Question about Panasonic GigaRange KX-TG5240M Cordless Phone
Answering machine rings busy?
I recently switched back to my phone's answering machine rather than the phone company's service. Now my anwsering machine only rings busy and does not take a message. I have tried everything mentioned in the manual "trouble shooting" section. Please advise what is wrong. Thank You
cnavarro
  • 2460 Answers
SOURCE: Digital panasonic kx-t7633
The 7633 has a FWD/DND button. Is it blinking, lit solid or dark? It's designed to be pressed 3 times for FWD DND or OFF....It's programmed as follows, assuming that 500 is your voice mail access code:
From the intercom dial *7101. That sets DND. Dial 710x 500 # to set call forwarding where x-2 for all calls 3 for BUSY for for NO ANS 5 for BSY/NA. 7&8 are FOLOW ME commands and they have a different set of instructions ie Dial *7107 plus your extension to have calls come to the phone you're at and *7108 plus your extension to cancel it. I have never seen it used. *7100 cancels all forward and DND arrangements from your phone..
This is just hte command set for ALL CALLS. You can also set up forwarding for Outside Calls and Inside calls seperately and you can program buttons to do the forwarding.
Your Panasonic dealer has 2 manuals that you would find interesting, one is the TDA Operating Manual and the PTPM Manual. The operating manual has a complete set of programming instructions for the manager and users of TDA systems, the PTPM has a complete set of programming features that can be performed from a Panasonic 76XX display phone.
THe pdf's aren't huge and they can be sent to your email address if you provide one under the Ask Me button.
Carl
Posted on Oct 01, 2008
rockitman187
  • 2559 Answers
SOURCE: How do I retrieve messages on the Panasonic KX-T7030 phone?
  • Call into your mailbox (usually by dialing intercom 165)
  • Press 4, and 4 again (for "Incomplete call handling")
    By default, three options are enabled:
    option #1: leave a message
    options #5: call the operator
    option #6: return to top menu
  • Follow the audible prompts to disable options 5 and 6
Here are some other features you may need
  • Make sure your Auto Answer button is lit up, so you can receive intercom announcements, and respond hands-free.
  • Use the Call Forwarding (FWD) to send un-answered calls to another phone or to voicemail
  • Press BGM (or 1 on the touch-tone pad) for background music, if your system is equipped.
  • Use Absent Messages to show text messages on other people's phones when you are away.
  • Use System Call Waiting so your phone will ring even when you're on the phone. Press Intercom and dial 7311 to set it up, or 7310 to cancel.
  • Use Do Not Disturb (DND) when you don't want to receive calls. Press Intercom, press FWD/DND and dial 1 to activate, or 0 to cancel.
  • Press MESSAGE when you call a busy intercom number. This will turn on the MESSAGE light on the other phone, and the other person can tap that button to automatically call you back.
  • If you get a busy signal when you call an intercom number, you can signal the other person by dialing 1 (if that phone is programmed for System Call Waiting (above).
  • Dial 330 to make an announcement to all phones.
  • If you want your phone to automatically select an outside line when you pick up the handset, press PROGRAM, dial 99, dial 12, press STORE, press PROGRAM
  • Posted on Feb 12, 2009
    Vit Avaya BP
    • 211 Answers
    SOURCE: Line 1 of my phone is always busy.
    From your description it sounds that you have a short on your Line 1. Its either on DMarc of your carrier or it cross connected improperly. However your post is not clear on voicemail. In normal operation if busy it doesnt go to voicemail.
    Call your carrier first and report troubled line. Their technician will tell you what to do next.
    Posted on Mar 16, 2009
    SOURCE: Lost manual, need to change # of rings before machine answers pho
    hey u can chk in our Fixya site
    http://www.fixya.com/support/p475286-panasonic_kx_tg5632_phone/manual-19838
    there are pages u can go thru this Showing Page 1 out of 64
    hope this help u
    Posted on Aug 06, 2009
    SOURCE: kxa144azt cordless phone answering machine problem
    push int then# this is the menu for the answer machain um 00000 is the security code used to reset or reassign the hand pice
    Posted on Mar 04, 2010
    Hooking up fax to KX TG7871 Panasonic Phone
    There is excellent support here on basic fax setups. You have what is known as "Distinctive Ringing Service". There are pros and cons to the various setups. I assume you recognize the rings and answer only when the ring for the landline talk comes on. The fax will pick up the faxes, and the answering machine will pick up the voice.
    Need model number of your fax - google that!
    Service manual for your phone.
    http://service.us.panasonic.com/OPERMANPDF/KXTG7841-MUL.PDF
    This link shows various configurations of setting up your phone/fax/answering machine or using an answering service.
    http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00059780#Dist_ring
    Distinctive Ringing Service setup While it is not available everywhere, a distinctive ringing service can be purchased from most telephone companies. With this service, more than one phone number is assigned to the same phone line. Each phone number will ring differently. The main number will ring with a normal single ring and the additional number will ring with a distinctive ring pattern assigned by the phone company.
    When a distinctive ringing service is used, set the Rings to Answer to 2 and then follow the steps below to set the distinctive ringing pattern:
    1. Press Setup , press 4 , and then press 1 to enter the Answer Ring Pattern setup of the Advanced Fax settings.
    2. Use the Right Arrow to scroll through the available settings. When the ring pattern assigned by the phone company displays (double or triple rings), press OK .
