Question about Samsung HCM4216W 42" Rear Projection Television
Where i could buy a Bulb ?
First, my tv stop to work properly, she's turning on and off by itself, and no image, only the sound. I open the rear and when i touch the left projector ( from the rear view ) he fell off. The bulb is broken. I would need your expertise to know where i can buy these bulb. And if somebody have a some informations about how changing this bulb, i will really appreciate. THANKS A LOT !!! P.S. After i change the bulb do i have something special to do? Or just turn it on ? THANKS AGAIN !!!
    Scholar:
  • 77 Answers
Try partstore.com, the lamp will come as an entire assembly. The whole case. just loosen the two screws and slide it out. You shouldn't have to do anything afterward, check your menu and see if there is a timer to reset, but aside from that nothing.
Posted on May 06, 2007
Turned itself off. I turned it back on and the green power light blinks for awhile then blinks red for awhile.no picture or sound
Get rid of this TV. Had one and replaced the bulb and light engine many times. Just buy a Samsung or Vizio 50+ inch instead and be very happy. Those Panasonic projection TV's were terrible. You will find a 50 inch Vizio for around $500 bucks and it will blow your mind how great the picture looks.
Oct 16, 2014 | Panasonic PT-50LC14 50" Rear Projection...
My rca 52inch rear projection tv would shut off then come back on know it won,t come at all is it possable it is a bulb help wayne
this model does not use a bulb, but has 3 picture tubes. Most common problem for this is bad solder connections under the high voltage transformer.
Nov 29, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
My Samsung HLP4663W 46 in was making a buzzing noise for several months. I know it could have been either the fan(s) or the color wheel, but I never opened it up to determine which it was. Now the TV quit...
Great reasoning work! In fact, the lamp will not light if the color wheel does not spin-up. Fans will not stop the process of lamp ignition. Instead, a fan will be detected and a message will appear on the screen telling which fan has stopped. You need to have the color wheel replaced.
Mar 15, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Mitsubishi wd-52825. red lamp indicator, new lamp installed
Failed caps on the power supply will cause that. The V26 Power pwb repair kit will usually correct that issue. Its available from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Oct 30, 2009 | Mitsubishi WD-52825 52" Rear Projection...
Sony WEGA Large Projection TV
I sounds like the projection bulb has failed. I think there is a red lamp on the front that lights up when the bulb fails however.
This sounds very similiar to what mine did when the bulb failed about 2 months ago. Once the buld fails the TV will shut itself down and keep doing that until the bulb is replaced.
Dec 17, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Panasonic pt 50dl45 shuts off buy itself
You probably have a lot of dust inside.
Open the back panel and vacuum.
Also use compressed air to blow into the components. Do not blow into the fan on the right as it will get the dust inside the lamp housing.
Oct 15, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Mitsubishi 57" HDTV - has sound and timer light flashes
I had the same problem and my local repair guy soldered a defective sensor so that it goes around that problem. I also had to buy a new bulb. Now my picture is "cloudy" and the repairman has no idea why. I am waiting for them to call back on it.
Mar 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sony 55" rear projection tv
TIGHTEN THE BULB --AFTER YOY CLEAN THE DUST OFF THE BULB VENTS ON THE BULB ITSELF. PROBLEM SOLVED. EASY--CHEAP. Hey it worked for me. My picture was turning off blinking 29 times for picture 37 times for audio. This was the first issue with my KDF-55WF655 since I unwrapped it almost 5 years ago......... ITS STILL ON!!! I hope this helps someone.
Feb 14, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV Turns off and on
How long since the last time the bulb was replaced? It sounds like the bulb is overheating and triggering a safety shutdown.
It's probably in need of nothing more than a good cleaning (open it up, clean off the boards with a can of air) and *may* be time to replace the bulb.
Nov 13, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Red light blinks 3 times
When the senior service tech changed our bulb, I watched very carefully, and he said there is an electrical contact towards the rear of where the bulb goes in that bends very easily and that care is required not to damage or bend that connector. His assistant tech then bent the thing, and the senior tech had to straighten it out properly. All the while, he talked about how delicate this connector is. Hope this is helpful to you. It sounds like what he was talking about.
Oct 29, 2007 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Samsung HCM4216W 42" Rear Projection Television Logo
46 people viewed this question
Jerry Greenberg
Jerry Greenberg
