Question about Thule Atlantis 1200
Cracked thule storage box-want to fix it-How?
How do I fix a cracked thule lid that broke when we drove it into our garage?
  • 1 more comment
  • sarajthigpen Jan 04, 2009
    I need help repairing a cracked thule lid.
  • bstanleypa Feb 04, 2009
    Same problem - somebody (me?) left the garage door open-but-not-quite-all-the-way, and assuming it was open I backed our Thule car-top carrier into the door, cracking the carrier. Still has it's general shape, but is cracked and would definitely leak rain if used without fixing.
    Help?
  • davidtomahaw Feb 08, 2009
    Same thing here. What glue or adhesive would be best?
Use Devcon High Strength Plastic Welder Epoxy for Vinyl, PVC Piping, Fiberglass,etc. Line up the broken area as best you can and apply the mixed epoxy on the interior side as well as the exterior side. Do not overwork. It gets stick and lumpy fast. Apply it while it's smooth. With this epoxy you have about 5 to 7 minutes before it starts to get real sticky. Use the edge of a thin cardboard box to apply. I used a piece of a cardboard nail box I had laying around. Don't use your good puddy knife because you'll never get it clean. Let it dry - about 15 minutes. Do the process again until you've got it covered well and as smoothly as possible.
Don't be alarmed as this epoxy is a creamy color. After the epoxy has dried, use a fine sand paper to sand it off. Wipe the sanded area clean with mineral spirits. Then use a glossy black spray paint to touch it up. Coat it with the spray paint several times while letting it dry in between sprays. It won't be perfect but it will be waterproof.
Posted on Jun 19, 2009
    Sergeant:
  • 209 Answers
Hi Fixya community, this question is dated, but for the sake of adding to the body of knowledge here... my story.
I have the popular Thule Atlantis 1600 which for reasons that still escape even the high volume vendors, has been discontinued as originally set up. A large (8 metres) branch fell on my Thule box splitting the upper carcass in many directions (both seams and field areas), in addition to the complete break of a front lower segment. I acquired the box for the features it represented, now broken, wanted to buy a new one --- wait... it is discontinued. While I was able to finally find one after much searching, I decided to try and fix the broken one. Well I have to say, it worked out great, and did not involve expensive epoxy, adhesives, hot air welders, or any of the methods most commonly referred to.
Thule's cargo boxes are made from ABS plastic. The same black plastic material used for your household domestic waste plumbing systems. Rather than use foreign (non-ABS) as your binding agent, simply use ABS. By keeping the joint material native, you are essentially re-establishing the continuity of the original material.
Take a small pieces of ABS pipe (any scrap will do, just ensure it's ABS -- will say on the side) and grind it down in shavings. I used a rotary cutting tool with a bit that looks like a common router bit for rabbit joinery. This resulted in very small shavings. Accumulate enough shavings and place in a small glass jam jar with a lid. I had to cover roughly 1.5 metres in crack length and found ABS shaving volume equal to a couple marsh mellows to be plenty. Here's the magic.... pour a small amount of Acetone into the jar and stir the contents (outside as it fumes) -- add more as needed just to get it to the consistency of carpenter's glue.
After you have bound the cracked segments of your Thule from the outside (I used rubberized packing tape as it great horizontal field strength but can be removed easily). The tape up doesn't have to be pretty, just ensure the edges are tight and tape is firmly holding it tight. On the inside, use a rotary cutting tool and any cutting bit to grind a trough directly where the cracks are. I when down approximately 3 millimetres and across approximately 8 mills. I left it rough to the touch.
Clean the trough with Isopropyl alcohol; let dry. Using a small paint brush (ones you find in elementary school water colour paint kits is fine) "paint" the trough with the dissolved ABS in your jar. The advantage here is the Acetone in the mixture dissolves the edge of your trough so both the slurry (your mixture) and the hard carcass body are naturally bonding. As you might imagine, the Acetone will evaporate leaving nothing behind but ABS -- as hard as the original, fully bonded to the original material. Once dried, apply additional coats to build up the trough to your preferred profile.
Remove the tape on the outside and you're set. You could apply some sealant to the outer surface of the cracked area, but I did not as keeping it clean to look at is difficult.
Good luck.
Posted on Feb 04, 2015
Supposedly heating a strip of similar plastic the size of the crack should work. i am going to give it a shot
Posted on Mar 08, 2009
How to fix a thule weekender roof box to the roof bars
eTrailer has published information on mounting the Weekender --- attached here for your convenience.
Good luck.
Thule QM3 Quick On Off Mounting Hardware Kit Recommendation for 1997 Thule...
Oct 18, 2012 | Cars & Trucks
Strut on Thule Atlantis 1600XT popped off. How do I re-attach it?
Put your carrier on a pair of saw horses and clamp down firmly then open the lid as it now stable and clamp your strut with a wide jaw wood clamp. Apply just enough pressut to start the ball into the socket and finish with your hands. Steve Parks
Jun 23, 2012 | Thule 686 Atlantis 1600 Cartop Carriers
Hinge Replacement, Thule Thule Atlantis 688T 2100 Cargo Cariier
Hi Erroll,
What I believe you're referring to is the 'locking hook' -- the piece attached to the lid that slides into the lock mounted on the bottom segment of the cargo box. While it acts like a hinge in respect of the closed side of the Thule, what the mfg refers to as the hinge (or also referred to as a strut) is the spring mechanism at the front and back used to hold the lid up.
You can acquire this locking hooks online - attached a link for your convenience.
Good luck.
