Question about Blue Rhino 2350 Heater
Patio heater when turing on patio heater the flame lights fine but when i let go of the knob the flame shuts off.repeated steps holding down knob for up to minutes and flame shuts off. propane tank full. thanks
Buffalo12980
  • 625 Answers
SOURCE: Patio heater won't stay lit
make/model??
Posted on Oct 15, 2007
Buffalo12980
  • 625 Answers
SOURCE: Kirkland heaters - outdoor patio
get a new thermocouple
Posted on May 27, 2008
  • 8 Answers
SOURCE: Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
Posted on Jun 18, 2008
AZSTALZ
SOURCE: charmglow patio heater
Well, I just went out this morning and worked on the heater after it would not light last night. Turns out that a spider or moth set up camp in the pilot light intake housing and plugged up the two small mixer holes that pull in air for the pilot light. This would explain the 'yellow-flame'. I took a punch awl and some compressed air and cleaned out the hole, then re-installed the cover and knob. Lastly, I turned and depressed the knob and the pilot light ignited almost instantly, stayed on when I let the knob up, and the heater turned on normally after that. Good luck, I hope this helps.
Posted on Nov 09, 2008
Accurate Joe
  • 61 Answers
SOURCE: Reddy propane heater RLP100
Try a little longer, sometimes it takes a full minute to heat the thermocouple. Check and make sure thermocouple is in flame. If all this is ok. then your going to have to change the valve.
Posted on Nov 30, 2008
2006 water heater. Is it only run on gas. How do i turn it on.
If it is a regular gas hot water heater You need to turn the knob on the gas valve to pilot. Depress and hold the knob down. while doing that press the green button on the side of the valve . you may have to repeat that a few times. that button makes a spark to light the pilot. You need to hold the knob down for about a minute more to let the thermocouple heat up and signal the gas valve that it has a flame. release the knob . if the pilot flame stays on ,turn the knob back to the on position. If that does not work repeat if still not working give more info. Make and model of heater
Feb 03, 2015 | Water Water Heaters
Push knob in and lights fine wont stay lit after started goes out when knob comes out.
Most likely the regulator is bad. The second culprit could be the thermocouple.
Dec 24, 2009 | Eastman Outdoors 90207 Open Flame Patio...
I go thru the process of lighting the pilot light following the directions exactly, but as soon as I let the pilot light switch pop out so that I can turn it to the left to light the heater the flame goes...
The system works off of a thermocouple that is heated by the pilot. The thermocouple creates millivolts that magnetize a head behind the control knob. When you push in the knob the magnetized head behind the knob holds the gas valve open. So obviously the head is not being magnetized. First make sure that the pilot is not plugged and the flame is large enough to heat the thermocouple. Also sometimes you may need to hold the knob for several minutes before the pilot will stay on. Also patio heaters have a safety feature that will cut the millivolt circuit if the heater falls over. It is possible that this safety device is tripped or defective causing the pilot to not stay lit. Also check for any loose wires on the millivolt system.
Dec 21, 2009 | Endless Summer UniFlame (GWU501E) Open...
Pilot flame lights but goes out when knob is released
i would try cleaning or replacing the thermocoulpe if you did replace it make sure the flame is touching the thermocouple
Jul 30, 2009 | DCS PHFS Phoenix III Outdoor Patio Heater
Burner will not ignite as pilot light goes out when knob is released
Are you holding the knob for 30 or more seconds,If so,Clean or replace the thermocouple/Flame sensor.
May 29, 2009 | Endless Summer (GA200209) Stainless Steel...
Windchaser patio heater
You have to hold the button down for 30 seconds at least before turning the knob to ON. If you are doing this and it still goes out after you let up on the knob, then it needs a new flame sensor, or thermocouple. Same thing different names.
Feb 29, 2008 | Endless Summer 2009 Open Flame Patio...
Lighting a glo warm heater
Is this a new heater or have you had it awhile? If new, yuo may have air in the line that will need to be bled out. The heater has a gas valve with a pilot setting on it. Make sure the gas is turned on. Turn the knob to the pilot setting and depress the handle. Holding it down and at the same time, press down on the red button that sparks. You may have to repeat this a few times. Once the pilot lights, continue to hold down on the pilot knob for about 30 seconds. When uou release the knob, the flame should stay o. If it does not, replace the thermocouple. Once the pilot flame is steady, turn the gas valve knob to on.
Nov 29, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Blue Rhino 2350 Heater Logo
70 people viewed this question
Top Blue Rhino Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Blue Rhino Heating and Cooling Expert? Answer questions, earn points and help others
