Sony Grand WEGA KDP-65XBR2 65 in. Rear Projection Television
Problem for Sony Grand WEGA KDP-65XBR2 65 in. Rear Projection...
Repair or buy new?
By cs35 on May 06, 2007
Hi-
I have a SONY KDP 65XBR2 TV - a wonderful unit that I have had for about 4 years.
About 6 months ago, it started to display curved diagonal lines - very visible in dark scenes, not at all in bright ones.
The it started to radomly flash bright grren - sometimes this was followed by the TV shutting down - we would either have to turn it back on or, more and more often - unplug it and plug it in again.
Although this has not happened for a few days, thelines are still there.
Someone told me that the green gun is probably going.
The problem is, I live in NYC - no one will servive it here - the want totake it to the shop - which costs $175 just to come and get it.
We were given ablu ray player for Xmas - the SOny of course has no HDMI input.
We have limited $$ to spend, and, as we see it, have three options.
1. Get it fixed
2. Try to sell it and buy a new TV with HDMI inputs
3. Donate it to a charity and take a tax write-off of $2000 or so.
The new HD TV we were thinking of was the Toshiba 65HM167 65" DLP Projection TV - not as good as the Sony we know - but we aren't as solvent as we were in 2002.
Any thoughts/suggestions would be appreciated!
Thanks!
Carl (cs35@aol.com)
Same Problem
Feb 16, 2009
-   We had the curved lines on the black screen...always. About 6 months ago we would turn the TV on and it would flash a few times go blue and shut down. We would have to unplug it to get it to come back on. It repeated this about 3 times before it would stay on. The last time it went off it would not come on again even when I unplugged it. Now we are without a TV. This TV was purchased at Circuit City and you can't get anything out of them now. I called Best Buy and they could not find the model number but said they would come service it to see if they could fix it. If I could find out the part number they would order it. Please offere me some hope. Thank you. Bonnie Tittle-   bonniet
Jul 06, 2008
-   i have the 65 inch sony grand wega i think? the picture comes on then about twenty seconds into it it starts flashing red on the screen and then the picture turns off .please help me i know nothing and could use a hand all i have done is remove the rear cover and look blindley into the guts of it-   skattydykis
Best Solution
posted on May 06, 2007
Very Helpful)
joshv
Rank: Guru
Rating: 85%, 130 votes
I would guess your problem is more likely the green drive bd (the circuit bd mounted to the neck of the green tube) it might be the tube but it doesn't have to be and I have seen many drive problems on sonys. I think the usually call it the CG board if you want to locate it and put it on it probably is relatively inexpensive. By the way my opinion for what it is worth the Toshiba is much better than the Sony.
Was this helpful?
Yes
No
Popular Solutions for Sony Grand WEGA KDP-65XBR2 65
Questions and Unsolved Problems for Sony Grand WEGA KDP-65XBR2 65
Do you recommend Sony Grand WEGA KDP-65XBR2 65 in. Rear Projection Television?
Answer
Answer
KDP65XBR2 TV, When turned on, no picture and there is a red light which blinks times.it has sound .... (More)
Answer
the tv after 10 minutes on the escren come on blue color only my tv is kdp-65xbr2
Answer
I have a Sony KDP-65XBR2. It powers up fine, then shuts off after 5 steady red blinks on the... (More)
Answer
I have a Sony KDP-65XBR2 tv that i am trying to fix.The tv will turn on with just a color display on... (More)
Answer
We have a TV with this problem: http://www.fixya.com/support/t1673203-sony_kdp65xbr2 I located both... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
