Question about Sharp XR-10X Multimedia Projector
Opening the Sharp XR10-X
How do I open up the Sharp XR10-X to replace the lamp? The cover is really tight and I don't want to break it. What's the trick to it?
  • dothory Nov 07, 2007
    I've already unscrew them but the lamp is still tight. Do I have to pull it harder?
  • 4 Answers
Yes the LAMP is very tight sometimes. What I do is use something to pry on one side, while pushing against it from the other. Just be careful. It does take a little work.
Posted on Nov 26, 2007
    Problem Solver:
  • 14 Answers
There is a screw to open the cover. then see the two or three screws inside for lamp.unscrew the same and pull the lamp out.
Posted on Jun 04, 2007
I was given this model tv. The green and red lights on the front are flashing. Says to replace bulb and close lamp cover correctly. I am missing the lamp cover. Is that going to be a problem?
U mean the Lamp door cover?Yes?Tv might work,might not.Don't know never tries to turn the tv on before without a Lamp door cover close before.There is a blue safety switch though must be press down when the Lamp door cover is close.Test it out.Why don't u just take a piece of tape and tape that blue safety switch down tightly,than turn on the tv.If the tv message that said close lamp cover correctly disappear.Than yes the tv will work,without the lamp cover closed.Now u just needed to do a replacement of the tv projection lamp only that all.
Sep 24, 2011 | Toshiba 62HM95 62" HDTV
E7 02 SHARP AR-5316
CCD is not detecting the white refference value possibily your lamp is not getting on at the starting time check by opening the cover of the machine , if the lamp is not lighting up you have to suspect the white ribbon cable in the optics , first replace that one if the problem not resolved replace the pcu pwb and lamp inverter pwb respectievely. come back with your queries rate this and vote for this
May 10, 2011 | Sharp AR-5320 Black and White Copier
I have changed the lamp in a Sony VPL EX-1. I have fitted a YODN (LMP - C150) I cannot get the flashing light to go out which indicates `lamp,cover` and I cannot do anything with the projector.
When you open the lamp cover for replacement of lamp there is a switch in the projector is OFF
If lamp cover not fix proper after replacement of lamp the lamp/cover indicator flashing
SOLUTION: Open the lamp cover and fix proper and tight the screw
Feb 22, 2011 | Sony VPL-EX1 Multimedia Projector
Where is light bulb locatd in the sharp carousel?
Replacement of the lamp should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its position is adjacent to the vent holes that it shines through.
If you feel confident, disconnect it from the mains power, remove anything in the cavity.
Remove the microwave cover. Purchasing a new replacement lamp will be useful as it will give you an idea of what it looks like. Locate the dead lamp remove the lamp and fit the new one. Replace the covers. Plug it back in and try the lamp by opening the door.
Hope this helps.
Feb 20, 2011 | Microwave Ovens
R-209 Microwave : How do i change the light bulb pls ?
Hope this helps.
Feb 15, 2011 | Sharp Microwave Ovens
How do i change the bulb in a sharp R-350F
Hope this helps.
Feb 07, 2011 | Sharp Microwave Ovens
Replacing bulb
Hope this helps.
Jan 29, 2011 | Sharp R-354 Microwave Oven
The oven light is going out sporatically . Can I replace it?
Hope this helps.
Jan 12, 2011 | Sharp R-1480 Microwave Oven
Need to replace the bulb on a sharp carousel microwave oven - model R-4620
Hope this helps.
Jan 07, 2011 | Microwave Ovens
XR-10x bulb timer has timed out. How do I reset the projector?
you need to reset the lamp timer see http://www.ercservice.com/PDF/Lamp-Sharp-XR10-XR20.pdf
Apr 07, 2009 | Sharp XR-10X Multimedia Projector
Sharp XR-10X Multimedia Projector Logo
299 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
