn it on, see if it still shuts off.
May 26, 2009 | Garmin GPSMAP 178C GPS Receiver
Dell Pocket DJ does not charge using USB Cord
If you find none of this has worked you need to try some other decvie in the same usb port. If it is plugged in and operates correctly, you have narrowed it down to the dj unit. Since the chord has tested good, we should go to the unit itself. Four tiny screws located on the outside of the case need to be removed in order to open it. Carefully remove the hard drive, then the battery.
Now with the cable hooked up to the usb port you will use a meter to check some voltages. Perhaps you have a friend who can help. The batteries should read 3.6 VDC. Measured like that its not a true indication of the state of the batteries, but tell us that the charging circuit is probably working okay.
Put it back together carefully, making sure every connection is properly seated and there is no damage. Try it again, making sure you hold down the button for 3-4 seconds. If you have done all of this, the problem is electronic and at a component level. Suggest you take it or send it to the repair shop dell has.
Ted
Jan 16, 2009 | Dell Pocket DJ MP3 Player
Dell Dj 5 will not hold a charge
FYI, replacing the battery did not solve the problem of the battery refusing to charge. Instead, I've spent $30 at batteryship.com and since I've opened the battery I can't return it. There must be a software or hardware failure that's preventing the unit from charging the battery.
Mar 12, 2008 | Dell Pocket DJ MP3 Player
Dell 30 GB digital jukebox
Dell has a website specifically devoted to Dell DJ users.
Mar 11, 2008 | Dell DJ MP3 Player
My Dell MP3 Player Won't Charge
I had the same problem for weeks. Very frustrating. Try the following as it brought my pocket dj back to life. I found that (while plugged into an AC adapter) by inserting a paper clip in the hole on the bottom (reset button) and holding it there for 5 secs it would power cycle the dj then the charging icon would appear in the top left corner, however it did go away after 5 icon flashes. I did this repeatedly. I noticed that every time I pwr cycled it , I got more icon flashes and it would charge for a bit longer. Finally it charged completely. Weird but this is what worked for my player.
Aug 24, 2007 | Dell Pocket DJ MP3 Player
I charged my MP3 Player, but it won't turn on!
Hi Katie The problem is the battery. I have had the same problem as you and I found only one way to fix it. I don't know if you want to try this your self but I did it and it worked for me and know my DJ Ditty works great. This is what I did. I took the dj ditty apart and cut the battery out but I left the little circuit board between the battery and the ditty I then bought a battery that goes in a ipod shuffle and soldered it in. The battery is a little smaller but works great. If I can be of any help please let me know.
Dec 29, 2006 | Dell DJ Ditty MP3 Player
Dell DJ MP3 Player Logo
37 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
