Wont focus model #p56812bl wont focus
    Genius:
  • 2,920 Answers
There is a focus control in the back of the tv
Posted on Dec 31, 2008
Broke orignal key for ford focus kept the chip and got new key cut now immobiliser wont knock off
Have a Ford dealer cut you a key. For a modest price most will with the VIN number, model, make and year of your vehicle.
Sep 01, 2012 | 2005 Ford Focus
Hi i got this TV from my uncle he said it was making a "cheeping like" sound so i said i would take it, im a sophomore at a tech school and have good experience with electronics work (I'm...
Hello matter0464 and a warm welcome to Fixya. The issue you are asking about is actually rather common with the RCA P56812BL after it gets a few years on it. The problem is most likely the high voltage circuit located on the main board. I would start there before looking elsewhere. Also inspect the 195 AP fuse on the main board as well because it is known to blow out periodically. Well I hope this was helpful and good luck to you. Thanks for using FixYa.
Apr 26, 2011 | RCA P56812BL 56" Rear Projection...
It wont turn on, there is no sound of an electrical current
The first thing to try is to unplug the unit for 30 minutes and plug it back in and try it. If the unit had a temporary glitch in the software it should reboot and clear the problem and work. If this does not solve your problem I have a tip at
http://www.fixya.com/support/r6396176-projection_tv_troubleshooting
which will walk you through the troubleshooting procedure for a crt projection tv.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 05, 2011 | RCA P56812BL 56" Rear Projection...
Colors are out of focus and magic focus wont fix
Go to Encompass Parts Distribution and type in your Model number they have free service manual you can print out on line. they also list 393-399 Parts for this model.
May 08, 2010 | Hitachi 57F500 57" Rear Projection...
RCA P56812BL, Flickering Static like lines
Check all inputs and tuner, that you can, and report back.
Apr 19, 2010 | RCA P56812BL 56" Rear Projection...
What can be wrong with the tv when when only sound can be heard and no vision seen?
that depends on the tv. We need the model number to try and help you more with this.
Mar 17, 2010 | RCA P56812BL 56" Rear Projection...
D52W26
call RCA and give them a M# thay you send you the not cheap.
or go to part store.comor rca part.com
Mar 30, 2008 | RCA P56812BL 56" Rear Projection...
Rca model p56812bl
I would try soldering the flyback terminals on the PC board and also re solder around the Horizontal and vertical yoke pins as well as the transformer and line coils. Rca has ad some problems with bad solder problems on the circuit boards. let me know if I can assist you further.
Jan 23, 2008 | Televison & Video
No pic no sound just ticking
This set normally has problems in the horizontal and high voltage circuit. The horizontal output will short out and I often change the high voltage transformer. The high voltage splitter is another one of the usual suspects. Since it's ticking at plug in, then, I would look at the secondary of the high voltage transformer or the regulator circuit. Checking the the horizontal output first for a short and if ok, checking the B+ voltage on the collector would be my next step. That should give a good thought as which direction to go. Hope this helps.
Apr 01, 2007 | RCA P56812BL 56" Rear Projection...
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
