Question about Dishwashers
My Kenmore Ultra Wash Diswasher is stuck on the wash cycle.
It just keeps running on the wash cycle and won't move to the next steps of the cycle. I was told that it may be the timer motor, but I find no timer motor on the parts list. There is an electronic control panel. Does the electronic panel provide the timing function?
  • 3 more comments
  • jim6576 Jan 02, 2009
    There is no screen, just a buttons to push and indicator lights.
    The heating element checks at 16 ohms which is within the range of the factory specs.
    I guess I don't know how this site works. I can't see all the added comments at one time. Nothing I have seen yet solves my problem.
    I've attempted to post the model number a couple of times but it dosent show up. Here it is again 665.16767000
    Why can't I see the entire thread with all comments?
    Genius:
  • 1,011 Answers
Sir,
Here is the link for some basic tips to how to maintained the diswasher. check out may be u solved ur problem
thanks
good luck
Posted on Jan 02, 2009
  • Asfiya Ahamed
    Asfiya Ahamed Jan 03, 2009
    Check this link
    Also it may be a bad door switch or fuse - or bad control panel. Some tips do it yourself
    thanks
    good luck
  • Dishwashers Master
  • 8,220 Answers
Sadly the timer may be gone but you can oil it if it is mechanical. If it is digital then replace or clean the gook off the sensor.
  • 82 Answers
Hi , the probleme is electric timming , take a photo whow it s plug, to make sure to remember , take it off and go buy a brand new and install let me know yvon Chow !!!
    Scholar:
  • 86 Answers
Hi, I see in the other posts that you are being pointed in the right direction. The heater! Some of these units have a T.O.C. (Thermal over load cut out ) This could have been activated some also are of the re-setable type which would just mean pushing a button to put the heater back in the circuit and fixing the problem. If it is not of the push button type then the heater will need replacing. If it does heat, could it be over heating??? This then could be a thermostat problem. If yours is an electronic P.C.B. type of dishwasher then it could be the board that is the problem.. Check the easy things first and move on to the more expensive things later on,,,,,
Good luck.............
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, it may indeed be the controller which is an electronic timer or the logic board. Still, your post "It just keeps running on the wash cycle and won't move to the next steps of the cycle" is significant. I suspect that his indicates that the wash cycle has not really completed, did it drain? Before considering anything else, try the basics, check/clean the filter, sump/bowl, drain valve, impeller, pump, hose (kinks). Additionally, most washers would have a tech sheet behind one of its panels or under the controller panel. The tech sheet would have a listing of possible faults and user action to address them. In most, there would also be an electrical diagram which may be of further help.
Pls post back the exact model number.
Good luck and Thank you for using FixYa. Happy New Year.
  • Louie  Role
    Louie Role Jan 02, 2009
    You posted that you have checked the heating element, have you checked the thermal fuse that is in series with the heater?
    President:
  • 2,110 Answers
  • Sibananda Jena
    Sibananda Jena Jan 02, 2009
    if you do have a timer motor that has
    failed, consider replacing just the motor itself and not the entire
    assembly. Timer motors can be considerably cheaper than the complete
    timer assembly.
    Before
    you can begin to test your dishwasher's timer motor, you must first
    locate the device. It is a part of the timer assembly. Timer assemblies
    are located either in the control panel at the top of the dishwasher
    door, or behind the lower kickplate at the bottom of the unit.
    To get to a timer located in the unit's control panel, first examine
    the outside of the appliance. Sometimes, depending on the model, you
    only have to remove a couple of screws in order to remove the outer
    control panel. In other cases, you will have to remove either the
    entire internal door panel, or the entire external door panel. In each
    case, the panel can be removed by removing anywhere from 6 - 10 screws.
    Be careful to not remove the screws at the very bottom of the door that
    are actually a part of the hinge assembly. Removing the hinge assembly
    screws will remove the entire door from the appliance, which is not at
    all necessary to test the unit's timer. With all of the screws removed,
    the door panel should be easy to lift off of the door assembly. If you
    have difficulty lifting the panel, look for other screws you may have
    missed. There may or may not be a smaller control panel cover. If you
    do discover one, it will be held in place with either a couple of
    screws or a couple of clips.
    With the dishwasher's control components fully exposed, you may
    discover that your model uses two timer motors. The second one will be
    a rapid advance motor. It is operational when the wash cycle is
    cancelled or reset. If you are unsure which timer is which, then test
    each of them.
    To
    get to a dishwasher timer located behind the lower kickplate at the
    bottom of the unit, simply remove the few screws holding the kickplate
    panel in place. With the panel removed, you will be able to identify
    and locate the timer and its motor.
