Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite Flashing PF
Is there a reset button? If so were can I find it.
  • 15,935 Answers
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
I have Kenmore elite oasis electric dryer when you push start button it goes to pf code ive tryed holding down start button & it just flashes & is back to pf code how do I reset it ?
try unplugging it from power or tripping the circuit breaker(which might be easier). then re energize it and see if it resets. good luck.
Jul 29, 2016 | Kenmore Dryers
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
10 year old sears kenmore elite dryer, PF light will not stop flashing even after holding start for 10 seconds or after holding stop button for 10 seconds
Hello & Welcome to FixYa
PF error means power failure which is generally caused when the control board inside the unit goes bad. You can try unplugging the unit for 15-30 minutes, if the issue returns then the control board needs replacement. Please get back to me if you have any other questions.
Kevin
May 12, 2011 | Dryers
Mi secadora electrica oasis kenmore elite aparece un codigo PF que significa eso como puedo resolverlo
PF means power Failure unplug hold the cancel button for 3-5 seconds if the pf doesnt disappear then unplug the unit for 7 minutes this will make the control reset on the board if the pf still doesnt fade then you would have a control issue and most likely have to replace the control or call a technician if you have any further questions message me back and please remember to rank how this opinion has helped when our chat has fully concluded Thanks Rick
Feb 26, 2011 | Kenmore Elite Oasis 6809 Electric Dryer
I HAVE THE PF CODE FLASHING ALONG WITH THE HIGH LOW OFF LIGHTS AND PRESSING BUTTONS DOESNT WORK
Hello
PF error code means Power Failure, it is displayed when the unit is either not getting enough power or the power board also known as the electronic control board has gone bad and needs replacement. As pressing buttons doesn't work then first unplug the unit for 15 minutes and then check, if this does not help then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Nov 20, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Oasis 110.67087600 Dryer will not power up. No power at all. Prior to this it had a PF flashing. House power checked good.
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
If no-go.. the timer is failed due to a power spike and must be replaced.
Apr 26, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore Elite dryer shows a flashing PF
pf,,power failer...just unplug for 30 seconds,,,
Dec 31, 2008 | Kenmore 659 Electric Dryer
Kenmore 67082 "PF" power failure code
Check your circuit breaker. Reset it even if it doesn't look tripped. It is a dual switch and sometimes you can't tell if one of them is tripped. Then try it. When you reset the breakers leave them off for about 10 minutes before turning them back on.
Dec 24, 2007 | Kenmore 67082 Electric Dryer
Kenmore Elite 45986 Front Load Washer Logo
196 people viewed this question
Sal De
fordexpert
Robert Rankin
