Question about Toshiba Cinevision DVR2000
I lost the remote to my sonicblue dvd player dvp650?
I have a oneforall remote i just need to know how to program it the code for the dvd player
Try this URL for the manual: http://www.hifi-remote.com/manuals/
Posted on Feb 23, 2009
I need to find the codes for the sony dvd player on the urc-3021B00 remote
Try the codes: 0533 1533 0864 1033 for a Sony DVD player.
The code list for the URC-3021 is available from One For All here: http://www.oneforall-na.com/remote.php?type=URC%203021 . The manual and the code list is available here: http://www.oneforall.com/uploads/support/00a1e876ce84e35c2c0351a407218d66.pdf .
Please note that the codes available in a universal remote are limited to those for devices released 6 months or more before the remote was programmed. If your DVD player is newer than your remote, you may need a new remote. The first URC-3021 was released in 2004.
I hope this helps.
Oct 19, 2011 | Televison & Video
Need code for rca dvd on a urc3220 oneforall remote
Try the codes 0522 0571 0717 for an RCA DVD player.
The code list for the URC3220 is available here: http://voxxsupport.com/images/User%20Manuals%20-%20FAQ%27s/URC3220codes.pdf .
Please note that if your remote is older than your dvd player you may need a new remote. The codes are usually limited to those for devices released 6 months or more before the remote was programmed.
I hope this helps.
Oct 13, 2011 | One For All Remote Control
I have a GoVideo DVR 4300 that has been child locked. I have lost the remote control. Is there any way to unlock it with out the remote?
According to page 16 of the owner's manual, you cannot disable child lock without the remote. Because you have lost the remote, the unit does not offer a manual way to disable that feature. I am not sure if a universal remote will allow you to enter the setup menu, and turn the child lock OFF. You could try that - it might work.
Or you could try contacting them:
Phone (480) 922-0896 or (800) 736-7679 (during business hours)
E-Mail customersupport@sonicblue.com
Web www.govideo.com or www.sonicblue.com
They may or may not be able to offer further assistance. The universal remote might help, if you cannot get the original replacement for your unit.
Personally, child lock in DVD players is a pointless and unnecessary extra feature that should not exist; it should really only apply to Blu-Ray/DVD recorders.
May 06, 2011 | GoVideo DVR4300 DVD Player/VCR
How can I change my Sony RDR-VX530 to a multi region DVD planer?
Follow the below instructions closely;
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
* Press the DVD button
* Hold down the Magic button until the unit performs a double LED flash
* Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
* Press the Magic button once
* Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
* Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
* Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
* Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
* Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
* Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Good luck.
Jan 14, 2011 | Sony RDR-VX530 DVD Recorder/VCR
I just need the codes
Try this website, the instruction manual & code manual links are right below the picture of the remote. http://oneforall-na.com/remote.php?type=URC4220
Dec 10, 2009 | One For All URC4220 Remote Control
Maual for ALL FOR ONE UCR 7740 REMOTE CONTROL
Hi if you go to there website www.oneforall.com you can download any manual you need and find any codes you want.
Dec 29, 2008 | One For All URC 7740 Remote Control
Need DVD remote control code.
This would be the place to go:
http://www.oneforall.com/webwizard/index.htm
or
Welcome to Remote Central: Universal Remote Control Reviews & More!
They both have loads (more than I ever want to know) about universal and learning remotes.
tom
Dec 14, 2008 | LG DR787T DVD Recorder
Is it multiregional
Sony are probably the most protective manufacturer of this kind of information. All manufacturers carrying a DVD logo are obliged to say "no" but will normally intentionally leak this to boost sales, particularly in non-US areas.
But try this:
  • Press the DVD button
  • Hold down the Magic button until the unit performs a double LED flash
  • Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option 3. On your DVD recorder, using the official Sony remote, select the Setup option 4. On your DVD recorder, using the official Sony remote, select the Options option 5. On your DVD recorder, using the official Sony remote, select the Command-Mode option 6. On your DVD recorder, using the official Sony remote, select the DVD1 option 7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover 8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player 9. Program your OneForAll remote with the following instructions:
  • Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
  • Press the Magic button once
  • Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
  • Press the 1 button once, a double LED flash should occur
  • Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
  • Press the 2 button once, a double LED flash should occur
  • Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
  • Press the 3 button once, a double LED flash should occur
  • Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
  • Press the 4 button once, a double LED flash should occur
  • Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
  • Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode 15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time 16. Your DVD player should show the words TIMER OK 17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time 18. Your DVD player should return itself to Standby mode 19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Nov 27, 2007 | Sony DAV-S500 System
Toshiba Cinevision DVR2000 Logo
363 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