    There will be two wires extending from the round motor housing. Follow
    the wires until you locate the connectors. Label the wires so that you
    will be able to reconnect them later in the right positions. Carefuly
    remove the wires. Do not pull on the wire itself. Needle nose pliers
    may be needed to pull gently on the wire connector.
    Set your ohmmeter to the x 1000 setting. Take each probe and touch it
    to one wire. A normal reading for most dishwashers is in the 2000 to
    3500 ohms range. Try to locate a schematic for your dishwasher. It
    should be in one of the service areas of your dishwasher or in the
    owner's manual. This schematic should indicate the proper resistance
    reading for your specific timer motor.
    If the reading you receive from testing your timer's motor differs
    greatly from the range presented here, then you should replace your
    timer motor, or the entire timer assembly.
  • Sibananda Jena
    Novelist:
  • 163 Answers
Is there any error code on the screen?
  • ronny2051 Jan 02, 2009
    read the following ---
    The cycle doesn't complete
    If the cycle doesn't complete, check these:
    Water-heating cycle
    Timer
    Water-heating cycle
    Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
    On some units, the pause is timed and the unit continues after the allotted time.
    On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
    Timer
    Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
    I see an error code
    If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
    try another in place off.
  • 69 Answers
Yes more than likely the control board is bad. Thats the problem nowadays, everything is so hitech, to many things to go wrong.
How do I check and see if pump is out on kenmore diswasher 665. Will pump out but not wash
Get a current monitor or meter (the Kill-a-Watt meters available at Fry's Electronics and eBay for about $20 to $25 is a good easy-to-use current-monitoring tool) and connect it to your dishwasher. Turn it on and start a cycle. After the dishwasher fills, the main pump should run. Watch the current. If it jumps up to a few amps (even briefly), then current is going to the pump and it's not running. If you don't see any increase in current, then it's probably your controller. (The drain pump is a separate pump from the main wash pump, so it can work and the main pump may not.)
Feb 15, 2015 | Kenmore Dishwashers
My Kenmore Elite Ultra Wash Dishwasher keeps shutting off before entering the cycle. I have repositioned dishes, even emptied it, changed cycle and tried everything. When I press the start light flashes...
I too had problems with the Kenmore Elite (aka Bosch). The issue was solved by replacing the Lock Sensor on the door. After replacing the sensor the dishwasher has been working. Hope this helps.
Oct 08, 2013 | Kenmore Elite 24" Built-In Dishwasher with...
Kenmore washing machine won't agitate?
You are referring to the "agitator dogs". Does the unit run during the wash cycle put the agitator does not move?
Nov 24, 2012 | Kenmore Washing Machines
Kenmore ultra wash diswasher top rack not cleaning
see please the next video for your fix it: God bless you
Jul 21, 2012 | Kenmore 24" Built-In Dishwasher with Ultra...
Kenmore Ultra Wash 3 (6651694193) stuck in wash cycle
There should be 2 thermostatic switches in the heater area. They are just simple bi-metallic "button" switches.
One will trip at the correct temperature - and tell the programmer to advance now the water is hot enough. The other will cause a shut-down if the water is over heated.
It is the first one you need to replace - I wouldn't bother testing it.
Obviously - disconnect everything before opening up (I have to say this) and only if competent to carry out a repair.
However - you don't know which is which?
To test them. Remove one, put inside an empty can , and put 1" of water in a pan onto boil. Test continuity with a meter when cold - and when sitting in boiling water.
Turn off heat, and see which trips first. That is the over-temperatue one. When a little cooler, the other should trip. This low setting one is likely the faulty one - so will not trip or contacts will be faulty.
These are available online from various appliance retailers.
Aug 15, 2009 | Dishwashers
Brand new ultra wash HE stuck in one cycle
Does it fill with HOT water (check after fill stops)? Did Sears install the washer? If so, have them troubleshoot the problem. It's obviously bringing water in. Are there any error lights or codes? May need to replace the control unit.
Jul 14, 2009 | Dishwashers
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore diswasher gets stuck between the quick rinse and drying cycle
I am having the same issue as described above. I think it is either the timer, thermostat (temp assure), or thermostat (temp boost) that needs replacing. The dial gets stucks in both the wash temp boost cycle and rinse temp boost cycle. However, I don't have a picture of the temp assure or boost part. Does anyone know how to fix this? Thanks. -Bill
Aug 31, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
1,633 people viewed this question
Top Dishwashers Experts
