Question about Frigidaire GLTR1670A Front Load Washer
'DR' indicator light on but door is shut
Front loading Fridgiair washing machine. It is 4 months old. Today the load was not spun out, water remained in tub. 'DR' indicator would not go off with the pause, clear, examining the door and latches. We tried unpluf\gging it to reset it etc. Any ideas?
    President:
  • 1,294 Answers
Check out your outlet drain filter; dr could be drain. Possible this is clogged or something or the water shd just drain. To reset press pause and reset together for about 4 seconds. Suggestions, ideas.
Posted on Sep 04, 2007
Door remains locked and machine doesn't start running
Did you check and see if the child lock is active?
Mar 25, 2017 | Zanussi FJ1254W Front Load Washer
Water remains in the tub after spin cycle
Sounds to me like the Water Pump is bad. Hopefully if your machine is less than a year old you can get it fixed for free, if you bought it new it will have a 12 month warranty on it. If not you can always buy the manual for your washer and try to fix it yourself.
May 15, 2010 | Hotpoint Aquarius WD63 Front Load...
My washing machine tub is off kilter, the water runs in, that's all. It worked fine, washed, rinsed & spun last load, & now won't rotate or move, please tell me what to do?
There are 4 support arms on this unit and the tub has popped off. Using a flat blade you will need to locate and push in the locking tabs for the front panel. 1 on each side and when you locate push in while pulling the front panel toward you on that corner. You will then be able to see the support and with help from someone. 1 of you lift the tub up and the other will slip the rod back into position. You can look at any of the others to see how it hangs. Hope this helps and good luck.
Feb 24, 2010 | GE WBSR3140DW Top Load Washer
After the clothes have spun dry, a small amount of water accumlates in the tub; generally 1/4 inch or so. Why BTW, I'm not sure that I've selected the correct model. Our washer is about 3 years old.
If draining into laundry tub, chances are water is siphoned back into washer due to laundry tub slow drain.
Very long drain hoses( such as 10+ feet) will also cause this.
Nov 05, 2009 | Fisher and Paykel IWL12 Top Load Washer
Our front-loading HE washing machine delivers
try putting in 2 caps of a citrus or pine bleech straight in to the drum with some old rags. then select a boil wash. the rags will spray the water around the tub, the bleech will clean the tub and make it smell fresh. DON'T put any clothing in whilst doing this. if you are worried about bleech in the machine just select a rinse cycle after. i do this once every 3 months
Aug 05, 2009 | Maytag MAH2400A Front Load Washer
Standing water in washer after cycle
take off the bottom front panel and clean the coin trap it will be up front just unscrew it have some towels handy
Dec 20, 2008 | Whirlpool GHW9400 Front Load Washer
Whirlpool top loading washing machine
Maybe the motor is shot, maybe the electronics are messed up. You might be able to siphon the water out of the tub.
Apr 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Water in machine
does it actually refill with water or is the water still remaining from that load? i recycle my water though a hose to use on my garden if it dosent run freely and quickly enough water will still remain in my machine sometimes nearlly half a load. that makes me think it could be your drain the smell would suggest slow or sitting water which could indicate obstruction along the line somewhere.check as much length of the drain as you can my drain outside has a u shape where things can build up there is also a removable cape so at least you can stick something down there.
Dec 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire GLTR1670A Front Load Washer Logo
54 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
