Question about Infinity BassLink II Car Subwoofer
Infinity BassLink II Keepps Cuting Out!
Hello everyone, I like infiniy subs and speakers for the car. I have a baslink 2 that i installed and it works, but there is one problem. If i turn up the vol too loud it will ct off and stop working until i turn off the honda 07 fit sport head unit and then turn it back on again. Why is that? I have amp and remote on and ground installed and i am useing the front speakers has line in. Is i because i did not ground the basslink 2 right? Please let me know what can cause this type of problem. I love my honda fit sport 07 sliver so much and the bass link 2 in my friends car is so good. i want it to work good for me too. Thanks for all the help. Yasir Faheem
  • 106 Answers
Auto cut is due to overload, check out the wattage handling capacity of the Amp & the woofer( if the impedence is too low there will be an over load for the Amp.
Posted on May 06, 2007
Infinity Basslink. I wired and connected everything and sounded amazing. I removed my center console to construct a box to put the Basslink in. When I was putting the Basslink sub into the box (tight fit)...
I would get a test light and see if the remote line is still working. Otherwise, yes you probably fried it. Doesn't take much in car audio to fry an amp.
Jan 17, 2014 | Infinity BASSLINK Car Subwoofer
I have a 2005 Mitsubishi Eclipse with the Infinity high end stock radio installed, which has a 200 watt amp under the seats. The head unit does does not have direct speaker outputs. The head is connected...
I am going to refer you to the live help
at crutcfield.com audio
They can give you ideas on compatible equipment and designs that will achieve your desires without the OBVIOUS overlad/mismatch.
Your search for comparison returned these articles
Free factory (usa market) wiring diagrams
BBB Industries Premium Alternators Starters Power Steering Products
Mar 11, 2017 | Infinity BASSLINK Car Subwoofer
Where to purchase vertical mounting feet & bolts for Infinity sub
Simple as it sounds, try Home Depot/Lowe's! They will have them! Been there, done that!
Mar 30, 2010 | Infinity BASSLINK Car Subwoofer
I need the wires to conect my infinity basslink 10''
Any auto parts store or WalMart will sell adequate speaker wires. For a sub of this power rating, you'll be fine with 14GA speaker wires (pronounced 14 gauge) but if you want to get beefier wires in case you upgrade the sub later, I'd recommend this 10GA hookup kit or something comparable.
Feb 13, 2010 | Car Audio & Video
My sub woofer wont turn back on
Hello austin_optiz,
If you have had 2 units with the same problem, I'd say that yes, there is a problem with the "sound sensing" function of the auto turn-on circuit. Either it's not getting the correct level or one side is being shorted or grounded. Some vehicle speakers may have one side at ground potential which could cause the auto turn-on to fail.
If the Basslink operates normally otherwise, I'd recommend that you just connect a 12V + fused and switched source to the remote terminal. Wire it through a conveniently mounted toggle switch and turn it on and off manually.
Hope this helps.
Oct 14, 2009 | Infinity BASSLINK Car Subwoofer
Infinity Bass link keeps cutting out.
Tapping into front or rear gets high level signal 3 plus volts at low impedance which is totally unsuitable for the sub's line level input which is more like 300millivolts > A competent tech could make up an attenuator patch or just take it to a professional car installer before you do more damage
ataraxia
Jan 15, 2009 | Infinity BassLink II Car Subwoofer
Basslink keeps cutting off into protection!!
From what i have heard, If you have a speaker level input connection. this sympton does occur. You buy a scosche LOC and try giving the input to Basslink, it should work fine
Jun 24, 2008 | Infinity BassLink II Car Subwoofer
Basslink II problem running off speaker input
Definately a wiring issue. Go to this site and backtrack to see where you went wrong. hope it helps.
http://www.ehow.com/how_5829_wire-car-stereo.html
Dec 12, 2007 | Infinity BassLink II Car Subwoofer
Light is always on!
yes the problem is in the installation.the power supply usually has 2 to 3 positives one positive which is usually red go directly to battery. the other,either yellow,orange,or blue go to car stereo(not to battery or ignition) this supply,turn off the amp when u turn of the stereo. hope this help u....
May 09, 2007 | Infinity BassLink II Car Subwoofer
Infinity BassLink II Car Subwoofer Logo
906 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Richard Lukszys
Richard Lukszys
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
