Question about KDS K717s 17" LCD Monitor
Wide screen images lookshort and fat
You told me to change to 1400 9000
  • 3 more comments
  • shadyuk Dec 31, 2008
    This did not work I need help to change the settings
    Thanks I will try it because the 1440 was making them look too skinny Thank you I hope it works !
    I just tried your suggestion but I cant get it to stay on 800 it keeps going to 960 ?
    My monitor is a 21 inch !
    Have just realised my monitor is 21 inches .... I need help to change screen settings
    Scholar:
  • 96 Answers
Native resolution for a 17" widescreen TFT is ;
1280 x 800
Try that.
(The 1440 x 900 is for a 19" widescreen)
Posted on Dec 31, 2008
Wide screen stretches all my photos
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.
Dec 09, 2011 | Samsung Computers & Internet
The HANNSPREE monitor that I just bought is great except for one thing. As a photographer, the HANNSPREE screen is too wide in relation to the normal photograph sizes. The horizontal linear distortion...
The best way to adjust the screen is to adjust the screen resolution until you get a correctly proportioned image.
First display an image such as a square or a circle on the screen.
Go to Control panel - Display - Settings tab and start with 1024 X 768 screen resolution adjustment
click Apply and the check your image.
Repeat the adjust screen resolution select the next highest screen resolution setting, repeat thia process until you get the best image.
Jan 24, 2011 | Computers & Internet
I have a 55cm TFT LLED-22FHD TV. The aspect ratio is 16:9. This is too wide and the images appear fat. How do I correct this.
Go to the picture menu and select a different aspect ratio. Auto sizing is useful as the TV will detect the picture size and select the correct aspect ratio, except for letterbox and super wide screen of course as your screen is not the right shape for those.
Hope this helps.
Nov 17, 2010 | Televison & Video
How do I adjust the 22 in. rectangular screen to prevent images from appearing wider than normal. For example, pictures of persons make them look fat and wide.
You can use any other image viewing software such as Picasa. It will open images at 100% size but you can change the size of images
Jan 02, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
The pictures are too wide all people look fat
You most likely have a wide screen and the screen resolution needs to be adjusted to suit the monitor.
Go to the Control Panel - Display and adjust the screen resolution until you get a normal image and correct screen aspect screen ratio. Start with a screen resolution of 1024X768 and gradually increase it until you get an image that suits your screen.
Oct 01, 2009 | Acer Computers & Internet
Acer widescreen extend sides when setting old resolution
You have entered the area between a rock and a hard place. The older games are not aware of the possibility of a wide screen. Either put up with the fat and large images or get a second 4X3 ratio monitor for your older games.
I do not know of any driver to do what you are asking.
Aug 03, 2009 | Computers & Internet
Distorted images due to wide screen
Hi
Your entire desktop is probably stretched left to right.
You need to adjust the resolution of your computers video card in the display properties to one that the widescreen will accept correctly.
There is a chance that your video card may not have the correct resolutions available. If this is the case then you may be stuck with this view until you change coputers or video cards.
to get to display properties based on win2k or xp
Right click in the center of your desktop, choose properties, go to settings and there you should see the resolutions available. Try different ones till you find a good one, you may have to settle for one that is close to your monitors setup if the exact one isn't available.
If using a laptop with a standard screen with the wide monitor, you may need to disable the laptop screen and use just the monitor to get the correct resolution on the monitor.
Fran
Oct 13, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Display appearing stretched
the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
Oct 26, 2007 | ViewSonic VA1912wb 19" LCD Monitor
KDS K717s 17" LCD Monitor Logo
64 people viewed this question
Top KDS Computers & Internet Experts
RobertFonner
RobertFonner
ray
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
