Question about Sony Handycam CCD-TR517 Camcorder
Sony model ccd tr5. eject button will not open tape compartment.
Is there a manual way to open and remove casette?
4 Suggested Answers
hardrocko
  • 1476 Answers
SOURCE: troubleshooting sony handy ccd-trv 107e
The first thing you should try is removing the batteries for 20 to 30 minutes to reset the unit. If this does not work push in on the cassette mechanism at the top while trying to eject. Also check the tape compartment cover screws to make sure they are tight. Any misalignment in the cover mechanism will cause binding which will create the problem you describe. Finally, and I know this will sound unusual, slap the unit on the cassette side. Forcefully but not enough to break anything. This procedure has been helpful many times with similar problems. I know it is not sientific but hey if it works. If none of the procedures solves your problems you may need professional help. The following websites offer free estimates: http://www.camcorderrepair.com or http://www.videotech.com or http://www.videoonerepair.com Good luck
Posted on Jul 24, 2006
SOURCE: Sony camcorder HDV 1080i model HVR A1U won't eject
Sony A1U stopped functioning. Neither AC power or battery yields anything. Reset button yields brief flash only. Tape stuck in machine. Help?
Posted on Sep 19, 2010
LongPockets
  • 1177 Answers
SOURCE: I have a Sony Video8
This problem can be caused by condensation. Leave camera and tapes in a warm dry place for a day and try again. If that doesn't help, there may be a tape threading fault. This can be something as simple as a broken drive belt, but still will require professional attention.
Posted on Oct 28, 2010
SOURCE: Have a Sony CCD V9 camcorder. Stored it for years
Use a hairdryer to warm up the cassette area. My camcorder did same thing and this worked.
Posted on Apr 09, 2011
CCD-TRV32 won't eject tape
Its better if you get it serviced by an authorized service center,If its not in warranty then try for any local mechanic.If you try to manually open it there is a very possible chance of any kind of damage.
Jul 29, 2012 | Sony Handycam CCD-TRV32 8mm Analog...
I have a SonyCCD-TRV21 and the casettte tape wont eject.
hello flame!
possibilities:
no power - recharge battery or use power supply (might also battery broken)
tape stucked - ccd must be opened and cassette must be released manually (might also casette mechanism broken) this is service issue.
regards
Thank you for using FixYa! A four thumbs up rating is appreciated for answering your FREE question.
Mar 26, 2011 | Sony Handycam CCD-TRV21 Camcorder
Can not eject
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
Aug 11, 2009 | Sony Handycam CCD-TRV318 Camcorder
The cassette is stuck and the player will not eject it. when you turn it on it just makes a beeping noise.
Aug 11, 2009 | Sony Hi8 CCD-TRV138 Camcorder
It does not eject the tape,it gives out error c3211
Reel of the cassette must be stuck inside. open the top cover and have a look inside. release the reel if it is tangled up inside. Reset the switch at the bottom of the frot pannel and try to eject the cassette. It will slove your problem. If it is not then you must consult the nearby sony service centre.
Aug 07, 2009 | Sony DSR-45P DV / Mini DV VCR
Manual eject option for trv320? No tape in it. Won't open so I can put one in.
Aug 06, 2009 | Sony Handycam DCR-TRV320 Digital Camcorder
Can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Oct 14, 2008 | Sony Handycam CCD-TR416 Camcorder
Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
Jul 24, 2008 | Sony Handycam CCD-TRV37 Camcorder
Code 32:11 will not eject tape sony tvr67
The mechanism got stuck. Open the cassette compartment screws and apply external DC to the Power input and eject the tape. If this is not possible refer to a skilled technician. If you need the service manuals and mechanism for replacement write to us.
Dec 07, 2006 | Sony Handycam CCD-TRV67 Camcorder
Sony Handycam CCD-TR517 Camcorder Logo
239 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
sonic boom...
sonic boom...
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
