Question about GE WDSR2080D Top Load Washer
GE washer repair
My washer fills with water then it just hums. it doesn't spin or drain the water it just hums. any help will be appreciated. thank you
  • 3 more comments
  • Anonymous Dec 25, 2007
    washer fills but does not agitate. It does drain & spin when the dial is turned to spin, just doesn't agitate.
  • vippss Jan 10, 2008
    fill start to agatate then stop after 1 minute. will drain and spin
  • tdolan Jan 11, 2008
    fills and spins but will not drain, just hums...
  • Anonymous Mar 14, 2014
    ge spacemaker laundry fills but will not cycle hums in spin position. Model wsm2700rdwwh built 1995.
  • Anonymous Mar 15, 2014
    The washer fills with water but, only hums after and does not washer or pump out
To start I will never again buy another GE product for as long as I live. I am having the same problem w/my GE washing machine. I have to manually turn the dial to make it go thru its cycles. the problem is the 'timer' must be replaced. good luck trying to get their customer service dept to help you with anything. they are useless.
Posted on May 09, 2007
Ge GTWN2800D1WW washer wont fill on start but will do drain and spin cycle....help
What do you mean? It not fill up or no water is coming in?
Did you hear some humming noise?
Check the input water tap... close be closed or blocked...
Dec 01, 2015 | GE Washing Machines
Agitator doesn't run
The problem could be transmission failure
May 23, 2013 | GE WWSE5240D Top Load Washer
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Jul 15, 2009 | Washing Machines
GE Top Loader 10 years old. won't drain
Timer is faulty and should be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | GE WBSR3140DW Top Load Washer
GE top load washer won't drain or spin
there was something stuck in the water pump. we pulled it out and good to go.
Jun 14, 2008 | Washing Machines
GE top load washer will drain but not spin
you both need to have the switch replaced or you can open top of washer and combine the lid switches wires together as a bypass and electrical tape
the lid switches are put in the washers to keep kids from opening the washer machine this is automatic shut down
for xenazoe
you require this part for your washer
Part Number: WH12X10065
SWITCH PRESSURE
Apr 01, 2008 | GE WBB4500EWW Top Load Washer
GE WBVH6240
Disconnect power to machine,
Drain all the water you can.
Remove the bottom access panel ( 3 screws on bottom plate)
open the large plastic filter in center
have a tray and towels to catch the water,
remove all clogging material,
look in with a light and turn the pump , it should turn freely.
Jan 27, 2008 | GE WSXH208A Front Load Washer
GE WDSR2080D Top Load Washer Logo
370 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