THULE ATLANTIS 200 from Exeter Roofracks Roofboxes
Apr 28, 2012 | Office Equipment & Supplies
Backed into garage with silver thule on tahoe and caused several cracks about 6 ins long would like to repair so it will be water proof as it is still in good shape thanks.. Barry
I believe, but am not sure if the 'silver' is paint over the black cover. If it is, the way I repaired by own, may help you.
A large (8 metre) branch fell on my Thule box splitting the upper carcass in many directions (both seams and field areas), in addition to the complete break of a front lower segment -- see photo. I decided to try and fix it despite finding a replacement. Well I have to say, it worked out great, and it did not involve expensive epoxy, adhesives, hot air welders, or any of the methods most commonly referred to. Thule's cargo boxes are made from ABS plastic. The same black plastic material used for your household domestic waste plumbing systems. Rather than use foreign (non-ABS) material as your binding agent, simply use ABS. By keeping the joint material native, you are essentially re-establishing the continuity of the original material.
Take a small piece of ABS pipe (any scrap will do, just ensure it's ABS -- will say on the side) and grind it down in shavings. I used a rotary cutting tool with a bit that looks like a common router bit for rabbit joinery. This resulted in very small shavings. Accumulate enough shavings and place in a small glass jam jar with a lid. I had to cover roughly 1.5 metres in crack length and found ABS shaving volume equal to a couple marsh mellows to be plenty. Here's the magic.... pour a small amount of Acetone into the jar and stir the contents (do it outside as it fumes) -- add more as needed just to get it to the consistency of carpenter's glue.
After you have bound the cracked segments of your Thule from the outside (I used rubberized packing tape as it has great horizontal field strength but can be removed easily). The tape up job doesn't have to be pretty, just ensure the edges are tight together and the tape is firmly holding it tight. On the inside, use a rotary cutting tool and any cutting bit to grind a trough directly where the cracks are. I went down approximately 3 millimetres and across approximately 8 mills. I left it rough to the touch. Clean the trough with Isopropyl alcohol; let dry.
Using a small paint brush (ones you find in elementary school water colour paint kits are fine) "paint" the trough with the dissolved ABS from your jar. The advantage here is the Acetone in the mixture dissolves the edge of your trough so both the slurry (your mixture) and the hard carcass body are naturally bonding. As you might imagine, the Acetone will evaporate leaving nothing behind but ABS -- as hard as the original, fully bonded to the original material. Once dried, apply additional coats to build up the trough to your preferred profile.
Remove the tape on the outside and you're set. You could apply some sealant to the outer surface of the cracked area, but I did not as keeping it clean to look at on the outside is difficult when adding to the perfectly smooth outer surface.
Good luck.
Feb 10, 2011 | Boating
Lid of my 2010 Thule Atlantis 2100 (silver) cargo box is cracked and a few small pieces broken out.(drove into garage that was an inch too short) Is there a way to repair it?
I believe the silver is paint over black ABS; if so, my repair may help you.
A large (8 metre) branch fell on my Thule box splitting the upper carcass in many directions (both seams and field areas), in addition to the complete break of a front lower segment. I decided to try and fix it despite finding a replacement. Well I have to say, it worked out great, and it did not involve expensive epoxy, adhesives, hot air welders, or any of the methods most commonly referred to. Thule's cargo boxes are made from ABS plastic. The same black plastic material used for your household domestic waste plumbing systems. Rather than use foreign (non-ABS) material as your binding agent, simply use ABS. By keeping the joint material native, you are essentially re-establishing the continuity of the original material.
Good luck.
Dec 22, 2010 | Thule Winter Sports
Wind blew the top lid of my thule off the hinges how can I fix this problem
I have a Thule Atlantis 688T 2100 with one broken henge. What they sell online and call a hinge is not a hinge but the spring arm that holds the top open. I contacted Thule twice with no answer and on the third try Thule sent an email saying they won't sell replacement hinges and would only fix it if it were on waranty which it is not. If anyone has a solution please let me know. Now you know about Thule customer support. If you buy a Thule product, good luck. You'll need it.
Dec 12, 2010 | Thule Atlantis 1200
Line crack of roof.
I have a solution for cracking of these Thules.
The stores that sell these, carry a patching kit. It's a 3x8" piece of the same material with adhesive on one side. You can take a heat gun and soften the patch and place it over the crack and shape to fit before it cools. I've had 2 Thules on the roof of my excursion with stress cracks at the anchor points. This stuff really does the job and it's really inexpensive.
I have them on both boxes at all stress points... It has solved this issue.
Aug 14, 2010 | Thule 668 Frontier ES Roof Box - LL Bean
Top section of Thule box(atlantis 1600)cracked
Try this link and scroll down to online live help and they might be able to provide you with parts:http://www.rei.com/help/feedback/feedback.html#_2
Nov 30, 2009 | Thule Atlantis 1200
The catch/lock on the thule roof box broke - need a repair / replacement
Any Thule dealer should be able to sort this one out for you.
Have a look through Thule's website to find the model and possibly you could get it online if it's sold as a user changeable accessory..
http://www.thule.com/Thule
Sep 02, 2009 | Thule 686 Atlantis 1600 Cartop Carriers
Cracked thule box
www.recrepair.com is what Thule recommends you use to seal your crack :) -- it is an ABS patch kit and is waterproof as it is used for permanent canoe and kayak repairs. it is NASA designed.
I am using it on my Atlantis 1800.
Mar 30, 2009 | Thule Winter Sports
Thule Atlantis 1200 Logo
3,184 people viewed this question
Top Thule Cycling Experts
Michial Gueffroy
tau1618
Are you a Thule Cycling Expert? Answer questions, earn points and help others
