Question about Fisher DS603W / DS603B / DS603I Dishwasher
Dishwasher error have a fisher paykel ds603i, top draw is receiving an error, constantly beeping with red light showing, bottom drawer is running
  • mettert May 14, 2009
    i have the smae problem - i only have the top half of the machine - and it is beeping every second + an icon with a small tap with a line over bliks. The documentation tells me it is bc there is no water coming in (and yes it is dry) but not how to solve it. I tried turn on and off the machine, teh water, ... any ideas?
The error was a flood fault, water was not draining from either of the drawere, I removed the bottom drawer, dried drip pan and used hairdryer to dry fault sensor, the dishwasher then reset itself and works fine.
Posted on Jan 01, 2009
Top drawer can not be open
If this is a double drawer dishwasher and bottom drawing is functional but top drawer won't open means the controller on top drawer is faulty or power circuit is locked. If turning the mains power off and back on makes no difference then controller could be the problem. One way to test is to take the controller from bottom drawer and replace that in the top drawer. This requires a lot of patience and experience with electronic stuff. If you are not brave enough to test then call the technician. The controller is about $200 to buy. Make sure the mains power socket is taken out before working on the dishwasher internals.
FISHER PAYKEL DISHWASHER DD603 Parts
Feb 10, 2014 | Fisher and Paykel Dishwashers
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
My Fisher Paykel DD603I top draw whines when it is first turned
The lid seal on the top drawer is faulty and needs replacement. It might be cut or damaged and is obstructing the drawer from closing. THis also may have caused the flood switch to trip as water can leak if drawer is not sealed.
Nov 29, 2012 | Fisher and Paykel Dishwashers
My single Fisher & Paykel dishwasher drawer DS603I (Integrated Panel) turns on by itself even after turning off the light switch that controls both units that sit on opposite sides of the sink. The...
Yes ,you may be able to restore function by completely drying the area and PC board located under drawer.Use a hair dryer.
However , you will still have a leak and the problem will return.Usually the leak is drawer lid not closing properly. Suspect lid actuators have failed.Very common.Or some kind of obstruction.The drawer can be removed easily by removing 2 large plastic scews at drawer front.If lid actuators have never been replaced go ahead and do that.It is normal for other drawer to work fine.
Hope this helps you
Aug 16, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
We have a 23" Fisher&Paykel dishwasher and got
The F1 error coming on top drawer when operating bottom drawer is due to the thermal fuse blowing up on the bottom drawer and shutting controller power.
The thermal fuse could have blown either as a normal component failure or heater over heated due to thermostat failure. In any case this can be repaired by replacing the whole heater assembly as all the parts are integrated.
This is at the underside of the drawer and will need a technician to replace unless you are very familiar with repairing electronic dishwashers. The part look like this.
The way you have described the onset of the F1 error is not due to flood switch. You can confirm that the lights on the bottom drawer are out even though the top drawer is showing F1 and beeping.
If problem was flood switch then both drawers would show F1.
Nov 25, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
My fisher paykel nautlis dishwaher display error code F1
What is the Model #? If both drawers, if a double, display F1 and won't shut-up then the flood switch is tripped and you have to unplug it to keep it from beeping and the drain motor running. The causes for the F1 fault can be numerous but not excluding bad lid lifts, broken link support, cracked drain line and wrong soap. Call F/P
Jul 19, 2009 | Fisher DS603W / DS603B / DS603I Dishwasher
F 1 Error, blinking, beeping and will not stop even when turned off, so we had to turn the circuit breaker off to stop the noise.
You have a leak.
Either from the top lid seal or bottom lid seal. A s time goes by the water level activates the sensor causing the beep. It won't do anything until you fix the leak.
May 25, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dish drawer DD601v2
thats tub home sensor switch, mounts to rear right of cabinet and senses drawer closing along with little black box with red switch should also have a little metal actuator( this is what usually breaks off switch), each drawer uses their own. unistall from cabinet and theres an access panel strictly for replacing theses switches
Feb 12, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher paykel - dishwasher - 2 drawer dd603i - top of dishwasher loose
The dishwasher while running began to beep constantly and then BOTH drawers began to beep with blue lights and read F1 with the small picture of a wrench. It will not turn off but keeps beeping with flashing lights.
Jan 20, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher DS603W / DS603B / DS603I Dishwasher Logo
490 people viewed this question
Top Fisher Dishwashers Experts
Tony Houde
Tony Houde
George Merkley
George Merkley
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
