Question about Fisher and Paykel DEGX1 Electric Dryer
Fisher-paykel electric dryer less that two years old dryer makes a loud thumping noise , I have checke the filther and it is installed properly, dryer work fine except for this noise
  • 7labs Jan 01, 2009
    yes I have the same problem,
    it is still under warranty(have only had it 6 months) and I have had the service techs out to my house 4 times to diagnose and it is still making the sound. First they said it was the ball bearings..replaced them but that wasn't it. Then they said it was the drum? ordered the part which took a least a week since it is from CA.
    Now it is a two hour service call and taking my dryer completely apart to tell me that I had dog hair accumulated causing the thumping sound.
    I have had dogs my whole life and never had a problem with hair accumulating in a dryer. It SHOULD go into the lint catcher. Now I feel like a pig...but I think...well at least the dryer is working again. Meanwhile 3 1/2 weeks without my dryer, I feel lucky to have had an old basic Whirlpool in the basement. Never have had any problems with it and so I continued to lug my wet laundry to the basement to dry it.
    So they told me it was fixed. I used it for barely a week and the thumping is back. I really got talked into this washer and dryer and it is supposedly the best there is and lasts forever????
    I am disgusted. Besides the fact that obviously if others have a thumping sound, mine is #1 not unique and #2 not caused by DOG HAIR.
    I am contacting Fisher Paykel tomorrow and telling them that they better get this problem fixed or they can take this dryer back!
OK. I hope this helps someone that runs across it later. I had that. It sounds creepy, like someone pounding to get out. I found that same lint catch issue where it wasn't collecting. Here's the scoop. There is a screw behind the lint bowl thing that lets you remove that piece. (forgive me if it's not exact, it's been a few months since I fixed it) OK, next, There is a ring around the side that needs to be turned a notch to pull it off the drum. It's the white thing that you see when you look into the drum. What happened is the tiny clips that hold onto the lint wheel broke. the remaining ones are clipping where they should catch and hold, thus thumping as the drum turns. To fix this, I simply took high temp epoxy from the hardware store and glued the two together. (youll see it if you take it apart) Yes, if the lint thing goes bad, ill have to buy both parts though it cost me a failed service call and about an hour with less than $20 for the fix. Well worth the possible issue down the line.
From here, I should note that the lint will need a little help. Clean out as much as you can (make sure its unplugged, 220v is no joke) The vent fan is all part of the same belt/motor as far as I can tell. I took a vac and shoved it in the back and slowly turned the fan thing by hand. It sucks, it's not going to get it all, but if you get enough, it should work to blow the rest out.
If this doesn't make sense or you'd like pics, email me. s kleman at g mail. with no spaces in the email...
Posted on Nov 06, 2012
  • Fisher and P... Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
wywter
Posted on Sep 29, 2010
Loud
If the dryer is not sitting in all four corners and rocking back and forth, try adjusting the leveling feet to make it stable. Another cause of noise are worn idler wheels that have either buildup, or wear that makes a thumping noise. They would need to be replaced.
Mar 20, 2014 | Fisher and Paykel DGGX2 Dryer
My dryer is making a thumping noise even without the vent being on. The vent pipe is not plugged.
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 23, 2011 | Fisher and Paykel DEGX1 Electric Dryer
Why is it leaving black dots on my clothes and making a loud noise?
It could be bearings or guide in the drum.Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Aug 03, 2010 | Fisher and Paykel DEGX1 Electric Dryer
No heat on any settings...worked the day before...great dryer, but less than a year old. What's up?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 30, 2010 | Fisher and Paykel DE09 Dryer
Dryer is not working makes loud noise
heatman101
Jun 18, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Frigidaire Dryer making loud thumping noise in back.
Some things to check.
Worn rear drum rollers, idler pulley, or drum front slide kit.
Click here for illustrations.
Hope this helps.
Aug 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Fisher & Paykel top load electric dyer makes loud squeaky sound
to be honest i doubt that a bad belt would make a squicky noise and for a high class dryer like that i would suggest just call repairman  they are very complex
Jun 08, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Did you resolve your dryer / noise?
heatman101
7687t
Apr 14, 2009 | LG DLG5932W Gas Dryer
Fisher and paykel dryer works but very noisy
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 27, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
394 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
