Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Console panel won't go back in
I had to replace the lid latch on my Whirlpool LTE5243D washer/dryer. I was able to remove the console panel and make the repair but I can't get the panel back in. There are two console latches on the ends that move up and down with a spring. Does anyone have any ideas?
  • 2 more comments
  • mikewp23 Dec 31, 2008
    http://shared.whirlpoolcorp.com/assets/p...
    I already made the repair -- the entire control panel is what I'm trying to get back into place. I attached the parts list, hopefully it might help to see what I'm working with.
  • mikewp23 Jan 01, 2009
    Part # 31 is preventing the console from going back into place. There are springs sitting underneath the console locks (# 31) and they are only accessible when the console is flipped down.
    Note the springs that keep the locks in place. Perhaps they're in the wrong position?
    FYI: For anyone that is having a similar problem, here's the solution:
    Put your fingers in the side of the panel and press down firmly to push the slider down. The panel will lock into place when you release.
    Seems pretty obvious now :)
    Thanks for everyone's comments.
  • Whirlpool Master
  • 8,220 Answers
The lip of the front slides under the base and sits on two tabs on the base. Ease the case forward and make sure the plastic tub hose is not pinching or you will get overflow. Plug the lid switch in and snap down the S clips.
Posted on Dec 31, 2008
  • 1 more comment
  • Dan Webster
    Dan Webster Jan 01, 2009
    The console has hinges right? You stick those tabs in the holes after rotating down the console and push them backward into place.Then put the screws in. I would think this is not too hard.
  • Dan Webster
    Aggrevating ain't it? I would get some long screws and attach it back on either side if it was mine.
  • Dan Webster
    I will have to make a note of it. Thanks
My LTE5243D top load stacked washer is about 10 years old. How do you take the front panel off to access the washer's motor coupling?
To gain access to the washer components, the front panel between washer and dryer must be removed first.
Remove the two top screws securing thethis panel to the unit.Tilt the transition panel down and pull itstraight out.Remove the two screws located behind the washer top.Pull the washer top forward to disengage the top locks. Disconnect the washer lid switch harness. Lift the washer top off the unit.Remove the two screws from inside the top of the washer front panel.Lift up on the front panel to release the catches near the bottom of the panel andremove the front panel.
Apr 24, 2012 | Whirlpool LTE5243D Top Load Stacked...
Washer does not drain or spin. don't know how to release the plastic release latches to access the lid switch.
On that stack washer/dryer the wayto get to lid switch is
remove diagonal panel between washer and control panel
in the back of washer top will either be 2 brass colored clips or in the very back egde of top will be 2 5/16th inch hexhead screws
for clips place a small screwdriver in front of that clip and pop clips off and slide top forward
for the screws remove screws from behind top in the left/right corner..pull top forward a bit and lift up a little the plug for the lid switch will be in front right side..squeeze the release for that plug,unplug swicth plug then remove top
in both cases lid switch asm. will be on right side of top on the underpart of it
Gene
Aug 23, 2011 | Whirlpool LTE5243D Top Load Stacked...
How to shut off dryer end of cycle beep. Can u run
If the model number is correct, the dryer End of Cycle signal cannot be adjusted or turned off. The informatrion is listed on page 11 of the Owner's Manual:
http://www.managemylife.com/mmh/owner_manuals/16695/WHIRLPOOL-Laundry-Centers-L0710382?brand_name_search=LTE5243D
The only way to turn the signal off, is to remove the operator console, locate the signal (buzzer) module and disconnect the wire(s). The buzzer is listed as item 32 under the "Washer/Dryer Control Panel" parts listing:
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-dryer-combo-Parts/Model-YLTE5243DQ2/1198/0152000/W0702346/00001?blt=06&prst=&shdMod=
CAUTION: If you choose this option, make sure you UNPLUG the washer/dryer before servicing anything inside. If you disconnect any wires, make sure you cover them with heat shrink or electrical tape to keep them from coming into contact with anything else.
The washer and dryer use a common power source, but the rest of the functions operate independently of each other. You can safely run both units at the same time.
If need further assistance, please let me know. I hope this helps you.
Aug 09, 2011 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool thin twin stacked,won't agitate or spin
whirlpool washers have a drive coupling in between the motor and the transmission to replace this remove the top and disconnect the lid switch set it aside remove the front panel then remove the 2 clips that hold the pump on then push it out of the way then remove the 2 screws that hold the motor clamps on and then remove the upper and lower motor clamps remove the motor then replace the three piece "motor coupling" one piece goes on the motor the other three pronged plastic piece goes on the transmission and the rubber isolator goes between them and now just put every thing back together
Mar 31, 2010 | Whirlpool LTE5243D Top Load Stacked...
Lid switch replacement
Some washing machines have the bolts that hold the top down situated behind the front panel but you have to remove the panel to gain access.
There may be 3-4 screws at the bottom of the front panel, remove the screws and the panel should come out.
Hope this has helped
Jun 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
The top of washer
take down the front acess panel that divides the washer from the dryer in front,,,but if you can get behind it theres a green metal clip on the rright and left ,right behind the back of the top remove those two screws than slide forward ,,remove lid switch connection on front left hand corner...its off,,,att; always unplug first
Dec 08, 2008 | Whirlpool LTE5243D Top Load Stacked...
Dryer Drum belt replacement
first unplug unit..remove front panel 2 screws..under the bottom side of timer console there is 2 pin or scews on each side pull down firmly,or if screws untighen slowly...just let console hang..now you can see the 2 screws holding bottom of front panel door.remove theses 2 screws..now step up on stool remove the 3 screws across the front top of unit,,theses screws are facing the ceiling..now remove door switch connection.remove front ,,you about there if belt has pop remove,if you have to replace a damaged belt..take your right hand and go though machine unit you fell the idler wheel on right side back pull down and take belt of idler wheel and motor pully at the same time ,,if you cant get ittake you left hand and help from the left side..to put back just reverse,,always unplug..
Nov 04, 2008 | Whirlpool LTE5243D Top Load Stacked...
How do I access the pump so that I can repair or replace it?
the pump is directly connected to the motor. the dryer section must be removed. next the washer console must be removed. next the top comes off. next the side front and side come off as one piece. it unbolts from the bottom and back plates.
Sep 10, 2007 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
61 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