    Mar 06, 2014 | Lands Phones
    THE ANSWERING SYSTEM WON'T RECORD MESSAGES,ALL MESSAGES GOES INTO POOVIDERS VOICE MAILE, AS IF MY PHONE IS BUSSEY?????? I CHECKED AND RECORD TIME IS NOT SET TO ANNOUNCE ONLY ANS ALL MESSAGES HAVE BEEN...
    This happens when the number of rings to answer of the provider voicemail is less than the number of rings to answer that the answer machine is set for. For example: if your provider voicemail rings to answer is set for 3 rings and the answer machine is set for 4 rings then the voicemail answers before the 4th ring, therefore the answer machine will never get a message. I would call the service provider's customer service number and request they increase the rings to answer above the number of rings to answer that the answer machine is set for. If you don't want voicemail to answer any calls(when your line is busy or when the answer machine is turned off) ask your service provider to disable voicemail.
    Mar 30, 2011 | Uniden Cordless Phone
    Does not wait for the 4th ring; sends call to verizon voice mail box after the second ring
    Sounds like your service provider(Verizon) has your phone line setup to forward to voicemail on no answer after 2 rings. Call your service provider's customer service number and request that the number of rings for forward no answer be increased to at least 5, then your answer machine can receive and answer your calls after 4 rings but if your line is busy callers can leave a message with your Verizon voicemail service. If you don't want Verizon voicemail to answer any of your calls, you could have them disable the voicemail service. When you call the service provider have a recent bill ready because they may request your account number before they will make any changes.
    Feb 25, 2011 | Uniden EXA15580 Cordless Telephone
    After 3 phone rings anwsering machine is on,iwant after 5 rings answering machine should on.I have 29888ge1 answering machine
    The "Changing the Settings" section begins on the third column of the manual at
    http://www.home-electronics.net/USER-GUIDES/29888_DOM_EN_AN_IB.pdf
    Oct 15, 2010 | GE 29888GE1 Digital Answering Machine
    How do I program the line redirection feature
    If you switched phone companies and the feature stopped working you probably had Call Forward Busy/No Answer from AT&T. If you use the call forwarding in the phone it will use two phone lines for the entire length of the call. Call Comcast and have them add Call Forward Busy/No Answer and tell them the number you would like your calls forwarded to and the ring cycle (the number of rings on no answer).
    Mar 05, 2010 | Nortel T7316E 2-Line Corded Phone
    Our AT&T 1725 has quit recognizing when the phone is ringing. The phone keeps own ringing instead of beign answered.
    There are a couple of things to try. First is to check the cable & plug that connect the 1725 to the telephone line. Disconnect the phone line from the back of the answering machine, plug it into a known working telephone, using cell phone (or another land line) call the phone number and see if the phone rings.
    If it doesn't, replace the line cord and try again.
    If it does ring, check the optioning to make sure it is set for, say 2 rings.
    Also, is the telephone line a regular telephone company POTS line or is it one that is being provided by a cable modem? If your phone service is being provided by a cable company, the media converter might not be putting out enough voltage for the answering machine to realize that the line is ringing.
    If everything is correct, replace the answering machine.
    Aug 18, 2009 | AT&T 1725 Answering Machine
    Can I use cordless phone answering machine even if I have voicema
    You do not have to cancel the phone company voice mail service. You need to change the number of rings the phone uses to answer the voice mail.
    For example, if the telephone company voice mail answers if 4 rings, set the telephone answering machine to answer in 3 rings or less.
    Good luck.
    joequevedo@charter.net
    Mar 03, 2009 | GE 27992GE5 Cordless Phone
    I HAVE A CANNON PIXMA MP830 IAM USING A ANSWER MACHINE ON MY PHONE I HAVE MY CANNON PIXMA ON "ANSWER MACHINE CONNECT" MODE SETTING BUT WHEN A FAX IS SENT TO ME THE PHONE RINGS THE ANWSER MACHINE...
    the connection should be phone cord to the fax then to the answering machine. answering machine answers first (rings to answer must be lower than the fax).
    Nov 21, 2008 | Cannon Office Equipment & Supplies
    Fax problem
    unplug the fax from the phone line. call it from you cell.if you hear your phones ringing in the house, plug the fax machine back into the jack. [you should still be on your cell phone] if the line goes dead or stops ringing, there is a short with the fax machine or wire to the jack.if you hear a busy signal without the fax plugged in, unplug everything you have plugged into phone jacks thruout the house. call your # again.if you hear ringing on your cell phone, plug everything back in one at a time.[again while still on your cell phone] if it was one of the phones plugged into a jack, when you plug the shorted phone back into the jack, the line will go dead again. that phone or cord is the problem.
    if still rings busy when everything is unplugged, then call your phone company. it can be an inside wire or jack problem, or the problem is outside your home.
    hope this helps
    wg
    Feb 05, 2008 | HP Officejet 5610 All-In-One InkJet...
    Fax ring tone or ring leader
    im sorry to say the machine you have does not have DRD distinctive ring detect.
    Jan 21, 2007 | Panasonic Workio DP-2330 Printer
    Panasonic GigaRange KX-TG5240M Cordless Phone Logo
    Top Panasonic Lands Phones Experts
    Henk de Ruiter
    Henk de Ruiter
    Marvin
    Marvin
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
