Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
Kitchenaid stand mixer oil leak - KitchenAid KSM90 Ultra Power Series Stand Mixer
  • 1 more comment
  • popziv4 Jan 04, 2009
    Leaking dark oil from head, over beater area.
  • Anonymous Feb 05, 2009
    leaking oil from head over beater area
  • Anonymous Mar 01, 2009
    OIl leak from a fairly new mixer.
  • 135 Answers
Hi. The grease that your mixers are lubricated with has reached a stage where the oil is leaching away from the grease. All your machines need this grease changed. Shell Darina EP-2 or Chevron FM ALC EP-2. These machines need to be internally cleaned and re-greased. It's important to remove the oil from any place that it drips. The planetary gear must be removed, cleaned and re-greased also. It's a messy job, but you can do it yourself if you're familiar enough with machinery. If not, then a suitable service outlet can easily do it.
If you choose to do it, go to the Kitchenaid website and locate the parts files for your particular model, these drawings will assist greatly with the project. If you can, take digital photos at every step of dis-assembly as a reference for re-assembly. If this solution assists you, please rate it. Good luck! ricardok45
Posted on Mar 06, 2009
    President:
  • 267 Answers
Common problem , main bushing bad cannot be replaced by user . sorry .
Posted on Jan 15, 2009
3 Suggested Answers
SOURCE: kitchenAid stand mixer is leaking alot of oil
ok, there are 4 skrews holding the body together on its white underside( or what ever color you have.) after you get those there are like 9 or 10 little skrews under a shiny rig that goes around the shaft that does all the work in the bowl. pull the ring off and take out those skrews. after that... well i have to find out for myself how to fix the oil leak! good luck and if you find out let me know! BTW here is a link to the service manual.
http://store.mendingshed.com/k45map.html
Posted on Dec 29, 2008
  • 718 Answers
SOURCE: oil is leaking
KSMC50
K5SS
K45SS
KSM90
I am not sure of the model you have but you can get a general idea of the internals from;
http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
It looks as if you have an oil seal failure. The parts for your machine model may not be available. You can try and use a close match from another model if not.
Some parts may be available from Sears;
http://www.searspartsdirect.com/partsdirect/index.action
If you have a service company do it, it may not be cost effective. In which case you can sell the machine for parts "as-is" now and cut your losses.
If you want to repair the machine and have some mechanical skills you can disassemble the machine and do the repair.
Note the following points.
) You only need to concentrate on the gear/oil part of the unit.
) Check for the point the oil is leaking from.
) When you disassemble avoid damaging seals and gaskets. You may need them as a reference to find or make a replacement e.g. if the leaking in from a gasket and you can not buy a replacement you will have to cut your own from a gasket kit.(hardware store item) If the leak if from a rubber seal on a shaft you will need it as a "show and tell" at the hardware store.
The oil will need to be replaced.
Posted on Apr 30, 2009
My kitchenAid stand mixer is leaking oil. How do I
referring to:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%204176924.pdf
You can see that there are 5 screws holding the upper and lower gearcase together. They pinch the gasket number 26 together and prevent the oil and grease from leaking. Remove the chrome ring by prying gently around the ring. You will see the 5 screw heads. Tighten them and the leaking will stop.
If it still leaks then you may have to replace the fiber washers number 29 which will involve disassembling the lower gear case.
Mar 30, 2010 | KitchenAid KSM103 Professional 5 Series...
My stand mixer was stored on its side and leaked oil.
Called the Kitchenaid toll free number and found a local authorized repair center. Not a fixya solution, but at least a solution.
Oct 01, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Leaks oir or grease at shaft where beater attaches
eaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
If you still feel as though the mixer is in need of service, you may locate Kitchenaid certified repair centers through the following link: http://caservice.kitchenaid.com/
Jul 15, 2009 | KitchenAid K45SS Classic Stand Mixer
The mixer leaks oil around the shaft. Is this a user repairable problem? How do I find service centers?
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Jul 10, 2009 | KitchenAid K45SS Classic Stand Mixer
Leaking oil
Jun 27, 2009 | KitchenAid Classic Stand Mixer
My mixer is leaking oil. last time we made bread dough in it it sounded kind of rough. we figured wiyh the heavy load maybe that was the rteason for the noise. when we moved the mixer to clean it, there...
May 13, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid 250 Watts; Classic: Leaking Oil
Found this,may be helpful.
Why do I see oil leaking from the beater shaft of my stand mixer?
Some KitchenAid® stand mixers that are not used very often or have been tipped may experience slight oil leakage from the shaft or hub attachment. To avoid the oil leakage, KitchenAid suggests that you run the mixer weekly for short periods of time. Generally, the mixer may lose approximately X cup of oil before repair is necessary. The oil used is FDA approved and is not harmful to consume, should any get into the food that you are preparing.
Dec 15, 2008 | KitchenAid K45SS Classic Stand Mixer
My kitchenaid mixer is leaking from the part that spins?
I took mine apart and all the grease had settled down around the shaft in the housing due to lack of use,found no seal.Going to spread grease back up on gears,see what happens.I found this at KitcheAids web site.Good luck.
Dec 01, 2008 | Food Mixers
Leaking oil at the base
A TV show "How it is made" was in the Kitchen Aid factory and they used a thick grease and no oil in the mixer. Does your unit get hot? Maybe its melting the grease (dark brown)..
Oct 25, 2008 | KitchenAid KP2671 Professional 6 Series...
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
1,224 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
