Question about Whirlpool LGR8648 Gas Dryer
No heat in gas dryer
Polit light seems to be out. how do i light it safely?
    Sergeant:
  • 311 Answers
Hey it dose not have a pilot your dryer has an ignitor.if you have a volt meter with the ignitor exposed you need to check voltage to the ignitor.if voltage replace ignitor,if no voltage re place thermal fuse you can see how the electricty travels by looking at thr wiring diagram
Posted on Dec 31, 2008
Home heating broiler will not heat new water pump installed polit is lit, it pops for about five minutes , like it,s going to come on ,nothing
It is most safe ,when it comes to natural gas and propane or oil heating system you should get help from local service centre for all safety
Dec 08, 2013 | Heating & Cooling
Tip
Gas Dryer not Working Gas Dryer Not Heating
If your gas dryer is not working because it is not heating then you need to check this out. Today’s gas dryers often do not use the simple thermocouple with a pilot to prove the flame anymore. They use a much more complicated method of lighting the burner and proving the flame.
The use of electric igniters has become the standard for many dryers today. The thermostat calls for heat, power is supplied to the igniter, then after a certain amperage draw on the igniter, the gas valve is energizes to open and allow gas to flow starting the flame. As long as the amperage draw on the igniter is high enough then the gas valve stays open till the thermostat is satisfied.
Sometimes the igniter will crack and no current will go through and the igniter will not even heat up or glow. Sometimes the igniter will wear to the point where it will still heat up and glow, but the current draw will not be high enough to allow the gas valve to open. This creates a confusing situation where you look into the dryer and see the glow from the igniter, but get no heat because the burner never lights up. If this is the case then you will need to replace the igniter even though it seems to be okay. The only way to know for sure is to know what the current draw requirements are for that gas valve and to have an amp meter to check the current draw.
Most of the time the problem will be in the igniter, and not the gas valve. Gas valves can go bad, but that is the case in only a very small amount of the situations. It is a pretty safe bet that if you have a problem with you gas dryer lighting that you have a problem with your igniter.
http://www.fixya.com/support/r4312805-dryer_maintenance
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
on Mar 23, 2010 | Dryers
Polit light
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101,.,.';';
Jul 28, 2011 | Dryers
Drier has no heat. Seems to run fine, otherwise. might I nee d to re-light the pilot through the small hole in the front of it?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 24, 2011 | Kenmore 60172 Electric Commercial Dryer
Heating problem
If you are smelling gas in the house, stop using the dryer, close the shutoff valve on the gas line behind the dryer & call your local gas co to repair it. It may not be a leak, but a problem with the burner lighting properly, but better safe than sorry.
May 15, 2010 | Kenmore 73952 Gas Dryer
It seems like the burners are not all lighting. Maytag Epic Z gas
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 11, 2010 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
Gg40t6a polit light will only light when polit button is held down.i have cleaned the thermo coupler and orfice at no avail.
Does the gas flame fully heat up the coupler
if not then clean out the gas jet nozzle
if yes then replace the thermo couple
Feb 11, 2010 | General Electric GE SmartWater Household...
Gas dryer not heating
REPLACE THERMAL FUSE #3392519 AND CLEAN YOUR VENTING GOING TO WHERE
IT EXITS THE HOUSE.
Jan 13, 2009 | Roper RGS7646KQ Gas Dryer
My dryer is ot blowing hot air
Remove the heater vent, then turn dryer on. Does this fix problem? If so then you have a block in your vent hose.
Dec 31, 2008 | Kenmore 75962 Gas Dryer
Neptune Drying Center MCGAWW (No Heat)
Sorry no pilot light but you have ignite, flame sensor and a gas valve...all control heat...
let me know if I can help
krazytech
Mar 30, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool LGR8648 Gas Dryer Logo
163 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
