Question about Krups V50 Iron
Krups V-50 does not turn on?
Plugged the iron in NOTHING! Changed outlets NOTHING! Used 2 days prior No Problem. Time for a new one?
The fuse trips when the iron is switched on
dead short internally or bad wiring in the cord
cord can be replaced by electrician but otherwise junk it and get a new one
Dec 09, 2016 | Irons
Owners manual
Things to try:
1. Fill iron with tap water ... distilled water may cause leakage.
1a. If you have very hard water, dilute with 50% distilled.
2. Fill the iron while upright, then allow to fully heat before using.
3. Use higher steam setting ... lower settings can cause leakage.
4. Allow your iron to "recover" (i.e. build up steam) if you have a spray or "steam burst" button. Trying to use it too rapidly can cause leakage.
Be sure to clean your iron according to your manufacturer's directions. Chances are, that means using a vinegar-water solution to break up any mineral deposits. You can find a helpful video, here: http://laundry.about.com/od/productreviews/qt/vincleaniron.htm
SAFETY FIRST. Try not to work on a hot iron, or one that is plugged in to a power outlet. Water and electricity do not play well together.
Dec 29, 2012 | Bosch Irons
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
Won't turn on. When I plug it into the outlet and
Free with the help of a friend with knowledge. Thank you.
Nov 02, 2009 | Rowenta Commercial Garment Steamer - White
My iron isn't turning on. It sounds like its turns on but the warming light doesn't turn on and it doesn't warm up
Check the plug end of the cord for a bad connection. If unsure, buy a replacement plug at a hardware store, cut off about 1 inch of cord and install the new plug. Make sure a lamp works in the outlet that you are using.
Sep 14, 2009 | Irons
Iron stopped working suddenly
perhaps the thermostat is sticking.as irons are cheap to replace i would try cleaning /soaking the tank to remove lime scale. or strip the iron down checking thermostat and conections.
May 01, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Light comes on, but iron will not heat up
oliso iron turns on when plugged in green light flashes but iron will not heat up
Feb 13, 2009 | Irons
Just stopped heating
Unless you have a 5 or 6 hundred dollar iron, there is an excellent rule of thumb when an iron quits working. Buy a new one. These days, irons can be purchased cheaply enough that it is WELL worth the money. Not just for the convenience, but for the safety issues. This is an appliance that could burn your house down even if it's in PROPER working order. Hope this helps!!
Chad
Oct 04, 2008 | Toastmaster 3302 Iron
Why isn't my Iron heating up? Just finished filling my Krups V65 iron with water. Was ironing linen shirt on linen setting, all of a sudden, heat dropped all the way down to light one (very low heat) and...
I do believe the thermostat is defective.All the iron have a small thermastat top control the temperature and is working like a switch.If the switch don`t work get stuck on the same position.Unfortunatly sometimes is better get a new one themn fix an old one but this is The Market and nothing i can do personally.Also make sure the thermostat knob is working properly.If you hear a click when you turn is ok.
Good Luck
Jun 12, 2008 | Irons
Cleaning a self cleaning iron
Fill the Iron with water but keep the water level below the max line. Plug in the iron and set the temp to 6 and stand iron on it's heel and allow to heat for 3 mins. Now unplug the iron and take it to a sink move and Hold the variable steam dial in the CLEAN position. There may be some hissing and spitting while cleaning so be careful. Continue to hold the dial in the clean position until all the water has emptied. If necessary rock side to side and back to front to get all the water out.When finished release the steam dial plug in the iron and heat for about 2 mins to dry out the remaining water and unplug.
May 22, 2007 | Black & Decker D2030 Iron
Krups V50 Iron Logo
Top Krups Irons Experts
Are you a Krups Iron Expert? Answer questions, earn points and help others
