Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
Router problem hi, i have a belkin 54g and did not know how to make it secure....i have two laptops that are connected to it.....have a neighbor that could have access.....please advise ....thank you
  • 25 Answers
Securing your router is very easy. Here is where the manual is located.
<a rel='nofollow' href="http://www.belkin.com/support/article/?lid=en&aid=5999">Here.</a>
There are detailed instructions (on page 48) in there on how to access your router and secure it. Post up if you are still having trouble and I will see if I can be of any more assistance.
Posted on Dec 31, 2008
  • 340 Answers
Connect a computer to any one of the four LAN ports of the Belkin wireless router. DO NOT use a wireless connection, use a cable.
Open your web browser and type the IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit.
Click Security under Wireless menu.
Under Security, Select 64 bit WEP (or 128 bit WEP).
Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you. Example (0102030405060708090a0b0c)
Apply the settings.
Please write down the key – You will need it later to configure your and your neighbors wireless computers with the same key.
Remember to set an admin password before you close down, other vice anyone can access you router and change the setup and admin password.
/regards
Teis
I have secured my router by connecting my laptop to the router by ethernet cable so now my network comes up as security enabled but I can't seem to connect to my wireless network although it shows the...
Remove the neighbor's network from the preferred network list.
add your own network in the list. If your router is old router then upgrade the firmware of the router. Firmware is the software of the router.
You have connected your laptop to the router, to secure the wireless network. When you connect the laptop to the router, make sure that the wireless network connection will be disabled.
Once you change the wireless settings, enable the wireless connection and connect to your network.
Apr 25, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Hi i have been trying to set a password for my belkin router but cannot log on line to the ip address
The address fro your Belkin 54G wireless router setup should be: http://192.168.2.1/
I would bypass the WiFi link/security and connect your PC/Laptop to be used for configuring the router via the Ethernet cable connection plug in Port 1 of the router.
If you do not have the password, you will need to reset the router to 'factory default' by using a small reset button on the back: you need a pen to push it down. Hold it down for about 10 seconds and it will put the router to factory default settings.
You will then need to reconfigure the router using the Belkins setup CD that came with the router (or download it before hand from Belkins support site): this will normally set it up automatically for you.
Hope it helps!
Dec 20, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
How to secure belkin 54 wireless router
Easiest wsay is to connect via cable and go into the configuration pages and set the security from the menu. Discoonect and then go into the wireless network settings on the laptop
Dec 06, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Need to enter Wireless Key???
connect your router to computer with ethernet cable.
Then you can access it with following link.
for belkin routers http://192.168.15.1
for other routers
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.Click on wireless and If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Let me know if you need further assistance.
Nov 15, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
How do I put security on my Belkin 54g router
You set your security by enabling WEP.
When you get in the interface to configure WEP, set a pass phrase. Write down the 3 numeric keys it generates. Then connect to the wireless using your laptop, etc. When it asks for your passkey, do not enter the pass-phrase; enter one of the three keys that were generated by the router. That's the biggest mistake people make when trying to get wireless to work.
Oct 06, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Wont connect to belkin 54g with wpa security applied
Please try using Wireless 'G' mode only in the router. Also, try using 'TKIP' and not TKIP+AES for encryption.
Please rate this solution, if it works for you.
Jun 01, 2009 | Dell Inspiron 6400 Notebook
Cant connect
Hi! Did you go into the router configuration through IE (Internet Explorer)?
May 24, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
120 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
