Question about Nikon Coolpix S50 Digital Camera
The camera displays "Memory card is write protected"
The write-protect switch is in the proper position. A replacement memory card produced the same message.
  • 1 more comment
  • ht61 Jan 05, 2009
    My question has not been answered nor a solution to the problem proposed.
  • ht61 Jan 05, 2009
    The card was formatted in a computer. The same message was displayed. If I format the card in the camera I will lose the photos on it.
  • ht61 Jan 06, 2009
    I believe the problem is a faulty micro switch in the card slot. Thank you.
    President:
  • 846 Answers
First off you can plug the camera in using the USB cord or if you have a card reader just insert the card into it. It should show up either way in MY COMPUTER, right click and format the card that should allow you to write to it.
I hope this will help you. Drop me a comment if you still have problems. I will help you.Your vote is highly be appreciated
Posted on Jan 05, 2009
  • Nikon Master
  • 19,396 Answers
Try first formatting the card using the camera menu, if you still get same error the memory card is probably defective and does not accept the format.
In that case replace the memory card.
  • 3,037 Answers
Hello ht61
have you tried more than one memory card? if so, does this happen on others as you may just have a faulty memory card which is a 1 out of 100 chance.
Otherwise there is sensor inside the camera that senses the little switch in the memory card. That sensor is supposed to have pressure on it only when the little switch on the memmory card is locked. Use a light and look inside the memory card slot in the camera and look for a little micro switch that may be jammed and when released should bring the camera back to working state.
If that doesn't work, then check your manual for the brands of memory cards recommended for Nikon and if that doesn't help, then I don't know what to tell you. I think personally it is the micro switch on the camera itself that is the problem. let me know if you have any further questions and good luck
bestdarngood
Posted on Dec 31, 2008
  • 104 Answers
See if there is a lock on the site of your memory card. Some memory Card comes with Lock that can be pushed to unlock!
  • Vanbiak Thanga
    Vanbiak Thanga Dec 31, 2008
    Oh you should have already unlock the memory. Well you can try the Card with another Card reader if it is LOCK
  • 10,594 Answers
Format memory card through camera menu format option and try.
  • Shahid Electronics
    Shahid Electronics Jan 06, 2009
    by formatting memory card, you will lose photo data, but there is no other way to correct this memory card.
    And problem still exist, then memory card is damaged and format will not correct it. Need new meory card.
  • 177 Answers
What did the card say?
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
When i switch on my digital camera write protect message is displayed on it , my camera is olympus fe-190
If your camera uses a SD memory card then the write protect switch maybe on.
SD and Micro SD memory cards has a smallslide switch on the edge of the card, which write protects data on the memorycard. Slide the switch from the READ position tothe WRITE position, which is furthest away from the contacts.
May 06, 2012 | Olympus FE-190 Digital Camera
How to take off card protect problem, I can't take pictures with a memory card on because the "card protect" notification displays on the screen of the camera. how to fix?
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 30, 2011 | Cameras
Have canon rebel xs , getting card write protected error
If this is a Canon Rebel XS there is no memory card in a 35mm film camera If this is a Rebel XSi then generally this error is caused by the memory card lock switch here is a diagram to show the correct orientation of this switch
Diagram
Also after you have unlocked the card you should format the memory card in the camera it is going to be used in. Failing to do so may produce other errors and possibly corrupt pictures and files Formatting clean the memory card to produce optimum performance between the camera and card
Jan 18, 2011 | Canon EOS Rebel XS 35mm SLR Camera
What does it mean when my nikon coolpix s60 displays Memory card is write protected?
It means the card has been protected from writing, preserving its current contents.
Take the memory card out of the camera and look at it. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 08, 2010 | Cameras
Memory card is protected (reset switch on memory
make sure that the slider switch on the actuall memory card itself is not in the locked position
Jan 19, 2010 | Cameras
"memory card is write protected"?? but it's not the memory card!
It's not the camera. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jan 13, 2009 | Nikon Coolpix 4500 Digital Camera
Memory card is protected how do i switch on memory card when i turn camera on, message reads that the memory card is protected and to reset switch on memory card. what happened?
Oct 11, 2008 | Kodak EasyShare CX7330 Digital Camera
Sep 26, 2008 | Kodak EasyShare One Digital Camera
"Memory card is protected"
This error message indicates that the memory card is locked. The switch on the memory card is in the write-protect position. Reset the switch as shown on the camera screen.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Nikon Coolpix S50 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
