Question about Whirlpool GEW9250 Electric Dryer
Dryer wont heat up it just blows cold air...whats the deal???????
Its an Amana Distinction Dryer / Electric / Model # DLE330RAW
    Scholar:
  • 39 Answers
Usually what fails in an electric dryer after years of good service that the heating element or elements fail and it often blows a fuse in the dryer when it does this. You need to remove covers and check the heating element with an ohm meter, Sometimes the element is visible and can be seen to be broken. If you can't see the break avoiding handling the element wire as the older it is the more fragile it gets. No point breaking one that isn't already broken. The thermostat that controls the drying temperature can also fail but that is less likely. Heating elements are like light bulbs. They have a fixed life and burn out after a number of hours. Don't forget to replace the fuse if it has one and its blown with the same size fuse.
Posted on Dec 31, 2008
My Amana distinction started making a loud sound like maybe the belt and I have to take cloths out of it. Now it stopped altogether. Is it the belt or drum?
Amana Dryer Makes Noise - Model DLE330RAW - Repair ...
www.repairclinic.com/...-/Amana-Dryer-makes-noise-DLE330RAW
When the drum rollers are worn out, they can cause the dryer to make a loud rumblingnoise. To determine if the rollers are worn out, inspect the rollers. If one or ...
Nov 26, 2015 | Amana Dryers
NO HEAT TESTED HEATING COIL ITS FINE DRYER ICE COLD
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 24, 2011 | Amana DLE330RAW Electric Dryer
Wont come on
At May be No guides are always there to provide technical support to troubleshoot Amana DLE330RAW Electric Dryer Problems which is free of cost. You can also get Amana DLE330RAW Electric Dryer, Dryers Help from archived solutions related to repair, maintenance, upgrades and installation problems.
Dec 16, 2010 | Amana DLE330RAW Electric Dryer
My Amana Electric Dryer DLE330RAW not heating
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 31, 2010 | Amana DLE330RAW Electric Dryer
Amana DLE330RAW Elec Dryer starts then shuts off & wont turn on
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 08, 2010 | Amana DLE330RAW Electric Dryer
Dryer has no heat
Most of the time the no heat is caused by a high temperature limit fuse blowing due to a lack of air flow. The part is not expensive, but tracing it down in the particular dryer may be difficult. To give more direction I'd need more information. I am familiar with Speed Queen, Whirlpool and their renamed counterparts (some Hotpoint, Kenmore, etc.)
Oct 25, 2009 | Amana DLE330RAW Electric Dryer
Dle330raw not heating.replaced heating element was working on time dry then stopped, replaced thermostate. no heat at all now.
Check your blower, it may not be blowing hot air to your drum..You did not say if it was blowing or not.
Sep 26, 2009 | Amana DLE330RAW Electric Dryer
My amana dryer turns on but wont heat only cold air
you can remove the acess panel fornthlower front, and the heate and thermostats are located on back wall, check for continuty, in hte thermnaostats and heater
Mar 15, 2009 | Amana DLE330RAW Electric Dryer
My dryer wont heat up...It just blows cold air....?????
It may be the thermal fuse but it could also be the heating element. The way to check is to open it up as described above and run the dryer. Watch the element and if it turns on then off again immediately then it is your thermal fuse. That is only about 15 dollars to fix and you can get a new fuse at any appliance repair shop. If the element doesn't ever come on then the element is burnt out and needs to be replaced. This is a little more expensive. I hope this was helpful and if you have any more questions feel free to ask me. Good luck.
Dec 31, 2008 | Whirlpool GEW9250 Electric Dryer
Heating element
What did the original heater look like when you removed it? Was it burned in two? Make sure you are getting air circulation over the heater. Check your lint filter and air exhaust piping. Flapper outside on the exhaust pipe may be sticking.
May 28, 2008 | Amana DLE330RAW Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
166 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
