Question about Mercury Electronics CyberPix S-555V Digital Camera
My camera is not starting up after i put a 4 gigs SDHC card need help i pull the card out but it still doesn't start
  • ayman_ap Jan 01, 2009
    dude the max is 2 gb but i tried removing the 4 gb card but still my camera won't start
    do u have any more helpful tips or solution
    thx for the help
    & thx for replying back so fast
    Genius:
  • 2,985 Answers
Read thre Manual- It is likely you have an oversize card.
The manual will tell you the max size card the camera will handle
Posted on Jan 01, 2009
Easyshare z981has stopped taking pictures, eaven tho installed with new 34 gig card
Is it a 32 or a 34 Gig card? Does it say SDHC or SDXC?
because the SDHC should work, but the SDXC can't work in your camera.SDHC cards go to max 32 Giga byte. Above 32 G, it is SDXC.
Please don't forget to format the card in your camera the first time you put it in the camera.
Don't trust a format done in the computer. Or even formatted in an other camera from the same brand or same model, can cause trouble.
Mar 19, 2014 | Kodak Cameras
Can't format 4 gig sdhc card in kodak easyshare M575
Have a look at the memory card, you should see a tiny slide switch to lock the card.
Goto
http://kb.sandisk.com/app/answers/detail/a_id/1102/~/memory-card-is-write-protected-or-locked
for explianation
Nov 26, 2011 | Kodak EasyShare M575 Digital Camera
I can not get our memory card to format. it says card error. we are using a microSDHC Ccard with adapter 4gb
Is the camera compatible with SDHC? If it can only handle SD memory cards this card is not readable in the device. It will show on the camera whether it is compatible with SDHC. If it doesn't have the logo, take it as the card won't work and you'll need to get a normal SD card.
There is a theoretical maximum of 2GB for SD memory cards, SDHC start at 4GB and go up to 32GB.
Simply put, if your camera is quite old, it won't support SDHC and therefore is limited to a maximum of 2GB memory card.
Jul 26, 2011 | Cameras
Will an 8 GB SDHC card work with a kodak easyshare cx6230? We put it in and it says we need to format, but it won't format. Message says to use another card.
These can usually only hold 2 to 4 gig cards. Many only do 2 gigs or less. On the other hand some can handle more memory but only certain brand names.
Dec 31, 2010 | Kodak EasyShare CX6230 Digital Camera
I have bought a 4 Gig SD card but my camera won't accept it
If it's a 4 GB card there is a chance your camera doesn't have SDHC support.
SD cards 4 GB and over are called SDHC cards and your phone may not have the ability to "talk" to the card.
Jul 09, 2010 | Kingston 4GB Secure Digital High Capacity...
SDHC Card 4 GB SanDisk will not format. get
The Z740 uses SD cards, not SDHC cards. SDHC cards will physically fit into the card slot but are not compatible. It's a hardware incompatibility, not updatable in firmware. You'll have to stay with 2GB and smaller SD cards.
Feb 06, 2010 | Kodak EasyShare Z740 Digital Camera
When 4 gig. sd hc memory card is loaded into camera CARD IS IN ERROR msg. appears on lcd screen. Any ideas???
The A10 uses SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into the slot, they are electronically incompatible and will not work with the A10. You need to use SD cards, 2GB and smaller.
Apr 12, 2009 | Pentax Optio A10 Digital Camera
Maximum memory size of sd-card for canon ixus 40 ????
Check to see if your 16GB card is an SDHC card. If it is, your camera is not compatible with SDHC. (The SDHC protocol was developed after the SD300 came out in 2004).
Feb 23, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Kodak 7590 New SD card will not format
Is this an older camera? If so it will not support sdhc cards. Sdhc is a 4+ gig card. You will need to buy a card 2 gig or under.
Jan 29, 2009 | Kodak EasyShare DX7590 Digital Camera
New SD Card wont work - all the others I have do!!
I believe any SD cards larger than 2Gb are technically SDHC cards, which are not compatible with all cameras. Kingston is a decent company so I'm guessing it's not because the card is a dud. If your camera doesn't advertise SDHC compatibility then I don't think you can get the card to work in it.
Oct 27, 2007 | Casio Exilim EX-Z57 Digital Camera
Mercury Electronics CyberPix S-555V Digital Camera Logo
123 people viewed this question
Top Mercury Electronics Cameras Experts
Are you a Mercury Electronics Camera Expert? Answer questions, earn points and help others
